XLD: 1 track of new CD not found by AccurateRip, “may not be accurate”
tomten_alle
post Apr 17 2012, 20:22
I have just bought Symphony X - The Odyssey (Limited Edition). When I rip it using XLD 20120407 all tracks except one rip perfectly. I have verified with many other disc that all settings are correct.
Log
X Lossless Decoder version 20120407 (140.0)
XLD extraction logfile from 2012-04-17 20:58:21 +0200
Symphony X / The Odyssey
Used drive : MATSHITA DVD-R UJ-898 (revision HC10)
Ripper mode : XLD Secure Ripper
Disable audio cache : OK for the drive with a cache less than 1375KiB
Make use of C2 pointers : NO
Read offset correction : 102
Max retry count : 20
Gap status : Analyzed, Appended
TOC of the extracted CD
Track | Start | Length | Start sector | End sector
1 | 00:00:00 | 05:32:53 | 0 | 24952
2 | 05:32:53 | 05:32:50 | 24953 | 49902
3 | 11:05:28 | 04:22:14 | 49903 | 69566
4 | 15:27:42 | 07:53:40 | 69567 | 105081
5 | 23:21:07 | 06:19:72 | 105082 | 133578
6 | 29:41:04 | 04:44:51 | 133579 | 154929
7 | 34:25:55 | 08:21:55 | 154930 | 192559
8 | 42:47:35 | 24:13:73 | 192560 | 301607
9 | 67:01:33 | 05:59:69 | 301608 | 328601
List of alternate offset correction values
# | Absolute | Relative | Confidence
1 | 84 | -18 | 105
2 | 9 | -93 | 8
AccurateRip Summary
Track 01 : OK (AR2, confidence 11, with different offset)
Track 02 : OK (AR2, confidence 11, with different offset)
Track 03 : OK (AR2, confidence 11, with different offset)
Track 04 : OK (AR2, confidence 11, with different offset)
Track 05 : OK (AR2, confidence 11, with different offset)
Track 06 : OK (AR2, confidence 11, with different offset)
Track 07 : OK (AR2, confidence 11, with different offset)
Track 08 : NG
Track 09 : OK (AR2, confidence 11, with different offset)
->8 track(s) accurately ripped, 1 track(s) not, 0 track(s) not found
All Tracks
Filename : /Users/tomten_alle/Documents/MusikFlac/Original/Symphony X/The Odyssey/Symphony X - The Odyssey.flac
Album gain : -7.83 dB
Peak : 0.952576
CRC32 hash : 567CC956
CRC32 hash (skip zero) : 70613786
Statistics
Read error : 0
Jitter error (maybe fixed) : 0
Retry sector count : 0
Damaged sector count : 0
Track 01
Pre-gap length : 00:02:00
Track gain : -7.59 dB
Peak : 0.889496
CRC32 hash : 8D2CBE33
CRC32 hash (skip zero) : 667AEC5E
AccurateRip signature : 2CA94A8B
->Accurately ripped! (AR2, confidence 11)
(matched with the different offset correction value;
calculated using an additional offset of -18;
the signature after correction is: 70E15955)
Statistics
Read error : 0
Track 02
Pre-gap length : 00:01:00
Track gain : -6.99 dB
Peak : 0.889496
CRC32 hash : 0875E0F8
CRC32 hash (skip zero) : 9825DBC0
AccurateRip signature : 23732D47
the signature after correction is: 3BA10DB8)
Statistics
Read error : 0
Track 03
Track gain : -8.33 dB
Peak : 0.889496
CRC32 hash : 3DCC2EEF
CRC32 hash (skip zero) : E31C1AB2
AccurateRip signature : B2F9CE93
the signature after correction is: C7C421C3)
Statistics
Read error : 0
Track 04
Pre-gap length : 00:03:00
Track gain : -7.92 dB
Peak : 0.839752
CRC32 hash : 7A894994
CRC32 hash (skip zero) : 250F5EDF
AccurateRip signature : BAA1D767
the signature after correction is: 7B706844)
Statistics
Read error : 0
Track 05
Track gain : -7.93 dB
Peak : 0.889496
CRC32 hash : C6B555B0
CRC32 hash (skip zero) : 855956C7
AccurateRip signature : CD0FBDED
the signature after correction is: 499369BD)
Statistics
Read error : 0
Track 06
Track gain : -8.21 dB
Peak : 0.889496
CRC32 hash : 50240667
CRC32 hash (skip zero) : A142F143
AccurateRip signature : 83751680
the signature after correction is: 5171B6F6)
Statistics
Read error : 0
Track 07
Track gain : -8.25 dB
Peak : 0.942200
CRC32 hash : 01FFC47C
CRC32 hash (skip zero) : 8B9A6E76
AccurateRip signature : EC675883
the signature after correction is: 869E4A22)
Statistics
Read error : 0
Track 08
Pre-gap length : 00:04:00
Track gain : -7.53 dB
Peak : 0.943207
CRC32 hash : 7338D5AE
CRC32 hash (skip zero) : E3A5BCA3
AccurateRip signature : 30FB5342
->Rip may not be accurate.
Statistics
Read error : 0
Track 09
Track gain : -6.86 dB
Peak : 0.952576
CRC32 hash : 0448CFCC
CRC32 hash (skip zero) : 4CD6418E
AccurateRip signature : 0670F43B
the signature after correction is: EF858017)
Statistics
Read error : 0
Some inconsistencies found
End of status report
How can this be? I doubt the accurip DB is wrong. Am I wrong or is the DB wrong?
This post has been edited by db1989: Apr 17 2012, 20:49
Reason for edit: improving title / changing enclosure of huge log from [code] to [codebox]
- tomten_alle   XLD: 1 track of new CD not found by AccurateRip, “may not be accurate”   Apr 17 2012, 20:22
- - spoon   With a Confidence of 11 it is likely your rip has ...   Apr 17 2012, 20:48
|- - tomten_alle   QUOTE (spoon @ Apr 17 2012, 21:48) With a...   Apr 21 2012, 16:26
- - Engelsstaub   There seem to exist multiple pressings of this CD ...   Apr 21 2012, 23:42
- - Chinch   Personally, I don't know what XLD is (other th...   Apr 22 2012, 10:50
|- - tomten_alle   QUOTE (Chinch @ Apr 22 2012, 11:50) Perso...   Apr 22 2012, 15:32
- - Pepzhez   I have experienced this (very infrequent) problem ...   Apr 22 2012, 22:19
|- - tomten_alle   QUOTE (Pepzhez @ Apr 22 2012, 23:19) I ha...   Apr 23 2012, 17:55
- - Pepzhez   I would say that there is definitely a problem wit...   Apr 24 2012, 07:00
- - gib   Since the CRC was the same every time you ripped i...   Apr 24 2012, 07:15
- - Pepzhez   I'd second ripping again with a different driv...   Apr 25 2012, 04:57
- - tomten_alle   QUOTE (gib @ Apr 24 2012, 08:15) Since th...   Apr 26 2012, 15:05
- - psycho   Hey! I have this CD... I've tried to rip ...   Apr 26 2012, 17:52
|- - gib   QUOTE (psycho @ Apr 26 2012, 06:52) Judgi...   Apr 27 2012, 03:55
- - psycho   @gib, either that, or he uses wrong offset for his...   Apr 27 2012, 13:26
|- - gib   QUOTE (psycho @ Apr 27 2012, 02:26) Now, ...   Apr 28 2012, 09:45
|- - Kees de Visser   QUOTE (gib @ Apr 28 2012, 10:45) I know w...   Apr 28 2012, 10:19
|- - gib   QUOTE (Kees de Visser @ Apr 27 2012, 23:1...   Apr 28 2012, 22:36
- - psycho   @gib, thanks for clarifying. I was mixing apples ...   Apr 28 2012, 12:47
- - tomten_alle   Hi again! Sorry for the delay! Here is a ...   Jul 26 2012, 15:30
- - greynol   QUOTE (gib @ Apr 28 2012, 01:45) AR2 (and...   Jul 26 2012, 16:36
- - spoon   > In fact, the algorithm change has actually ma...   Jul 26 2012, 21:30
|- - greynol   QUOTE (spoon @ Jul 26 2012, 13:30) > I...   Jul 27 2012, 15:13
- - spoon   @tomten_alle Re-rip in XLD, keep the ripper const...   Jul 26 2012, 23:20
RSS Lo-Fi Version Time is now: 27th January 2015 - 18:15
