Portal appears to be broken in Chrome
Ron Jones
post Mar 26 2012, 18:41
The portal (landing page for hydrogenaudio.org) appears to be malfunctioning. It displays only the header, footer and the navigational breadcrumb:
Replies (1 - 5)
tpijag
post Mar 26 2012, 18:42
Fine here. Maybe clear your browser cache. Close and reload browser and page.
Ron Jones
post Mar 26 2012, 20:48
Yeah, that's the first thing I did.
A closer look indicates that some of the HTML generated is malformed and may be causing issues within Chrome (but IE9 is fine):
<td class='row2''>
(That's two apostrophes, not one quotation mark. That's bad.)
kode54
post Mar 26 2012, 23:52
Group: Admin
I fixed that single quote bug in the template, but I don't know what else it needs.
Apparently, the bug only affects Chrome dev channel or newer. Neither beta nor stable exhibit the issue.
I would like to fix the glaring validation failures on that portal code, and heck, the main template, but I don't even know where some of the template bits are stored. Like that meta description tag that isn't terminated like an XML tag should be. And then a link or two that contain raw ampersands instead of &amp;, but that should be easier to find.
Garf
post Mar 27 2012, 01:15
Mad Scientist
Group: Admin
The site's (X)HTML isn't 100% compliant but that shouldn't be the problem - Chrome's devtools have no problem parsing the structure. This is simply a bug in (the development version of) Chrome.
I fixed some of the issues kode54 pointed out. If you point out more, I can fix those too. But it doesn't help Chrome.
You can also use Firefox, Opera, or hell, even IE. They work.
GenjuroXL
post Mar 27 2012, 08:30
Seems to work in the 18.x branch of Chrome, only 19.x is broken.
RSS Lo-Fi Version Time is now: 31st July 2015 - 11:01
