Rockbox 3.11.2 released, New stable release of opensource firmware replacement for various PMPs
saratoga
post Apr 12 2012, 20:47
Version 3.11.2 of the open source digital audio player software Rockbox has been released.
See full release notes: 3.11 / 3.11.2
Some new things since version 3.10:
  • The Sansa c200v2 series and MPIO HD300 are now stable
  • Allow customisation of the main menu (see Advanced Topics section of the manual)
  • USB enabled on Sansa Clip+, Clip V2, and Fuze V2
  • Sansa Clip players can now return to WPS using the Home key
  • iPod hardware clicker
  • Implemented GUI boost (timed out CPU boost during scroll activity) for a more responsive GUI.
  • List icons and theme images can now have alpha information embedded
  • Add support for down-mixing multichannel FLAC files
  • A large number of bug fixes
This post has been edited by db1989: Apr 12 2012, 21:51
Reason for edit: moving release-note links so they appear on Portal, adding first two links, additions to titles
m45t3r
post Apr 13 2012, 04:32
Finally USB is supported on Sansa Clip+. Now my Clip+ is complete smile.gif .
Kohlrabi
post Apr 13 2012, 08:50
I cannot get USB mode to work on my Clip+. Win7 tries to install a device driver (USB Mass Storage Device) upon connection, but fails. The device does not get mounted at all.
EDIT: I suck, I had to disconnect and reconnect it, the second time it worked.
This post has been edited by Kohlrabi: Apr 13 2012, 09:05
Yaztromo
post Apr 13 2012, 09:58
QUOTE (m45t3r @ Apr 13 2012, 03:32) *
USB mode is working for me. However this presents a new problem, since I like to leave the clip+ plugged into my computer at work while it plays. Now a picture of usb connector displays and the device is unusable other than for transferring files.
Think I'm going to have to construct a usb cable with the data pins removed.
Cynic
post Apr 13 2012, 12:52
I think that if you get a cheap USB to power socket adaptor you can connect it to a wall plug instead of the PC and use it as you intend. I've not tried this since USB support was added, but I assume that functionality remains unchanged.
marc2003
post Apr 13 2012, 14:20
QUOTE (http://download.rockbox.org/daily/manual/rockbox-sansaclipplus/rockbox-buildch3.html)
3.3 USB Charging
To charge your player over USB, hold any button while plugging it in. This will prevent it from connecting to your computer and let you continue to use it normally. Your player must already be in Rockbox for this to function.
Note: Be aware that this button may still perform its normal function, so it is recommended to use a button without harmful side effects, such as Select.
also, as you won't need to boot into the original firmware anymore, i'd delete all it's files/folders ('m left with just .rockbox and MUSIC when i'm done). this gives ~180MB in space which is a good 3-4 albums to me. that obviously can differ depending on what encoding you use.
This post has been edited by marc2003: Apr 13 2012, 14:23
Yaztromo
post Apr 13 2012, 14:24
Could you see any reason that you might need the old firmware? Say if rockbox gets bricked somehow, it might be useful to hang on to.
This post has been edited by Yaztromo: Apr 13 2012, 14:28
marc2003
post Apr 13 2012, 15:22
the original firmware isn't part of those files so you can still reboot into it at anytime (hold left when powering up).
besides, you can't brick rockbox now. the only risky part is the flashing of the firmware.
AlanSE
post Feb 13 2013, 03:08
I experienced the same thing! I unplugged it, and the USB image was still displayed. Then I plugged the cable back in just like that. It then recognized. That was strange, but I just wanted to make an account and let you know that I had the same experience and that your post fixed it.
RSS Lo-Fi Version Time is now: 22nd May 2015 - 12:53
