2 Pages V   1 2 >
What differences among CUETools outputs? libFlake/libFLAC/flake/FLACCL, Moderationóderailed into a verbose discussion about compression levels
pinkfloydeffect
post Mar 24 2012, 23:41
I have some audio FLAC CDs in single track format with a CUE file. I read the best way to split up the tracks is with CUETools, but I don't know which audio output (encoder?) to use. There are four options:
libFlake, libFLAC, flake & FLACCL
Can anyone explain what the difference(s) are please?
pablogm123
post Mar 25 2012, 02:19
Check these links:
www.cuetools.net/wiki/CUETools_FLAC_encoders_comparison
www.cuetools.net/wiki/FLACCL
libFLAC is the standard encoder and the one you should stick with if compatibiliy is the main issue. However, alternative encoders can encoder faster (Specifically FLACCL if you own a proper graphic card) than libFLAC, and apply more aggresive compression levels. However, more aggresive compression levels may broke compatibilty with hardware implementations, as warned in previous links.
This post has been edited by pablogm123: Mar 25 2012, 02:21
Porcus
post Mar 25 2012, 02:25
QUOTE (pinkfloydeffect @ Mar 24 2012, 23:41) *
The safe advise is to use libFLAC/FLAC unless you know what you are doing, or feel like experimenting. FLAC/libFLAC is the reference tool, the official release from the creators of the format.
The 'lib' only makes the difference between a windows library (.dll) and a windows executable (.exe). The reason for offering a choice between the two, is that the user might want to keep just one version and direct everything to that one, rather than having to do multiple upgrades if and when that is due. Flake/libFlake is an alternative implementation of the FLAC format. Don't remember whether it supports all features.
FLACCL requires a CUDA graphics card. http://www.cuetools.net/wiki/FLACCL
pinkfloydeffect
post Mar 25 2012, 02:40
Thanks guys! I'm not worried about speed I have a fast computer I'm worried about compression wink.gif I'm an audiophile quality freak, 0% compression thank you!
Kohlrabi
post Mar 25 2012, 03:12
QUOTE (pinkfloydeffect @ Mar 25 2012, 02:40) *
You're contradicting yourself here. Apparently you don't care about compression at all? unsure.gif
Keep in mind that FLAC is a lossless format, so you don't lose any information, but "gain" (or lose less) disk space due to compression. Think of it like a zip file.
This post has been edited by Kohlrabi: Mar 25 2012, 03:14
pinkfloydeffect
post Mar 25 2012, 04:06
Wait...so my FLAC audio player extracts the song from the FLAC file before it's played?
This post has been edited by db1989: Mar 27 2012, 22:14
Reason for edit: deleting pointless full quote of above post
GenjuroXL
post Mar 25 2012, 09:20
QUOTE (pinkfloydeffect @ Mar 25 2012, 05:06) *
Yup. A process also known as "Decoding". And keep in mind the FLAC file _is_ the song, just in a compressed format that decodes straight to the original data you fed it in the first place. It's called "lossless" for a reason. smile.gif
lvqcl
post Mar 25 2012, 10:34
QUOTE (pinkfloydeffect @ Mar 25 2012, 07:06) *
in time of playing, not before.
pablogm123
post Mar 25 2012, 10:55
I own a very ancient PC (A secondary retro PC I built), which has a Pentium III Coppermine, 1 GHz. I use this PC to play FLAC music, mainly. I don't notice any difference between 0, 5 and 8 modes in decoding-playing.
FLAC is a asymmetric algorithm: Encode relatively slow, decode very fast.
pinkfloydeffect
post Mar 25 2012, 17:55
I see I see, is this why when I open FLAC files in VLC the first few seconds of the song are cut off sometimes? If you REplay it the first few seconds will be there, and foobar seems to "fade" the first few seconds.
pinkfloydeffect
post Mar 25 2012, 22:28
ALSO, the bar above "Go' that says 0-8 is that compression/quality/priority? Best quality 0 or 8? lol
Dario
post Mar 25 2012, 22:38
QUOTE (pinkfloydeffect @ Mar 25 2012, 18:55) *
No audio codec should ever cause such behaviour. FLAC is one of the most mature codecs out there (as are fb2k and VLC in their respective departments), so it's definitely you doing something wrong.
I really suggest that you search a bit regarding how codecs work.
QUOTE (pinkfloydeffect @ Mar 25 2012, 23:28) *
It's the level of compression. Higher values result in higher compression (lower file size), but slower encoding speed.
pinkfloydeffect
post Mar 25 2012, 22:50
Thanks! So either way it's not about quality it's about compression I understand now, so with that being said, my library of FLAC "tracks" (non CUE) could all technically be opened and the tracks/FLAC files re-written in level 8 compression mode with no quality loss of "re-compressing" ?? Sounds worth my time to me if so!
tpijag
post Mar 25 2012, 22:57
once again, lossless is lossless. Before getting too excited do one track. Size reduction might not be worth it to you. Many consider level 4 or 5 to be a good mix of size vs the length of time it takes to encode. Time required to compress greater than this can be long. YMMV
This post has been edited by tpijag: Mar 25 2012, 22:58
pablogm123
post Mar 25 2012, 23:17
Post #15
"and foobar seems to "fade" the first few seconds."
Check Playback/Output options in Foobar. Then, you can tweak Fading options.
In my modest opinion, if you have a (Relatively) modern CPU (Dual-Core or multi-core: Core 2 Duo/Quad, Athlon X2, Core i7, Phenom II...) you always can use -8 mode without any issue. However, in older single-core CPU -8 mode takes a lot of time (Twice the required for -5 mode, more or less), and only compress a little bit more than -5 mode.
pinkfloydeffect
post Mar 25 2012, 23:35
Post #16
It seems to run pretty fast in level 8 for me, I have an Athlon64 X2 @ 3.2Ghz and 4gb of ram....not the best but certainly not outdated.
This post has been edited by db1989: Mar 27 2012, 22:15
Reason for edit: as per posts #6 and #13
pablogm123
post Mar 25 2012, 23:47
Post #17
You can get better perfomance if you use a converter capable of multithreading (i.e, runs one instance for each physical CPU/core). Foobar, for example.
Porcus
post Mar 26 2012, 07:24
Post #18
QUOTE (pinkfloydeffect @ Mar 25 2012, 22:50) *
Yes, but you should do a backup. If there is an error while overwriting, your file could be damaged.
If you want to recompress, then a good advise would be to (I) make sure the backup is synced first, (II) convert from set #1 to set #2, (III) when done, use e.g. foobar's bit-compare to verify that they contain the same audio signal.
pinkfloydeffect
post Mar 27 2012, 04:57
Post #19
Thank You
Reason for edit: as per posts #6, #13, and #16
Chinch
post Mar 27 2012, 11:08
Post #20
Exactly. So here is to sum up what everyone has said about your questions:
1. Compression has nothing to do with audio quality in a FLAC file or any lossless file format like it does with a lossy format such as MP3/AAC (aka M4A). Whether you use level 0, or level 8... the output (whether decoded in real-time as you are listening to the music, or decoding it back to a WAV file, etc) will be exactly the same. Compression ONLY has to do with two factors... a) the amount of hard drive space the encoded FLAC file will take up (if you would like to save as much HD space as possible, then always choose level 8) and b) how much resources will be consumed, most often considered are the playback/real-time resource usage, since the greater the compression of the FLAC file, the more CPU/memory it is likely to use when you are PLAYING that file. When you are decoding to a WAV file... it's likely your hard drive is the bottleneck rather than the CPU. Same goes for real-time decoding -- if your system has trouble decoding audio to the point where it can't keep up with decoding 1 (listening) second of audio before your audio player is ready to play that second or those fractions of a second, then it's time to upgrade. If your machine is fast like you said, then I personally recommend using compression level 8, the max in the reference or "official" FLAC encoder.
2. Once again, they mentioned that FLAC is a lossless format... and you're not going to do anything to make it LOSSY unless you're converting from a LOSSY SOURCE such as MP3's or AAC files. As long as you're encoding from another lossless format, such as Apple Lossless (ALAC) or WAV... which is the uncompressed form of the lossless audio, you will suffer no quality loss. Even decoding a FLAC file to a WAV file, then back to a FLAC file with greater compression will not cause audio loss.
There is a super simple way to prove this. If you know how to create a checksum or a checksum file (such as a SFV, MD5 or SHA-1 file/file hash) then grab a WAV file, get make a checksum of it, then encode the WAV to FLAC using any compression level you want. Now delete the original WAV file. Decode the FLAC file right back to WAV (thus re-creating the original WAV file... which should be identical. Check the newly decoded WAV file with the original WAV file's checksum value. It should match. I'm not going to go into super detail about anything that could cause them not to match but still be the same audio data... because they're rare cases, and they're the exception rather than the rule. Also, each FLAC file, once encoded, has a built-in MD5 "fingerprint" or checksum value. This is calculated considering ONLY the decoded/original audio stream, and EXCLUDES metadata (tags, embedded art, etc) or any other non-audio data. Therefore, you can change the file's tags, etc and even re-encode it, and this MD5 should remain the same.
So here's my proof process. I open up foobar2000, load up a random FLAC file. Then I go to the file's properties, and take a screenshot of it. A few very important values to note. 1) filesize 2) total length (or more importantly, total SAMPLES) 3) MD5 checksum of the audio
Before screenshot, I have no idea what compression was used on this file, etc... it doesn't matter. This is the file's properties, still in FLAC format, the way I found it:
Then, I decode the FLAC file to a WAV file. Next, I arbitrarily choose a compression level of "2"... because it's... well... random enough... then I re-encode the WAV file with the new compression level. Take a look at the end results in the "after" screenshot:
You will notice three important things... 1) the second (re-encoded) file size is LARGER than the original one.. meaning it was originally compressed using greater than level 2 compression, since it's approximately 2MB bigger... BUT at the same time, you'll notice that it is the EXACT same length (both time and samples are identical)... AND the MD5 checksum of the audio stream is identical, even though they have two differing file sizes! This proves that the audio has not changed by a single sample; thousands of a second... furthermore... I used foobar2000's Binary Comparator (I can't recall if it is stock or an add-on, sorry)... but this compares the exact same thing... it disregards any NON-AUDIO data, and compares ONLY the audio within both files. I compared the original FLAC file, with the re-encoded (larger) FLAC output file, with the same results... identical files, no differences found:
All tracks decoded fine, no differences found.
Comparing:
FILE1.FLAC
FILE2.FLAC
No differences in decoded data found.
3. My personal recommendation, and this is only because I have a fast machine with plenty of memory, and ENCODING speed (the very first compression) nor the DECODING speed (decompressing the samples as it plays the audio, plus a little ahead of what you're listening to, which is buffered...) is an issue to me. Therefore, when encoding, I always use two parameters. Those are -8 for maximum compression (I would rather the encoding take a little bit longer and save a little bit more hard drive space than vice versa), since I already run a tight ship there, haha... and although some may argue against its worth; the fact of the matter is that it can't do any HARM (other than consume a few more CPU cycles) is the -V or VERIFY switch/parameter... which encodes a bit of audio, then immediately turns back around and decodes it... then compares it to the source file (either in memory still or on disk) -- if everything jives, then you know there was no type of corruption or errors during the encoding process. It's one of those "paranoid" things that OCD freaks like me do... haha...
4. To me, another important thing... and this is, again, purely preference and will be subjective... but I prefer to rip my CD's in EAC using the COPY AND TEST IMAGE + CUE FILE option. Either option you use, by proper ripping standards, you have GOT to make sure that you are using the proper offset for your specific CD drive, which should have been auto-configured for you by EAC upon first use. This may cause cutoff at the start of a track; most obviously not at the very start of the CD or end... but in the MIDDLE of two seamless/gapless tracks where one goes right into the other with no pause whatsoever... this would be if you were doing track-by-track and reading each track by its own offset. If you have a large offset margin, and it happens between two seamless tracks, you're not going to notice the missed audio-- but it COULD reveal itself as a POP or CLICK in the transition... (which is caused by two points of a waveform not aligning to a zero-boundary, and the sudden shift between two differing dB/amplitude levels caused by misalignment... in this case, missing samples)... If you were ripping the disc as a SINGLE IMAGE... you wouldn't experience this, your whole image would just be shifted <- or -> whatever the missing offset correction was. Since there's padding before and after the first/last tracks, then an offset that is so tiny will only likely ever matter when comparing to the AccurateRip database... MAYBE.
For instance, my drive's offset is +6 samples. A standard audio CD plays at 44,100 samples per second (1 second = 1 frequency cycle, aka "period" = 1Hz). In my case, that 6 sample offset error is, in reality, equal to a fractional 1/7,350ths of 1 second, reduced... if these missing samples occur during an already silent/null/zero'd area of the disc/audio, such as the very first or very last samples of the data.
This is probably far more information than you were looking for, but maybe it'll be helpful to someone else... there are tons of very smart people reading these forums, and they are very curious to learn the fine details, most of them... so I don't know if there's always such a thing as "too detailed" or explaining something to greater levels than the original question may have asked for. I know, myself, I will ask a question that isn't asking for much detail... but simply because I am not AWARE of what details there are to such a subject. In other words, sometimes I don't know the correct questions to ask, if I don't know the depth of topic, right?
I can't begin to ask someone about low-level functionality of say, a video card... if I don't know how the bus handles the data to form/renders images, etc! You read as far as you can understand.. and there'll be a point where it stops making full sense usually... but you've learned a little more than you knew before... and the next thread that goes into detail, you'll understand more of it than you would have.... blah blah. It's all progressive learning, you learn this crap in tiers, (and if you learn it from me, likely in tears)... I'll end my formal write-up there. I'm sure it's more than you ever cared to know... but-- if you do want to know more... that's what these people are all here for... to learn and to teach... ass-hoppah!
NO difference between compress 1 and compress 8 for quality! GO! flaCUDA uses video card GPU on nVIDIA-based cards to speed up encoding. It proprietary though! Not for ATI! Flake and other ... experimental re-codings of original FLAC encoder/decoder. Done for fun/hobby. One by CUETOOLS creator... maybe both. Could be bugs, non-standard problems. I would stick with reference encoder, always. Speed is nice, but encoding glitches and errors, NOT nice... fu.. whoops. Almost drop F bomb there LOL... they mess up audio possibly!!@! This audio, not identical to original! Big problem!!! Hope you enjoy learning from my offerings. If not, my apologies to all. Have fantastic days today, everyone.
P.S. Two very minute bits of info I omitted...
When I rip the audio CD's to a single WAV file, I then turn around and encode that single WAV file to a single FLAC file, and embed the CUE sheet into the FLAC tag. This provides all of the correct indices for track identification (as well as lead-in's or INDEX 00's)... it includes essentially the full original disc's exact layout, within that 1 file... as well as the album art, titles, etc. In essence, I have 1 file per album that contains everything embedded within it to decode it and write back a 100% perfect copy of the original. This is my preference. Most people just haphazardly rip to 1-FLAC-per-TRACK, and don't ever save the CUE sheet or the LOG file from their rip/encode, as I've seen out in the wild. That sucks for me because the funny part is, when I'm looking for these albums, I'm not interested in the audio files... I already have them. I often want to get a different copy of the CUE sheet or log file from someone else's rip to address some rare anomaly or double check something that seems odd to me... and they never include the things. I may be one of the few people who are disappointed that they included audio files.... I just want the text files to compare! Regardless, this way... TO ME... IMO... is the ideal way to package my digital copies of my CD's. As said, though... it's all preference... so no fights necessary about which is "best".
Second, as far as compression ratios go... just for your reference/curiosity... most album WAV files that I compress at level 8 (max) hit an average of about a 30% reduction in file size vs. the original. So most of them end up being just 70% the size of their original, uncompressed sources... with NO LOSS of audio, whatsoever. You've gotta love lossless compression... it's one of the few scenarios where you can literally get "something for nothing"... (but no chicks for free... sorry). In fact, if chicks hear you talking about any of this stuff, you won't be getting chicks for free, OR with a major credit card, even... unfortunately discussing the dynamics of lossless audio compression algorithms does NOT get them hot and bothered. It just gets them bothered. LOL. We all know that already, though. wink.gif
This post has been edited by Chinch: Mar 27 2012, 11:32
Porcus
post Mar 27 2012, 11:31
Post #21
QUOTE (Chinch @ Mar 27 2012, 11:08) *
Nope, FLAC decodes at practically the same speed regardless of compression level (and it is very fast). If you look at http://flac.sourceforge.net/comparison_all_procdectime.html , the differences are miniscule, and it isn't even so that better compression takes longer time.
TAK and WavPack are fairly close to the same behaviour.
As for checking lossiness, it is easier to use foobar2000's bit comparator than md5ing files (which could fail due to headers and tags and whatnot ... actually, fb2k's bit comparator might at worst give miniscule differences due to roundoff errors on mp3 files, but you will usually not use it for those cases anyway).
I agree on that.
Chinch
post Mar 27 2012, 17:40
Post #22
QUOTE (Porcus @ Mar 27 2012, 06:31) *
I'll have to look at your charts a bit later, but to say such a thing would make one ask "if it isn't even so that better compression takes a longer time", then why would the option even exist to compress at the lower levels? If they were identical, it'd be level 8 and that's it... the others would be superfluous. Not to mention it breaks some of the basic accepted laws of computer science and mathematics, such as the time-memory tradeoff-- which this is, essentially. You're trading encoding time for less memory usage (storage memory, specifically, hard drive space; not random access memory). Or the opposite scenario, you get a quicker result, but the tradeoff is more memory/storage space is used. I don't make this up, here's some reading... and it's one of the fundamental concepts behind the creation of rainbow tables and why they are so effective.
See: http://en.wikipedia.org/wiki/Space%E2%80%93time_tradeoff
You must've not read through my post fully, here's a direct quote from it:
Comparing:
FILE1.FLAC
FILE2.FLAC
Also the internal FLAC MD5 files are reliable as comparisons, since they compare the UNCOMPRESSED audio stream in the FLAC file, disregarding all "headers and tags". It strictly uses uncompressed audio to calculate. This is stored in the STREAMINFO metadata block, which is required when creating a FLAC format file.
The quote directly from FLAC's developer pages: "Also included in the STREAMINFO block is the MD5 signature of the unencoded audio data. This is useful for checking an entire stream for transmission errors."
See: http://flac.sourceforge.net/documentation_...t_overview.html under the first header section titled "METADATA".
Don't get the two topics confused-- I do not mean an MD5 created of the entire FLAC file. Simply changing a tag or some other tiny bit of information; any number of things will ruin that MD5 compare. I'm strictly referring to the *internal* MD5 checksum that is auto-generated by the encoder and stored in the STREAMINFO block of the file. You need not do a thing to create this other than to encode to FLAC. This will continue to match across compression levels, if tags are changed, etc -- because, again, it strictly uses the AUDIO STREAM data (the raw audio information, uncompressed) to create this. Thus why in my screenshots, you can see an unchanged MD5 checksum across two FLAC files using the same source WAV, but encoded/compressed at two different levels, even the results are two different file sizes to show the different compression levels used. Read the post again and you'll pick up a lot of this detail; I did mention it.
This post has been edited by db1989: Mar 27 2012, 22:19
Reason for edit: Use [quote] tags properly rather than just lumping your reply in with another user’s post.
Porcus
post Mar 27 2012, 20:31
Post #23
QUOTE (Chinch @ Mar 27 2012, 18:40) *
Sorry. To be clearer:
- better compression (smaller file) takes longer time to encode, yes.
- ... but not to decode. Not with FLAC, and not much with TAK or WavPack either (you might very well be constrained on drive speed on those).
(For the likes of Monkey's and OptimFrog, then there is a price for better compression payable every time you decode.)
Chinch
post Mar 27 2012, 21:26
Post #24
I see, this is can meet more with you on. Definitely going to be more taxing encoding than decoding, surely... and this is going to be a subjective thing, as well... depending on each individual's CPU/memory/hard drive speed, etc. Let me run a quick test. It's going to be a rough one, but an estimated one. I'm curious myself...
Yow. That was so fast it was literally negligible.
Test source (the only CD I could think off immediately that actually fills the entire CD? TOOL - Lateralus).
Decode FLAC -> WAV took 16.1 seconds (Note: Original FLAC compression was LEVEL 8; I know, because I did it)
Decoded WAV is 01h:18m:56s, uncompressed file size is 796MB, single WAV file
You know what? I already know this is going to be a problem and it is going to demonstrate something important.
I was encoding back to FLAC, and noticed 0 and 8 were taking about the same amount of time. Now, I have a good enough machine to know that it's not being utilized to its potential, by far.
I watched the flac.exe encoder task run... and the CPU load never went above 15%. Now, I have an i7 quad-core with HT, so it shows up as 8 cores in task manager/apps. Then I realized that this reference build of FLAC encoder is dated 09/17/2007! That's a 5 year old compile! Then I realized more... of course it's not going to be multi-threaded, let alone optimized to utilize multiple CPU cores! I ran resource manager and highlighted the FLAC process... watched it... and the final results of the process at termination tell me all I really need to know.
Threads: 1, 32-bit app (of course)... it's likely not even compiled with simple optimized instruction extension sets like MMX/SSE/SSE2, etc...
In other words... the encoder is self-limiting. It's not multi-threaded, it's going to run on what would be seen as "half a core" out of 4 physical cores... and basically... that's as good as it's gonna get. The CPU limitation was actually the bottleneck (which is rarely the case in semi-current applications) vs. the HD. So it doesn't matter if I were to run this on a 12-core thread shredding, number crunching monster CPU... I'm gonna end up with the same encode time as I would with say... a piece of crap single core CPU like a Pentium.... lol... whatever came before the Core 2 Duo, I can't even remember the names... Pentium... Pentium Pro? That was like generation 5 of the x86 architecture chips (pent=5)... the Pro was generation 6 I think? Then the dual core chips could have been 7th gen? I'm making stuff up as I go at this point but case already solved and proven that the encode time will be no faster on a Dual core vs. this Quad core... or even on a single core vs. a dual core at the same speed.
This only gives more backup to what I said earlier -- if your computer can't handle realtime decoding of a FLAC file at any compression... it's time for you to upgrade your gear... cause you're hurtin. Conclusion: Not an issue.
And if this is the case, no wonder the encoding/decoding statistics gathered would not vary much from setting to setting! They're using the same amount of resources no matter what you set the compression to. So crank it up to 8, having said that. One of the test encoders that was starting to try and head that direction with the encoder, now that I am starting to recall... Flake, maybe it was? One of them had a benchmarking functionality built in or packaged with it to compare the encode/decode times and CPU demand amongst different compression settings, or maybe that encoder vs. the reference one.
All in all, the actual DECODE of the 800MB (nearly) CD was so fast that it finshed before I hit START on my stopwatch, LOL. So ONE SECOND or less to decode a LEVEL 8 compressed, FULL CD.
I haven't dabbled in programming to a deeper level in years, so I have no idea if there is any resolve to just an old, single threaded app... to make it .... it seems like I've heard of thread-slicing... I know I have... and while I don't know what the exact meaning is, if I had to infer... it would seem that it could take a single thread and distribute the workload across multiple cores (load-balance an otherwise single CPU focused application). Or, besides a recompile of the code with a newer compiler which would include the newest instruction sets for CPU's... etc... (which won't happen, at least officially) -- but alas, I forgot... FLAC is open source! Duh. Now I'm interested in looking at the code. (I was a programmer for years, but then again... I haven't programmed in years.... so I'm without a doubt rusty and not up to par with current technologies and practices)...
I'll come back to this... Let me do some more looking, some more researching... take a look at the source code. I'm not re-inventing the wheel... as it's been recoded as a multi-threaded encoder, and even in flaCUDA, it employs the very powerful GPU to make the encoder super efficient.
Porcus
post Mar 27 2012, 22:40
Post #25
QUOTE (Chinch @ Mar 27 2012, 22:26) *
Since you are a foobar2000 user, I am making the guess that you were converting from there.
If you have a look at Preferences --> Advanced --> Tools --> Converter, you will see an option to use multiple threads, and you will see an option to assign priority to conversion.
I believe the default values are as on my setup: autodetect # of threads, and set priority to 2, on a scale from 1 to 7. I guess that explains the 15 percent figure. Try to set priority to 7 and redo the experiment. (Maybe it even helps to set fb2k at high or realtime priority first.)
As far as I know, you are right that FLAC.exe itself does not support multithreading. However, fb2k will simply start one for each number of threads, although no more than the number of files to convert. That means that big jobs are about equally efficiently done as if FLAC itself had supported multithreading.
fb2k has a decoding speed test: http://wiki.hydrogenaudio.org/index.php?ti...(foo_benchmark)
You can choose whether to buffer the files in RAM in order not to be constrained by drive speed. My few-years old laptop with a Turion TL-56 (dualcore at 1.8 MHz), decodes from RAM at slightly less than 200x realtime, meaning that the actual playback is already down to half a percent of max CPU load. And the differences between FLAC -8, FLAC -0, TAK and WavPack are quite uninteresting ...
2 Pages V   1 2 >
RSS Lo-Fi Version Time is now: 27th January 2015 - 03:22
