Attenuator between pre- and power amplifier?, Moved from General Audio
AudioKitten
post Apr 11 2012, 06:19
My receiver sounds beautiful but has far too much gain for my relatively efficient speakers. This causes me to listen to all of my music within the first 10-15% of the volume pot (20% if I'm blasting it). Because my potentiometer has rather apparent channel balance problems below 5% that don't fully go away until 10% or so I'm considering some way of lowering the amplifier's gain.
My question is this: Is there any real pitfalls to adding an attenuator between the preamp out and poweramp input in my receiver? I'm thinking anywhere -15dB up to -20dB fixed. My other options are to perform surgery and maybe replace a resistor or two or possibly replace the pot for one that has better tracking. Replacing the pot was my first plan but the replacement pots for my amplifier cost 70 bucks a piece and there's no guarantee the replacement will track appreciably better. My understanding is that at <5% pretty much all pots have tracking problems.
So... should I go ahead and add a fixed level attenuator between my pre- and power- stages or should I refrain and what are the problems that I should be looking out for?
DVDdoug
post Apr 11 2012, 19:24
Parts Express has these attenuators in 1, 3, and 6dB for about $5 USD each., or these in 3, 6, and 12dB, sold in pairs for $26 USD.
I have some of the cheaper ones, and one bad thing is that they are not marked with the attenuation.
AudioKitten
post Apr 11 2012, 20:08
QUOTE (DVDdoug @ Apr 11 2012, 11:24) *
Some quotes from the amazon reviews of those Parts Express attenuators:
These are of poor design. The ground connection is not carried directly through and that can cause hum and static if the two pieces of equipment are not well grounded to each other by other means. I have done audio engineering for many years. I bought 4 of these and then put them in the trash after testing. The internal attenuators are of "balanced" design but are installed in these unbalanced units, this can cause the mentioned problems.
I should have listened to the one other review -- I bought two of these and one was dead on arrival. Take your business elsewhere, this part is worthless.
I don't like the Harrison Labs attenuators because they're too long and because Harrison Labs links to some pretty extreme right-wing religious literature which, as a queer person, makes me very much not want to do business with them. I was, however, looking at these attenuating cables that I could have custom built for the same price as the Harrison plugs.
I'm pretty sure they can't beat what I can do with some resistors and electrical tape for a third of the cost but I'm considering them just for the fit-and-finish. They are pi network attenuators though, which according to other people in this thread aren't generally used in audio circuits and aren't necessary. I think this builder uses them just so that they don't care which way they're plugged in, which is nice.
My question: Is there any reason *not* to use a pi network attenuator for this purpose?
- AudioKitten   Attenuator between pre- and power amplifier?   Apr 11 2012, 06:19
- - woody_woodward   Friend, if you can solve your problem with a coupl...   Apr 11 2012, 08:14
|- - AudioKitten   QUOTE (woody_woodward @ Apr 11 2012, 00:1...   Apr 11 2012, 09:56
|- - stephan_g   QUOTE (woody_woodward @ Apr 11 2012, 08:1...   Apr 11 2012, 17:21
- - Glenn Gundlach   Well an attenuator is certainly an inexpensive exp...   Apr 11 2012, 08:35
|- - AudioKitten   I don't quite understand. I was under the impr...   Apr 11 2012, 09:46
|- - soulsearchingsun   QUOTE (AudioKitten @ Apr 11 2012, 09:46) ...   Apr 11 2012, 13:35
|- - Glenn Gundlach   QUOTE (AudioKitten @ Apr 11 2012, 00:46) ...   Apr 11 2012, 20:56
- - DVDdoug   Parts Express has these attenuators in 1, 3, and 6...   Apr 11 2012, 19:24
|- - AudioKitten   QUOTE (DVDdoug @ Apr 11 2012, 11:24) Part...   Apr 11 2012, 20:08
- - pdq   If you don't mind minor modification to your a...   Apr 11 2012, 19:35
|- - AudioKitten   Volume control dependent input impedance seems lik...   Apr 11 2012, 19:49
- - pdq   That sounds like the pots have one or more taps, w...   Apr 11 2012, 20:00
|- - AudioKitten   QUOTE (pdq @ Apr 11 2012, 12:00) That sou...   Apr 11 2012, 20:11
- - pdq   Are the channels balanced at low volume with/witho...   Apr 11 2012, 20:36
|- - AudioKitten   QUOTE (pdq @ Apr 11 2012, 12:36) Are the ...   Apr 11 2012, 21:07
- - pdq   Well, the simplest fix would be if one switch cont...   Apr 11 2012, 21:19
- - AudioKitten   QUOTE (pdq @ Apr 11 2012, 13:19) Well, th...   Apr 11 2012, 21:28
RSS Lo-Fi Version Time is now: 6th March 2015 - 12:31
