Gapless playback with a Linux DLNA server, was: "software to create cue files"
Richard Kimber
post Apr 10 2012, 15:25
Virtually all the music I buy now comes in the form of downloaded flac files. These have no cue sheets with them.
Some of the music needs to be played gaplessly, and I'm under the impression that flac files + cue sheets is a solution to this. If this is so, can anyone recommend a linux program that would enable me to generate cue sheets from the flac files on my hard disk? I have seen software that creates cue files from music on a CD, but I can't find anything that does it from a folder of flac files on the hard disk.
db1989
post Apr 14 2012, 16:53
What does that have to do with it? You made a claim, so you provide evidence for it. How is anyone else relevant? If this is your attempt to dodge a valid challenge to your unsubstantiated and, frankly, very unlikely claim, then itís a terrible effort. Abide by the rules to which you agreed during registration in your posts, or donít make them.
Richard Kimber
post Apr 14 2012, 18:54
QUOTE (db1989 @ Apr 14 2012, 16:53) *
I just want to see what's passed the test.
What's wrong with that? It's all supposed to be public, and publicly verifiable isn't it?
db1989
post Apr 14 2012, 22:52
QUOTE (Richard Kimber @ Apr 14 2012, 18:54) *
I read your post as being more about dodging the obligation that you provide evidence for your specific case. Of course thereís nothing wrong with what youíre saying here, and I hope you find the material interesting. I apologise if I seemed hostile. However, the main point raised by greynol and myself still stands, as well as the recently mentioned possibility that you were comparing apples to oranges.
Richard Kimber
post Apr 15 2012, 13:25
QUOTE (db1989 @ Apr 14 2012, 22:52) *
That's OK. And I accept your main point, in principle. In practice it's very hard to know how to go about devising a good test that would be acceptable to people. I doubt if I could persuade my wife to sit and listen to the same piece of music over and over again, and my friends would not be inclined to do so either, so any test I could do would involve just me. If I can learn how to do streaming from the linux command line I could easily write an abx test program. Maybe I'll have a go, but I only have copyrighted music so I couldn't publish the files.
julf
post Apr 15 2012, 14:17
QUOTE (Richard Kimber @ Apr 15 2012, 14:25) *
In what way/why do you need to *stream* from the command line (as opposed to just playing a file with mpg123 or something)?
Richard Kimber
post Apr 15 2012, 23:11
QUOTE (julf @ Apr 15 2012, 14:17) *
Well that way I know that the PC is not doing anything to the music.
julf
post Apr 16 2012, 06:42
QUOTE (Richard Kimber @ Apr 16 2012, 00:11) *
Could you remind me - what does your playback chain look like?
Nessuno
post Apr 16 2012, 08:38
QUOTE (julf @ Apr 16 2012, 07:42) *
Let's try to summarize: the OP asked for a solution to gapless stream under Linux.
We proposed a possible solution, whose feasibility is jet to be verified, using Airplay.
He didn't find it suitable for his needs because, according to him: A) Airplay is limited to 16/44.1 and B) he can hear differencies between two tracks at 16/44.1 and at 24/96.
Regarding A: no evidence has been found that Airplay as a protocol has such a limitation. Being only a transport layer, very likely this characteristic is left to be defined by the specific implementation. The OP has to try if and how it works for him. That's all about the gapless and streaming issues.
Regarding B: as far as we know, there is not in the world a single objective proof that a human ear can differentiate between two musical tracks whose only difference is in bitdepth and/or sampling frequency when both are above Redbook standards. This has nothing to do with issue A).
If the OP wants to try for himself, he has to set up an ABX test, doing it as simple as possible and so not complicating it with streaming issues: if he states B) this means at least that he already has the possibility to listen to 24/96 materials natively with his hardware. Because he is running Linux, a possible way to setup a simple and fast ABX test is to use aplay and a few bash lines: as far as I know, ALSA can be configured to be bitperfect and aplay can pipe a bitstream (for example the output of a flac CLI executable) directly to the sound hardware.
... I live by long distance.
- Richard Kimber   Gapless playback with a Linux DLNA server   Apr 10 2012, 15:25
- - Porcus   QUOTE (Richard Kimber @ Apr 10 2012, 16:2...   Apr 10 2012, 16:03
- - Dario   As far as I know, lossless formats are inherently ...   Apr 10 2012, 16:05
- - trout   FLAC, as most any lossless format, should playback...   Apr 10 2012, 16:12
- - greynol   Gapless playback is not a requirement of proper de...   Apr 10 2012, 16:27
|- - Richard Kimber   QUOTE (greynol @ Apr 10 2012, 16:27) Gapl...   Apr 10 2012, 18:00
||- - benski   QUOTE (Richard Kimber @ Apr 10 2012, 13:0...   Apr 10 2012, 18:15
|- - JimH   QUOTE (greynol @ Apr 10 2012, 10:27) Gapl...   Apr 11 2012, 15:23
|- - Richard Kimber   QUOTE (JimH @ Apr 11 2012, 15:23) When yo...   Apr 11 2012, 16:19
- - Richard Kimber   QUOTE (trout @ Apr 10 2012, 16:12) FLAC, ...   Apr 10 2012, 17:42
|- - trout   QUOTE (Richard Kimber) Some googling suggested tha...   Apr 10 2012, 18:05
|- - Richard Kimber   QUOTE (trout @ Apr 10 2012, 18:05) Maybe,...   Apr 10 2012, 18:53
- - JimH   I did a search for "gapless DLNA" and fo...   Apr 11 2012, 15:30
|- - Richard Kimber   QUOTE (JimH @ Apr 11 2012, 15:30) I did a...   Apr 11 2012, 16:13
- - Wombat   I have a network player myself and read some revie...   Apr 11 2012, 16:29
|- - Richard Kimber   QUOTE (Wombat @ Apr 11 2012, 16:29) I hav...   Apr 11 2012, 16:47
|- - Nessuno   QUOTE (Wombat @ Apr 11 2012, 17:29) canīt...   Apr 11 2012, 19:08
- - Wombat   Ops, you responded while i was editing my last ans...   Apr 11 2012, 16:50
|- - Richard Kimber   QUOTE (Wombat @ Apr 11 2012, 16:50) Ops, ...   Apr 11 2012, 16:57
|- - JimH   QUOTE (Richard Kimber @ Apr 11 2012, 10:5...   Apr 11 2012, 17:14
|- - Richard Kimber   QUOTE (JimH @ Apr 11 2012, 17:14) There...   Apr 12 2012, 13:41
|- - soulsearchingsun   QUOTE (Richard Kimber @ Apr 12 2012, 13:4...   Apr 12 2012, 14:22
- - JimH   Here's a thread on the N-50 at computeraudioph...   Apr 11 2012, 17:19
- - Wombat   I only repeated what i read on that review that cl...   Apr 11 2012, 19:32
|- - Nessuno   QUOTE (Wombat @ Apr 11 2012, 20:32) I onl...   Apr 12 2012, 07:59
|- - Richard Kimber   QUOTE (Nessuno @ Apr 12 2012, 07:59) I ma...   Apr 12 2012, 14:29
|- - Nessuno   QUOTE (Richard Kimber @ Apr 12 2012, 15:2...   Apr 12 2012, 17:11
|- - Richard Kimber   QUOTE (Nessuno @ Apr 12 2012, 17:11) By t...   Apr 13 2012, 15:23
|- - Nessuno   QUOTE (Richard Kimber @ Apr 13 2012, 16:2...   Apr 13 2012, 19:25
|- - Richard Kimber   QUOTE (Nessuno @ Apr 13 2012, 19:25) QUOT...   Apr 14 2012, 12:26
|- - Nessuno   QUOTE (Richard Kimber @ Apr 14 2012, 13:2...   Apr 14 2012, 14:29
|- - Richard Kimber   QUOTE (Nessuno @ Apr 14 2012, 14:29) The ...   Apr 14 2012, 15:42
- - Wombat   When i read the thread at CA that jimH linked to i...   Apr 12 2012, 13:54
- - greynol   It's a shame that you seem to be held up by th...   Apr 13 2012, 15:47
|- - Richard Kimber   QUOTE (greynol @ Apr 13 2012, 15:47) It...   Apr 14 2012, 11:52
|- - Richard Kimber   QUOTE (greynol @ Apr 13 2012, 15:47) It...   Apr 14 2012, 13:10
||- - JimH   QUOTE (Richard Kimber @ Apr 14 2012, 07:1...   Apr 14 2012, 14:24
||- - greynol   QUOTE (JimH @ Apr 14 2012, 06:24) I agree...   Apr 14 2012, 16:37
||- - Richard Kimber   QUOTE (greynol @ Apr 14 2012, 16:37) QUOT...   Apr 14 2012, 16:48
|- - Light-Fire   QUOTE (Richard Kimber @ Apr 14 2012, 06:5...   Apr 14 2012, 17:13
|- - Nessuno   QUOTE (Light-Fire @ Apr 14 2012, 18...   Apr 14 2012, 18:08
- - db1989   What does that have to do with it? You made a clai...   Apr 14 2012, 16:53
|- - Richard Kimber   QUOTE (db1989 @ Apr 14 2012, 16:53) What ...   Apr 14 2012, 18:54
|- - db1989   QUOTE (Richard Kimber @ Apr 14 2012, 18:5...   Apr 14 2012, 22:52
|- - Richard Kimber   QUOTE (db1989 @ Apr 14 2012, 22:52) QUOTE...   Apr 15 2012, 13:25
|- - Nessuno   QUOTE (Richard Kimber @ Apr 15 2012, 14:2...   Apr 15 2012, 14:17
|- - julf   QUOTE (Richard Kimber @ Apr 15 2012, 14:2...   Apr 15 2012, 14:17
|- - Richard Kimber   QUOTE (julf @ Apr 15 2012, 14:17) QUOTE (...   Apr 15 2012, 23:11
|- - julf   QUOTE (Richard Kimber @ Apr 16 2012, 00:1...   Apr 16 2012, 06:42
|- - Nessuno   QUOTE (julf @ Apr 16 2012, 07:42) QUOTE (...   Apr 16 2012, 08:38
||- - Richard Kimber   QUOTE (nessuno)Regarding A: no evidence has been f...   Apr 16 2012, 13:11
|- - Richard Kimber   QUOTE (julf @ Apr 16 2012, 06:42) QUOTE (...   Apr 16 2012, 13:29
|- - julf   QUOTE (Richard Kimber @ Apr 16 2012, 14:2...   Apr 16 2012, 16:18
- - greynol   It's possible that two downloaded versions of ...   Apr 14 2012, 18:17
- - greynol   Feel free to search the forum for ABX logs generat...   Apr 14 2012, 19:00
|- - Richard Kimber   QUOTE (greynol @ Apr 14 2012, 19:00) Feel...   Apr 14 2012, 21:09
|- - julf   QUOTE (Richard Kimber @ Apr 14 2012, 22:0...   Apr 15 2012, 10:51
|- - Nessuno   QUOTE (julf @ Apr 15 2012, 11:51) I guess...   Apr 15 2012, 11:47
||- - julf   QUOTE (Nessuno @ Apr 15 2012, 12:47) So, ...   Apr 15 2012, 12:10
|- - Richard Kimber   QUOTE (julf @ Apr 15 2012, 10:51) QUOTE (...   Apr 15 2012, 13:47
|- - julf   QUOTE (Richard Kimber @ Apr 15 2012, 14:4...   Apr 15 2012, 14:22
- - greynol   http://www.hydrogenaudio.org/forums/index....lite=...   Apr 14 2012, 21:49
- - Roseval   Gapless First of all the audio format must support...   Apr 14 2012, 21:50
- - smok3   to the original question: I find it amazing that n...   Apr 15 2012, 12:06
- - greynol   http://www.hydrogenaudio.org/forums/index....showt...   Apr 15 2012, 17:30
- - db1989   That just seems paranoid to me. What kind of inte...   Apr 16 2012, 06:07
|- - Richard Kimber   QUOTE (db1989 @ Apr 16 2012, 06:07) That ...   Apr 16 2012, 12:31
|- - phofman   QUOTE (Richard Kimber @ Apr 16 2012, 12:3...   Apr 16 2012, 19:13
- - greynol   That was my initial impression as well. However, i...   Apr 16 2012, 06:17
- - greynol   ...well, no, that was not ok.   Apr 16 2012, 16:34
- - Wolwgang   QUOTE (Richard Kimber @ Apr 10 2012, 15:2...   May 17 2012, 20:40
RSS Lo-Fi Version Time is now: 2nd June 2015 - 06:01
