Directsound vs WASAPI vs ASIO
Midiman
post Apr 8 2012, 05:10
After reading many of the posts on this forum, it appears that there is no evidence that ASIO or WASAPI sounds any better than Directsound on Windows 7. I understand the importance of ABX testing - and I am interested in a way to do a double blind test of such claims. Let me first of all state that I cannot hear any difference. For me to be objective, I have used the same player for all tests - foobar2000 - and simply changed the Output from Directsound to WASAPI to ASIO. However, to do this, I have to stop the playback, change the driver, and then restart playback. This means comparions are doubtful at best due to the delay involved and my knowledge of what driver I selected.
How have others conducted such tests? Please note I am not trying to prove a difference exists - just to find a way to do the test properly. The ABX plugin for foobar2000 has been very useful to compare different WAV files. Obviously, one cannot use it for this sort of experiment.
Thank you for any suggestions or pointers to where this has been proved one way or another.
[JAZ]
post Oct 8 2012, 22:55
@item: The possibility to have an unaltered, bit-for-bit output with either of those three methods exists, and in such case, neither ABX, nor guesswork and supppositions play any role.
In the event that they aren't bit-perfect, the election of one over another is most of the times about performance/usability than about quality. (Expecting very low latency, wanting to play multiple streams at the same time, sampling rates and bit depths supported, etc..).
There are only two scenarios worth mentioning about Directsound or MME failing:
The old "AC97"-compatible hardware/drivers that used to resample with low quality 44.1Khz signals to 48Khz, and the newer "MME waveout recording resampling with low quality, even when unneeded" in Vista and 7 (which was patched some time ago).
That's as much about quality that any Windows user should care when using the different audio APIs (Other than when requiring bit-for-bit signals)
item
post Oct 8 2012, 23:10
QUOTE ([JAZ] @ Oct 8 2012, 22:55) *
The possibility exists that DS can be bit-perfect, but it's less likely. It is likely that if there is a positive difference, it will be on the side of ASIO / WASAPI.
As I said, whether there will be a practical difference in every - indeed any - system depends on many factors that are hard to rule in or out.
This post has been edited by item: Oct 8 2012, 23:12
- Midiman   Directsound vs WASAPI vs ASIO   Apr 8 2012, 05:10
- - nimd4   http://www.hydrogenaudio.org/forums/index....showt...   Apr 8 2012, 05:23
|- - Midiman   QUOTE (nimd4 @ Apr 8 2012, 14:23) http://...   Apr 8 2012, 05:59
|- - Nessuno   QUOTE (Midiman @ Apr 8 2012, 06:59) The p...   Apr 8 2012, 09:02
- - saratoga   QUOTE (Midiman @ Apr 8 2012, 00:10) How h...   Apr 8 2012, 08:03
|- - Roseval   There must be a mathematical difference. WASAPI in...   Nov 15 2014, 10:55
- - Roseval   The difference between ASIO/WASAPI and DS is that ...   Apr 8 2012, 10:58
- - nimd4   Midiman I get what you're saying, sorz 4 being...   Apr 8 2012, 19:23
|- - greynol   QUOTE (nimd4 @ Apr 8 2012, 11:23) For rec...   Apr 8 2012, 23:42
- - krabapple   If the stream is resampled and is no longer bit-pe...   Apr 9 2012, 06:11
- - item   ASIO, WASAPI and DS are different things. Which me...   Oct 8 2012, 19:29
- - [JAZ]   @item: The possibility to have an unaltered, bit-f...   Oct 8 2012, 22:55
|- - item   QUOTE ([JAZ] @ Oct 8 2012, 22:55)...   Oct 8 2012, 23:10
- - AiZ   [Not that fun mode on] For me, ASIO is vastly sup...   Oct 8 2012, 23:10
- - devhead   I have a Asus Xonar Essence STX sound card, and I ...   May 6 2014, 19:42
- - db1989   Prove it with double-blind testing as mandated by ...   May 6 2014, 19:51
|- - tweety61   QUOTE (db1989 @ May 6 2014, 19:51) Prove ...   Sep 10 2014, 21:50
|- - mephiska   QUOTE (tweety61 @ Sep 10 2014, 12:50) QUO...   Nov 15 2014, 03:18
|- - Arnold B. Krueger   QUOTE (tweety61 @ Sep 10 2014, 15:50) QUO...   Nov 15 2014, 18:29
- - [JAZ]   @devhead: First, Welcome to hydrogenadio. Hydrog...   May 6 2014, 19:53
|- - Porcus   QUOTE ([JAZ] @ May 6 2014, 20:53)...   May 7 2014, 11:29
- - greynol   Have a go at this one Arny, and he might give you ...   Nov 15 2014, 18:49
- - Chibisteven   I use WASAPI for it's exclusive mode. Take a ...   Nov 19 2014, 00:04
|- - Fairy   QUOTE (Chibisteven @ Nov 19 2014, 00:04) ...   Nov 28 2014, 15:46
- - BrunoMB2B   Hello Guys! I'm a DJ and producer from sou...   Aug 17 2015, 07:59
- - bennetng   Here is an explanation with audio samples: http://...   Aug 17 2015, 09:59
- - Merovingian   I came across this article a few years ago. It doe...   Aug 17 2015, 12:46
RSS Lo-Fi Version Time is now: 5th September 2015 - 18:10
