sound quality with drivers
chronek
post Apr 1 2012, 14:26
Hello,
I am using window7 + creative sb x-fi hd usb + some sennheiser headphones and lately found that after install driver 1.2.21 over original 1.2.20 my sound got worsen (I usually playing flac files with foobar + sox resampler plugin + asio). After reinstall driver sound got back better quality.
I just wondering, i always do resample sound to highest profile what my card can play (24bit/96kHz) for bypass windows/driver resampling, and using even asio for bypass that but looks like that driver have own resampler and filters and even if i try best - driver can corrupt sound.
Know anyone a way to bypass driver and play original sound as much as possible?
Mike
This post has been edited by chronek: Apr 1 2012, 14:27
xnor
post Apr 1 2012, 16:04
Sound got worse how exactly (TOS #8)? What asio driver, the asio4all "wrapper"?
If you want to play the "original sound" then why do you resample everything?
The soundcard driver cannot be bypassed if you want it to play sound.
This post has been edited by xnor: Apr 1 2012, 16:05
Sighted evaluation without blind testing is blind.
JimH
post Apr 1 2012, 22:17
QUOTE (xnor @ Apr 1 2012, 10:04) *
If the device has an ASIO driver, use that. If not, WASAPI is good. Kernel Streaming next.
ASIO4All is a wrapper for Kernel Streaming.
Upsampling is harmless.
db1989
post Apr 2 2012, 00:08
Donít misinterpret the above post to refer to quality. These modes are designed not for any effect upon the output audio but rather to achieve unrelated goals such as exclusive access to hardware, reduced latency, etc.
Nessuno
post Apr 2 2012, 08:13
QUOTE (db1989 @ Apr 2 2012, 01:08) *
Which nevertheless (and correct me if I'm wrong), under certain conditions (e. g. many concurrent sound clients, heavy average system load etc...), might have perceivable effects on output sound quality.
... I live by long distance.
phofman
post Apr 2 2012, 09:20
I am correct that X-Fi, unlike most other cards, employs extensive DSP in hardware? At least the older Audigy cards did so. In such case I can imagine an updated firmware, a part of the driver upgrade, causing different sound.
Nessuno
post Apr 2 2012, 10:06
QUOTE (phofman @ Apr 2 2012, 10:20) *
Already tried to downgrade the driver and verify the effect on sound?
By the way: you haven't jet detailed this difference in sound. We can't try to help you if we actually don't know anything about it.
In doing this, please follow the guidance of Hydrogenaudio TOS, especially point #8.
db1989
post Apr 2 2012, 10:49
QUOTE (phofman @ Apr 2 2012, 09:20) *
It should do so only if the user has X-Fi processing enabled.
Yes, perhaps. So, chronek should check this.
Which brings us back to:
QUOTE (chronek @ Apr 1 2012, 14:26) *
If this is your goal, you’ll want to have X-Fi off; that’s for sure.
This post has been edited by db1989: Apr 2 2012, 11:11
slks
post Apr 3 2012, 09:36
Indeed, one of the selling points of the X-Fi line are their DSP capabilities - I've never used one, but given the marketing, I'd say there's a high chance that some of the sound processing features could be turned on by default. Upgrading your drivers could have caused some of the settings to be changed, that is - turned on or turned off, compared to what they were before. There should be an option to change all these things in Creative's settings somewhere. These are things like "concert hall" reverb presets etc., although they're probably called something fancier for the X-Fi line. For the highest level of fidelity to the source material, you'll want to turn all such DSPs off.
You could also try going to Creative's site and see if there's a changelog or bug reports or something for the new drivers. It depends on how good their documentation is, but I should think any large changes to the drivers that influence sound quality is noted somewhere.
My money is on there being a setting misconfigured, though. Probably something to do with either the DSP stuff or maybe resampling. Unfortunately I haven't used a Creative card in years and can't tell you where to access these settings... but I'd advise looking over them very carefully. The eye-candy GUI bloat on some of these manufacturer tools can make it difficult to tell what the settings actually are and what can be changed. (Controls designed to look like analog knobs, switches, and indicators, for example... yuck)
This post has been edited by slks: Apr 3 2012, 09:37
What I do with all the audio tech? This: http://last.fm/user/sls
RSS Lo-Fi Version Time is now: 4th May 2015 - 15:30
