wrong/failed playback of mp3 on CD/mp3 players
crazyman
post Apr 9 2012, 22:43
Hi All,
I quite often meet, both on my car audio/microtower (pretty good, Onkyo) with mp3īs (on burnt CDīs) - some whole albums, songs or their parts are playbacked with long pauses, some songs or even whole albums are skipped. Does it depend on the chip which likely cannot read them? All these mp3īs can be easily played on computer both from CD/HD. I tried to eliminate all possible sources of this behavior - have good quality CDīs, burn with max. speed 10x (Ashampoo), tags are only ID3v1+2.3. Recently I noticed, that files with CBR 320 + (I did not even know-EncSpot shows CBR up to 390-isnīt that an artifact?), and none of these songs is read, the whole album just skips song by song with 0 sec of any sound. Does the proper function or ability to playback all "good" mp3īs depend also on the type of encoder, VBR/CBR or how high CBR/VBR is?
Any thoughts?
Thx.
crazyman
This post has been edited by crazyman: Apr 9 2012, 22:45
lvqcl
post Apr 9 2012, 23:03
Very big embedded picture (album art) can cause this.
This post has been edited by lvqcl: Apr 9 2012, 23:04
Porcus
post Apr 10 2012, 00:17
Unicode filenames? Incompatible ID3 tag version?
Tried to make a test CD where you remove all tags?
mjb2006
post Apr 10 2012, 00:58
I had a car stereo that wouldn't play untagged MP3s...
crazyman
post Apr 11 2012, 13:55
QUOTE (lvqcl @ Apr 9 2012, 15:03) *
I know, I have deleted all text/picture files, but did not help. The new installed player in a car of my colleague can playback all files I have experienced in my older radioplayers with no problems.
crazyman
post Apr 11 2012, 14:00
QUOTE (Porcus @ Apr 9 2012, 16:17) *
All names without any special characters. I use always tags id3v1 and id3v2.3, so why should some cause problems and most not? Anyway, i will try remove all tags...
Porcus
post Apr 11 2012, 14:17
... does it object to VBR files only?
crazyman
post Apr 11 2012, 15:10
QUOTE (Porcus @ Apr 11 2012, 06:17) *
No, also CBR 320.
pdq
post Apr 11 2012, 15:50
Some years ago there were mp3 players that could not handle 320 kbit frames (buffer size problem I think). Some versions of LAME have also generated frames that required a larger buffer than some decoders could handle. If you have the lossless source for these files, try encoding again and adding the -B 256 switch for vbr files, or encode as cbr 256.
db1989
post Apr 11 2012, 16:23
Could disabling the bit-reservoir be another potential workaround?
And if the player can handle 320 kbps frames but chokes on ones made larger by bits carried over from others, this would enable higher quality than permitted by an upper limit of 256 kbps (not that I expect it to be audible, etc. tongue.gif).
crazyman
post Apr 20 2012, 13:40
You were correct, after removing them it is OK. Thx.
RSS Lo-Fi Version Time is now: 28th January 2015 - 11:34
