Skeptoid: Digital vs Vinyl, Podcast casts its skeptical eye on digital audio
rick.hughes
post Mar 28 2012, 11:59
Fandango
post Mar 29 2012, 03:38
Didn't he dodge the big question anyway? He said that because the mediums are so different there's no point in ABX'ing them. I doubt he will challenge the theoretical limitations of the vinyl format. He simply claims it's inaudible and not ABX'able anyway, so it doesn't matter. The thing that I'm sceptical about is the first one, sure the effects of vinyl cannot be properly tested with actual vinyl because there are too many giveaways that have nothing to do with the way the format works, crackle, pops and noises feed into from the turntable for instance, but what one could do is simulate the theoretical physical limitations of vinyl records along with the post-production techniques digitally and take such processed samples and compare them to the same source samples treated as if they were produced for a CD. To answer the question he raises right from the start, if the limitations of vinyl alone are even audible, I think is doable, if one can eliminate all interfering factors, from the mics to the mastering and beyond.
Of course the results will hardly be applyable to the real world, because the overall real-world setups of vinyl listening and CD listening and the real-world preparations before each mediums are pressed are as he clearly pointed out too distinct from another.
I mean isn't it unscientific to claim one can do a proper ABX test between vinyl and CD under real-world conditions and say it is likely people can hear a difference because of how vinyl works and not because of all the other factors that also shape the sound that goes in a studio mic and come out a home speaker, them being different for vinyl and CD? Well, I would be very curious if the characteristics of vinyl playback can be simulated as a whole and whether it has been done before, maybe even just for certain aspects of the format.
This post has been edited by Fandango: Mar 29 2012, 03:59
krabapple
post Mar 29 2012, 17:22
QUOTE (Fandango @ Mar 28 2012, 22:38) *
In the real world, an LP doesn't necessarily acquire new crackles and pops and noises between playing it once to record it digitally, and playing it again to compare it to the digital copy. So that is not necessarily a giveaway.
This post has been edited by krabapple: Mar 29 2012, 17:22
mzil
post Mar 29 2012, 22:23
QUOTE (krabapple @ Mar 29 2012, 11:22) *
Although there are other causes for it, audible wow in record playback due to fluctuations in the platter's speed, will occur in random locations for each playback, so one couldn't even fairly ABX an LP to the same LP (a clone with identical pops/ticks) on the same model of turntable! There's a giveaway, at least for music where the wow might be audible. [Sustained piano chords and flute are often used to look for this.]
Synchronizing the two is also a nightmare, or an LP to a CD for that matter. So even if there are indeed no new pops or ticks on a second playing of an LP, the "giveaway" problem still exists.
What I'd do is the Meyer and Moran A/D/A loop trick (where they compared SACD to their CD recorder's quick A/D/A version of it); I would take the output of the LP and digitize it, but then bring it back to analog, almost instantaneously . This gets rid of the "giveaway" problems of subsequent LP playbacks due to all these factors. The wow (including flutter) components and the pops/ticks are the same, plus the two are synchronized.
This post has been edited by mzil: Mar 29 2012, 22:46
knutinh
post Mar 30 2012, 07:36
QUOTE (mzil @ Mar 29 2012, 23:23) *
Or, do a high-resolution digital recording of vinyl, play it back at high-resolution and CD-resolution in an ABX test.
-k
mzil
post Mar 30 2012, 08:33
QUOTE (knutinh @ Mar 30 2012, 01:36) *
-k
That way wouldn't be comparing direct analog LP sound to digital, though; it would be comparing two kinds of digital sound.
greynol
post Mar 30 2012, 15:56
Ignoring CDDA, if you are attempting to suggest that high-res digital is unable to capture vinyl (or the master used to create it either before or after RMAA equalization was applied) 100% transparently, what is your basis for this?
This post has been edited by greynol: Mar 30 2012, 16:03
mzil
post Mar 30 2012, 18:04
QUOTE (greynol @ Mar 30 2012, 09:56) *
Ignoring CDDA, if you are attempting to suggest that high-res digital is unable to capture vinyl (or the master used to create it either before or after RMAA equalization was applied) 100% transparently...
I'm not.
New topic for the general audience: I'm unable to read the original poster's link, because, at least through my browser/settings, when I click on it it brings me to a page that looks like I got the correct article, I think, however there seems to be many, many of the opening paragraphs (over a full page) completely obscured with a large, green table of contents starting with "About Skeptoid". If I click on any of the listings in it I still get this large, obscuring block, preventing me from seeing the actual page underneath. [Later, an invitation widow to subscribe also appears, however that I am easily able to close].
I don't really want to subscribe to skeptoid.com, but is that the only way to read the full article without this superimposed listing of articles? Or could some settings of my popup blocker, cookie blocking, or other settings be what's stopping me? I'm not well versed in how to deal with this sort of problem so any help would be appreciated. I am using Internet Explorer 9, if that matters.
This post has been edited by mzil: Mar 30 2012, 18:10
- rick.hughes   Skeptoid: Digital vs Vinyl   Mar 28 2012, 11:59
- - Fandango   This thread just reminded me that I haven't li...   Mar 28 2012, 21:29
- - Woodinville   Hmm, we shall see how he copes with my comment tha...   Mar 28 2012, 22:45
- - Fandango   Didn't he dodge the big question anyway? He sa...   Mar 29 2012, 03:38
|- - krabapple   QUOTE (Fandango @ Mar 28 2012, 22:38) Did...   Mar 29 2012, 17:22
|- - mzil   QUOTE (krabapple @ Mar 29 2012, 11:22) In...   Mar 29 2012, 22:23
|- - knutinh   QUOTE (mzil @ Mar 29 2012, 23:23) What I...   Mar 30 2012, 07:36
||- - mzil   QUOTE (knutinh @ Mar 30 2012, 01:36) Or, ...   Mar 30 2012, 08:33
||- - greynol   Ignoring CDDA, if you are attempting to suggest th...   Mar 30 2012, 15:56
|||- - mzil   QUOTE (greynol @ Mar 30 2012, 09:56) Igno...   Mar 30 2012, 18:04
|||- - dhromed   QUOTE (mzil @ Mar 30 2012, 18:04) I'm...   Mar 30 2012, 20:13
|||- - greynol   QUOTE (mzil @ Mar 30 2012, 10:04) I'm...   Mar 30 2012, 21:25
||- - Arnold B. Krueger   QUOTE (mzil @ Mar 30 2012, 03:33) QUOTE (...   Apr 3 2012, 14:45
||- - mzil   QUOTE (Arnold B. Krueger @ Apr 3 2012, 08...   Apr 3 2012, 23:32
|- - krabapple   QUOTE (mzil @ Mar 29 2012, 17:23) Althoug...   Mar 31 2012, 22:18
|- - mzil   QUOTE (krabapple @ Mar 31 2012, 16:18) Bu...   Apr 1 2012, 02:22
- - hlloyge   QUOTE (Fandango @ Mar 29 2012, 03:38) I d...   Mar 29 2012, 09:44
|- - Nessuno   QUOTE (hlloyge @ Mar 29 2012, 09:44) QUOT...   Mar 29 2012, 11:26
||- - Arnold B. Krueger   QUOTE (Nessuno @ Mar 29 2012, 06:26) QUOT...   Apr 3 2012, 14:42
|||- - Nessuno   QUOTE (Arnold B. Krueger @ Apr 3 2012, 15...   Apr 3 2012, 17:31
||- - splice   QUOTE (Nessuno @ Mar 29 2012, 03:26) QUOT...   Apr 17 2012, 02:47
|- - Woodinville   QUOTE (hlloyge @ Mar 29 2012, 01:44) QUOT...   Mar 30 2012, 02:01
|- - knutinh   QUOTE (Woodinville @ Mar 30 2012, 03:01) ...   Mar 30 2012, 07:55
|- - splice   QUOTE (knutinh @ Mar 29 2012, 22:55) If I...   Mar 31 2012, 00:38
- - Fandango   Right, besides one could analyze the recording for...   Mar 29 2012, 21:13
|- - Pio2001   QUOTE (Fandango @ Mar 29 2012, 22:13) But...   Sep 15 2012, 16:45
|- - hlloyge   QUOTE (Pio2001 @ Sep 15 2012, 17:45) Last...   Sep 15 2012, 19:09
- - mzil   Dhromed, Thanks! Great respone, but when I wen...   Mar 30 2012, 21:28
- - Woodinville   Just want to point out that the biggest component ...   Mar 31 2012, 23:10
|- - Arnold B. Krueger   QUOTE (Woodinville @ Mar 31 2012, 18:10) ...   Apr 3 2012, 14:50
|- - Nessuno   QUOTE (Woodinville @ Apr 1 2012, 00:10) H...   Apr 5 2012, 07:59
|- - Engelsstaub   QUOTE (Nessuno @ Apr 5 2012, 01:59) ...ev...   Apr 5 2012, 15:04
|- - krabapple   QUOTE (Engelsstaub @ Apr 5 2012, 10:04) I...   Apr 5 2012, 17:55
- - kraut   QUOTE Then there is the FM distortion caused by .....   Apr 3 2012, 17:52
|- - Woodinville   QUOTE (kraut @ Apr 3 2012, 09:52) QUOTE [...   Apr 4 2012, 06:19
|- - stephan_g   QUOTE (kraut @ Apr 3 2012, 17:52) QUOTE T...   Apr 4 2012, 22:36
||- - splice   QUOTE (stephan_g @ Apr 4 2012, 14:36) ......   Apr 5 2012, 01:45
||- - Woodinville   QUOTE (splice @ Apr 4 2012, 17:45) Many n...   Apr 5 2012, 03:53
|- - Arnold B. Krueger   QUOTE (kraut @ Apr 3 2012, 12:52) QUOTE T...   Apr 6 2012, 14:52
- - kraut   QUOTE Perhaps you should actually read up on the r...   Apr 4 2012, 15:59
|- - Woodinville   QUOTE (kraut @ Apr 4 2012, 07:59) QUOTE P...   Apr 5 2012, 03:50
- - kraut   QUOTE [Having said that, playing vinyl twice insid...   Apr 6 2012, 06:28
|- - splice   QUOTE (kraut @ Apr 5 2012, 21:28) QUOTE [...   Apr 6 2012, 07:44
||- - DonP   QUOTE (splice @ Apr 6 2012, 02:44) Lo and...   Apr 6 2012, 14:54
|- - Nessuno   QUOTE (kraut @ Apr 6 2012, 07:28) And if ...   Apr 6 2012, 07:56
- - kraut   QUOTE Where is the proof? Just claims pulled out o...   Apr 6 2012, 07:37
|- - Woodinville   Since I am not going to go buy an expensive, obsol...   Apr 6 2012, 10:42
|- - 2Bdecided   QUOTE (kraut @ Apr 6 2012, 07:37) My expe...   Apr 6 2012, 12:50
- - kraut   I play with a mixture with distilled water and 99%...   Apr 6 2012, 08:12
|- - splice   QUOTE (kraut @ Apr 5 2012, 23:12) I play ...   Apr 6 2012, 12:18
- - greynol   The topic at hand is not about the manner in which...   Apr 6 2012, 08:23
- - krabapple   If you're a masochist there's always this ...   Apr 6 2012, 20:23
- - krabapple   and, btw, the AES e-library is free to search. Re...   Apr 6 2012, 20:49
|- - Arnold B. Krueger   QUOTE (krabapple @ Apr 6 2012, 15:49) and...   Apr 8 2012, 12:54
|- - Woodinville   QUOTE (Arnold B. Krueger @ Apr 8 2012, 04...   Apr 8 2012, 22:00
|- - krabapple   QUOTE (Arnold B. Krueger @ Apr 8 2012, 07...   Apr 9 2012, 06:08
- - kraut   QUOTE To determine the actual deformation-force re...   Apr 7 2012, 00:20
|- - splice   QUOTE To determine the actual deformation-force re...   Apr 7 2012, 02:14
|- - Engelsstaub   QUOTE (splice @ Apr 6 2012, 20:14) ...I r...   Apr 7 2012, 10:37
- - kraut   QUOTE Most of the heat is produced inside the groo...   Apr 7 2012, 03:56
|- - Woodinville   QUOTE (kraut @ Apr 6 2012, 19:56) I have ...   Apr 7 2012, 04:16
||- - kraut   QUOTE (Woodinville @ Apr 6 2012, 20:16) Q...   Apr 7 2012, 06:53
||- - Woodinville   QUOTE (kraut @ Apr 6 2012, 22:53) The sam...   Apr 7 2012, 08:15
|- - splice   QUOTE (kraut @ Apr 6 2012, 19:56) ... Wha...   Apr 7 2012, 10:26
|- - Nessuno   QUOTE (splice @ Apr 7 2012, 11:26) Deteri...   Apr 7 2012, 11:31
|- - Woodinville   QUOTE (Nessuno @ Apr 7 2012, 03:31) QUOTE...   Apr 7 2012, 21:36
- - kraut   Just a last note: I know that my decades long expe...   Apr 7 2012, 07:59
- - splice   I feel a sense of regret that the CD came along wh...   Apr 9 2012, 14:04
- - pdq   @splice: That's an awful lot of conjecture, an...   Apr 9 2012, 16:54
|- - splice   QUOTE (pdq @ Apr 9 2012, 08:54) @splice: ...   Apr 9 2012, 22:03
|- - knutinh   QUOTE (splice @ Apr 9 2012, 23:03) We wer...   Apr 9 2012, 22:44
|- - pdq   QUOTE (splice @ Apr 9 2012, 17:03) QUOTE ...   Apr 10 2012, 15:44
|- - splice   QUOTE (pdq @ Apr 10 2012, 07:44) ... If s...   Apr 10 2012, 21:54
|- - Arnold B. Krueger   QUOTE (pdq @ Apr 10 2012, 10:44) If someo...   Apr 11 2012, 16:14
- - splice   @-h, I happen to agree with almost everything you ...   Apr 9 2012, 23:04
|- - knutinh   QUOTE (splice @ Apr 10 2012, 00:04) @-h, ...   Apr 9 2012, 23:28
|- - Woodinville   QUOTE (knutinh @ Apr 9 2012, 15:28) I...   Apr 10 2012, 04:58
|- - knutinh   QUOTE (Woodinville @ Apr 10 2012, 05:58) ...   Apr 10 2012, 09:16
|- - Nessuno   QUOTE (knutinh @ Apr 10 2012, 10:16) We k...   Apr 10 2012, 10:56
|- - knutinh   QUOTE (Nessuno @ Apr 10 2012, 11:56) True...   Apr 10 2012, 11:52
||- - Nessuno   QUOTE (knutinh @ Apr 10 2012, 12:52) I sh...   Apr 10 2012, 18:09
|- - DonP   QUOTE (Nessuno @ Apr 10 2012, 05:56) True...   Apr 10 2012, 16:18
- - Engelsstaub   My system is by no means exotic nor is it expensiv...   Apr 9 2012, 23:28
- - kraut   "To determine the actual deformation-force re...   Apr 10 2012, 04:58
|- - greynol   You may want to look up the word predominant. I d...   Apr 10 2012, 05:07
|- - Woodinville   QUOTE (kraut @ Apr 9 2012, 20:58) Having ...   Apr 10 2012, 05:28
- - kraut   QUOTE as is your vile defamation of those who have...   Apr 10 2012, 06:09
- - pdq   Say what you will about two channels, but I grew u...   Apr 10 2012, 12:54
- - lvqcl   Don't know about Soundstream... found this: ht...   Apr 10 2012, 16:39
- - pdq   Only in the world of vinyl would 1% THD be referre...   Apr 17 2012, 13:34
|- - Arnold B. Krueger   QUOTE (pdq @ Apr 17 2012, 08:34) Only in ...   Apr 17 2012, 13:43
- - Pio2001   Yes, that is something that I noticed too. Never l...   Sep 15 2012, 19:31
|- - mzil   On some receivers/preamps the record out selector ...   Sep 16 2012, 00:57
- - krabapple   For us non-Francophones, here's Google Transla...   Sep 16 2012, 18:22
|- - mzil   QUOTE (krabapple @ Sep 16 2012, 13:22) If...   Sep 16 2012, 21:02
||- - krabapple   A disadvantage to any method involving LP is the l...   Sep 17 2012, 16:40
|- - Pio2001   QUOTE (krabapple @ Sep 16 2012, 19:22) Fo...   Sep 16 2012, 21:14
|- - krabapple   QUOTE (Pio2001 @ Sep 16 2012, 16:14) We c...   Sep 17 2012, 16:49
- - Pio2001   No, I mean that I observed the same distortion art...   Sep 17 2012, 22:23
- - robbo1802   Hello Pio, It has been a long time, I think I las...   Sep 27 2012, 08:03
RSS Lo-Fi Version Time is now: 1st August 2015 - 19:49
