Using FB2K for correcting file names that are too long ?, Closed due to spam. Please PM a staff member to reopen.
swayzak
post Apr 13 2012, 21:54
Hi
I came across a weird problem today.
I have been running a music library from an ext USB driver (320GB+, mostly mpt3 files) for my Logitech Squeezebox devices.
Bought a nice new Win 7 64bit laptop today with a 750GB drive so tried to copy over the library.
Annoyingly approx. 113 mp3 files refused to copy because of filename length issues.
Don't understand why they can exist & be played from the USB drive on my old netbook, but there you go.
Is there an easy way I can use FB2K to identify all the culprits & shorten the filename lengths to circumvent this problem ?
thanks
derty2
post Apr 18 2012, 11:38
Yes it is possible to manage this information from within foobar2000.
Firstly, I would like to state that I am using Columns UI alternative user interface ("CUI"), and this allows me to create a custom column with conditional string colors,
i.e. if path is below 255 characters in length then display the string using normal color, if string exceeds 255 characters display the string in bright red.
As you may guess, having the option of coloring strings conditionally is a powerful visual aid, unfortunately the foobar2000 Default User interface ("DUI") does not have such features.
So... this is how to do it :
Create a custom column in your Playlist Viewer,
         and give it a name, eg: Path Len.
         and give it dimensions, eg: Width: 59 | Alignment: Centre
         and give it this Display script: $len(%path%)
Restart foobar2000 (to permanently set this new configuration).
Search your entire Media Library and create a custom playlist,
         @ foobar2000 toolbar -> Library -> Search
         @ Media Library Search window -> enter this query: ALL SORT DESCENDING BY "$len(%path%)"
         wait for list to fully populate...
         click button [...] -> Create Playlist
         close Media Library Search window
You now have a Playlist of your entire Media Library sorted by Path Length, descending with highest number at the top of the list (as can be seen in your Path Len. column).
Happy editing.
P.S. --- was there a need to quote my whole previous post !!!???
swayzak
post Apr 18 2012, 13:34
Many thanks
However this sorts by path length (rather than file length) doesn't it ?
Therefore by this method I may miss some overlong file names as their actual path length may disguise the true filename size ?
This post has been edited by Frank Bicking: Apr 18 2012, 13:43
Reason for edit: Removed yet another fullquote.
Closed TopicStart new topic
RSS Lo-Fi Version Time is now: 3rd May 2015 - 17:47
