What differences among CUETools outputs? libFlake/libFLAC/flake/FLACCL, Moderationóderailed into a verbose discussion about compression levels
pinkfloydeffect
post Mar 24 2012, 23:41
I have some audio FLAC CDs in single track format with a CUE file. I read the best way to split up the tracks is with CUETools, but I don't know which audio output (encoder?) to use. There are four options:
libFlake, libFLAC, flake & FLACCL
Can anyone explain what the difference(s) are please?
tpijag
post Mar 25 2012, 22:57
once again, lossless is lossless. Before getting too excited do one track. Size reduction might not be worth it to you. Many consider level 4 or 5 to be a good mix of size vs the length of time it takes to encode. Time required to compress greater than this can be long. YMMV
This post has been edited by tpijag: Mar 25 2012, 22:58
- pinkfloydeffect   What differences among CUETools outputs? libFlake/libFLAC/flake/FLACCL   Mar 24 2012, 23:41
- - pablogm123   Check these links: www.cuetools.net/wiki/CUETools...   Mar 25 2012, 02:19
- - Porcus   QUOTE (pinkfloydeffect @ Mar 24 2012, 23...   Mar 25 2012, 02:25
- - pinkfloydeffect   Thanks guys! I'm not worried about speed I...   Mar 25 2012, 02:40
|- - Kohlrabi   QUOTE (pinkfloydeffect @ Mar 25 2012, 02...   Mar 25 2012, 03:12
|- - pinkfloydeffect   Wait...so my FLAC audio player extracts the song f...   Mar 25 2012, 04:06
|- - GenjuroXL   QUOTE (pinkfloydeffect @ Mar 25 2012, 05...   Mar 25 2012, 09:20
|- - lvqcl   QUOTE (pinkfloydeffect @ Mar 25 2012, 07...   Mar 25 2012, 10:34
- - pablogm123   I own a very ancient PC (A secondary retro PC I bu...   Mar 25 2012, 10:55
- - pinkfloydeffect   I see I see, is this why when I open FLAC files in...   Mar 25 2012, 17:55
|- - Dario   QUOTE (pinkfloydeffect @ Mar 25 2012, 18...   Mar 25 2012, 22:38
|- - pinkfloydeffect   Thanks! So either way it's not about quali...   Mar 25 2012, 22:50
|- - Porcus   QUOTE (pinkfloydeffect @ Mar 25 2012, 22...   Mar 26 2012, 07:24
|- - pinkfloydeffect   Thank You   Mar 27 2012, 04:57
- - pinkfloydeffect   ALSO, the bar above "Go' that says 0-8 is...   Mar 25 2012, 22:28
- - tpijag   once again, lossless is lossless. Before getting t...   Mar 25 2012, 22:57
- - pablogm123   QUOTE "and foobar seems to "fade" t...   Mar 25 2012, 23:17
|- - pinkfloydeffect   It seems to run pretty fast in level 8 for me, I h...   Mar 25 2012, 23:35
- - pablogm123   You can get better perfomance if you use a convert...   Mar 25 2012, 23:47
- - Chinch   Exactly. So here is to sum up what everyone has sa...   Mar 27 2012, 11:08
|- - Porcus   QUOTE (Chinch @ Mar 27 2012, 11:08) the g...   Mar 27 2012, 11:31
|- - Chinch   QUOTE (Porcus @ Mar 27 2012, 06:31) QUOTE...   Mar 27 2012, 17:40
|- - Porcus   QUOTE (Chinch @ Mar 27 2012, 18:40) I...   Mar 27 2012, 20:31
|- - Chinch   I see, this is can meet more with you on. Definite...   Mar 27 2012, 21:26
|- - Porcus   QUOTE (Chinch @ Mar 27 2012, 22:26) I was...   Mar 27 2012, 22:40
|- - Chinch   Since you are a foobar2000 user, I am making the g...   Mar 28 2012, 04:56
|- - sune1974   What audioplayer do you use for your FLAC-files? Y...   Mar 11 2015, 09:01
|- - larryfine   QUOTE (sune1974 @ Mar 11 2015, 05:01) Wha...   Mar 16 2015, 17:56
- - pinkfloydeffect   Wow those are some lengthy detailed posts there Ch...   Mar 28 2012, 03:38
- - Porcus   Re your concern about a newer FLAC build; I knew I...   Mar 29 2012, 08:24
|- - pinkfloydeffect   QUOTE (Porcus @ Mar 29 2012, 03:24) Re yo...   Mar 29 2012, 23:23
|- - Porcus   QUOTE (pinkfloydeffect @ Mar 30 2012, 00...   Mar 31 2012, 14:28
- - Elias Pies de Plomo   Hello guys, I've been reading your posts as I ...   May 4 2013, 16:27
|- - belli   QUOTE (Elias Pies de Plomo @ May 4 2013, 16...   May 7 2013, 07:05
- - Wombat   QUOTE (belli @ May 7 2013, 08:05) QUOTE (...   May 7 2013, 15:09
|- - belli   QUOTE (Wombat @ May 7 2013, 16:09) QUOTE ...   May 7 2013, 21:21
|- - Gregory S. Chudov   QUOTE (belli @ May 7 2013, 16:21) Flake, ...   May 9 2013, 04:06
- - Wombat   QUOTE (belli @ May 7 2013, 22:21) Flake, ...   May 7 2013, 21:36
|- - belli   QUOTE (Wombat @ May 7 2013, 22:36) QUOTE ...   May 8 2013, 08:17
- - Wombat   I also tried latest 2.1.5 because i am still with ...   May 9 2013, 15:19
- - Gregory S. Chudov   I think the difference in size is just padding. CU...   May 9 2013, 16:47
RSS Lo-Fi Version Time is now: 23rd May 2015 - 11:29
