Quicktime pro resampler quality?
Mix3dmessagez
post Mar 28 2012, 20:23
I use quicktime to downsample needledrops to 48hz tvbr *for ipod use*
I've also come across foobar sox resampler which I've read is the best
I've tried to do comparisons *downsample with sox to 48000hz then convert with quicktime or convert using quicktime*
Usually the bitrates will be the same *on average* however sometimes sox downsamples will be one bit higher *on average*
I've tried to look at the individual bitrates for the first few seconds of each song *Just to see if there's a conclusive difference* and they seem to handle things quit differently, I notice the bitrate changes faster when downsampled with sox, I know that probably isn't a determinant as to quality, but it's all I know
With sox I use very high, 48000hz, 95% passband, allow aliasing, 25% phase response *someone at another forum said those are best settings*
On quicktime, best quality, variable bit rate, and recommended sample rate
I also want to know as if Sox is better I can resample all needledrops to 48hz flac *from 96 to save space*
- Mix3dmessagez   Quicktime pro resampler quality?   Mar 28 2012, 20:23
- - DVDdoug   QUOTE *someone at another forum said those are bes...   Mar 28 2012, 20:48
- - IgorC   http://src.infinitewave.ca/ has Apple resampler i...   Mar 28 2012, 21:20
- - Mix3dmessagez   QUOTE (DVDdoug @ Mar 28 2012, 15:48) [gia...   Mar 28 2012, 22:27
|- - saratoga   QUOTE (Mix3dmessagez @ Mar 28 2012, 17:27...   Mar 28 2012, 23:19
|- - Mix3dmessagez   But what if the source material is digital and pre...   Mar 28 2012, 23:29
|- - saratoga   To be clear, I'm saying that the process of cr...   Mar 28 2012, 23:31
- - nu774   If you are using MacOS X, you can try afconvert (C...   Mar 29 2012, 05:05
- - SebastianG   I don't know about how well Quicktime does res...   Mar 29 2012, 10:35
- - Wombat   QUOTE (SebastianG @ Mar 29 2012, 10:35) T...   Mar 29 2012, 16:58
- - Wombat   I hope it is of some help. I did some simple examp...   Mar 31 2012, 03:15
- - Mix3dmessagez   QUOTE (nu774 @ Mar 29 2012, 00:05) If you...   Apr 12 2012, 01:40
|- - nu774   If you are interested, now qaac lets you play arou...   Apr 12 2012, 03:26
- - Wombat   If there really someone was interested in listenin...   Apr 12 2012, 02:14
- - Mix3dmessagez   QUOTE (Wombat @ Apr 11 2012, 21:14) If th...   Apr 12 2012, 04:23
|- - nu774   Try something like the following QUOTE -V 127 --na...   Apr 12 2012, 05:08
|- - Mix3dmessagez   Hi, thank you so much!I see you are the creato...   Apr 12 2012, 05:35
|- - nu774   Still getting errors? See what foobar2000 says on ...   Apr 12 2012, 06:41
- - nu774   Ah, I've forgotten one thing: You will need ...   Apr 12 2012, 06:49
|- - Mix3dmessagez   QUOTE (nu774 @ Apr 12 2012, 01:49) Ah, I...   Apr 12 2012, 06:56
|- - nu774   QUOTE (Mix3dmessagez @ Apr 12 2012, 14:56...   Apr 12 2012, 07:25
|- - Mix3dmessagez   thanks, solved my issue!last problem though, I...   Apr 12 2012, 07:39
|- - nu774   QUOTE want quicktime best vbr but in its quicktime...   Apr 12 2012, 08:09
|- - Mix3dmessagez   I'm sorry for being unspecific.I'll try to...   Apr 12 2012, 08:37
|- - nu774   Well, it's interesting. Quickly tried now QT p...   Apr 12 2012, 09:45
|- - Mix3dmessagez   QUOTE (nu774 @ Apr 12 2012, 04:45) Well, ...   Apr 12 2012, 21:55
|- - nu774   QUOTE (Mix3dmessagez @ Apr 13 2012, 05:55...   Apr 13 2012, 02:31
|- - Mix3dmessagez   QUOTE (nu774 @ Apr 12 2012, 21:31) QUOTE ...   Apr 13 2012, 02:50
|- - nu774   QUOTE (Mix3dmessagez @ Apr 13 2012, 10:50...   Apr 13 2012, 04:53
|- - Mix3dmessagez   QUOTE (nu774 @ Apr 12 2012, 23:53) QUOTE ...   Apr 13 2012, 05:37
|- - nu774   QUOTE (Mix3dmessagez @ Apr 13 2012, 13:37...   Apr 13 2012, 07:11
|- - Mix3dmessagez   QUOTE (nu774 @ Apr 13 2012, 02:11) QUOTE ...   Apr 13 2012, 07:23
|- - nu774   QUOTE (Mix3dmessagez @ Apr 13 2012, 15:23...   Apr 13 2012, 08:07
|- - Mix3dmessagez   QUOTE (nu774 @ Apr 13 2012, 03:07) QUOTE ...   Apr 13 2012, 09:14
|- - IgorC   QUOTE (Mix3dmessagez @ Apr 13 2012, 05:14...   Apr 13 2012, 16:44
- - Wombat   Better ask on some audiophile forum for an abx of ...   Apr 13 2012, 14:06
RSS Lo-Fi Version Time is now: 2nd August 2015 - 20:39
