2 Pages V  < 1 2
Quicktime pro resampler quality?
Mix3dmessagez
post Apr 12 2012, 21:55
Post #26
QUOTE (nu774 @ Apr 12 2012, 04:45) *
Well, it's interesting. Quickly tried now QT pro 7.7.1 for Win with a few configuration parameters, and I also couldn't get identical result between QT pro and qaac. Same for CVBR.
On the other hand, I could confirm iTunes plus is still bit-identical with qaac --cvbr 256 -q2, and iTunes custom (CVBR) is identical with qaac --cvbr -q1;
qaac is now built directly upon CoreAudioToolbox, and is not using QuickTime API.
QT pro might be doing something different... I don't know for sure.
Hey, thanks for your response, I think I will just convert to alac and downsample using coreaudio now.One question though, on http://src.infinitewave.ca/ which core audio is present in the windows version?I see leopord and tiger, but I believe those are the mac versions.
nu774
post Apr 13 2012, 02:31
Post #27
QUOTE (Mix3dmessagez @ Apr 13 2012, 05:55) *
My personal recommendation is just to use SoX. It's good enough and still very efficient (fast). You can run sox resampler from foobar2000 DSP, too.
I implemented --native-resampler on qaac to tweek around with CoreAudio SRC not because I want/recommend people to use it seriously.
Apparently CoreAudio has been updated after Leopard release. Leopard is two generation behind from the newest (Lion). However, I don't know if SRC has been updated. I'm not a Mac user anyway.
I just quickly tested with sweep wave conversion; From what I can see, --bats,127 gives me something looks similar with Leopard version on the site. However, I don't know if it is exactly the same.
This post has been edited by nu774: Apr 13 2012, 02:32
Mix3dmessagez
post Apr 13 2012, 02:50
Post #28
QUOTE (nu774 @ Apr 12 2012, 21:31) *
Do you think it would be worth re-encoding all my needledrops to sox then and delete all the quicktime downsampled ones?
What I find puzzling is the fact that you say leopard two generations behind lion, but lion performs notably worse on the src scales in just about every fashion than leopard.
Also, I have uploaded samples of izotope 64 mbit dithered, original wav, and quicktime and sox comparisons now, so an actual listening test for the public can commence
quicktime
http://www.mediafire.com/?hgjv2mfu8b095w2
sox
http://www.mediafire.com/?xcdj0hj7yawio0g
izotope 64 src/mbit dithered
http://www.mediafire.com/?umnkxd63585rha5
original unsampled wav
http://www.mediafire.com/?pyc2o5ks74jebs2
QAAC bats native resampled
http://www.mediafire.com/?3421h4mz86dm8hi
*note, I forgot to rename some of the files all of them are in .mp4 and some might overwrite one another if saved in same place*
Anybody care to share their results?No serious abxing required, just to see if any differences can be spotted.
nu774
post Apr 13 2012, 04:53
Post #29
QUOTE (Mix3dmessagez @ Apr 13 2012, 10:50) *
No, especially on AAC encoding.
If *you* cannot ABX it, it's worth nothing.
How did you know that? Maybe another source?
Mix3dmessagez
post Apr 13 2012, 05:37
Post #30
QUOTE (nu774 @ Apr 12 2012, 23:53) *
Care to explain what you mean with aac encoding? This is not to sound like a jack a, i just want to know as much as possible about all of this, and music.
on the src website, i compared the two, namely on passband, transition, tiger falls off from the ideal filter for both, while leopord maintains near accuracy.On sweep, it has all this extra stuff that leopard doesn't have *and izotope 64 doesn't either, so I assume it to not be good*
This post has been edited by Mix3dmessagez: Apr 13 2012, 05:41
nu774
post Apr 13 2012, 07:11
Post #31
QUOTE (Mix3dmessagez @ Apr 13 2012, 13:37) *
Sorry for my English if it's unclear; It's not my native tongue and I'm really not good at it.
I just thought you are encoding to AAC and that's all.
Tiger ≠ Lion
Tiger is older than Leopard.
Mix3dmessagez
post Apr 13 2012, 07:23
Post #32
QUOTE (nu774 @ Apr 13 2012, 02:11) *
Tiger ≠ Lion
Your english is extremely clear and correct, there's nothing wrong with it.What i meant was..
Why is not worth deleting and resampling everything if I convert to aac, thats what i was asking
nu774
post Apr 13 2012, 08:07
Post #33
QUOTE (Mix3dmessagez @ Apr 13 2012, 15:23) *
Okay, I was assuming that you won't be able to ABX them, so I said no. If you are encoding with perceptual coder like AAC and you cannot tell the audible difference, the difference is not important.
Of course it's a different story if you can.
Mix3dmessagez
post Apr 13 2012, 09:14
Post #34
QUOTE (nu774 @ Apr 13 2012, 03:07) *
From the samples I've provided could you abx it?I'd just like someone whose more knowledgeable and smarter on this with better ears to scale the differences between them.
Wombat
post Apr 13 2012, 14:06
Post #35
Better ask on some audiophile forum for an abx of resamplers that all work very well, especially when you use some audiophile recommended settings like non-linear phase with sox.
With 24bit audio you can listen to silence much louder
IgorC
post Apr 13 2012, 16:44
Post #36
QUOTE (Mix3dmessagez @ Apr 13 2012, 05:14) *
Both Apple (Leopard) and SoX VHQ have a noise lower than perceptible (-160 ... -170 dB). Anything below -120 dB is inaudible.
And your files have nothing above 20 kHz so it's safe to resample to 44.1 kHz.
P.S. Even if the difference would be ABXable it's still hard to say what is better or worse. It could be just different.
This post has been edited by IgorC: Apr 13 2012, 16:52
http://listening-test.coresv.net/results.htm
2 Pages V  < 1 2
RSS Lo-Fi Version Time is now: 27th February 2015 - 01:02
