Help me make (statistical) sense of these DTS test results
krabapple
post Mar 22 2012, 18:33
Being often confronted with claims that DTS and especially Dolby 5.1 sounds like 'crap' compared to lossless surround -- to the extent that some simply refuse to buy a surround remix if it isn't offered in lossless -- I often find myself arguing that DTS and DD are actually rather good at what they do (lossy perceptual encoding), and should be hard to distinguish from lossless in typical listening. Suffice to say I am sometimes met with vigorous, occasionally bordering on vicious, reactions to this stance biggrin.gif
That happened on the SurroundSound forum a few months ago, and in response, a poster (a nice guy, not vicious!) set up a listening test. He took a lossless 96/24 surround track of subjectively good audio quality, and converted it to DTS with Surcode's encoder, at three different settings. He then converted all of the lossy versions to 96/24 PCM to match the lossless, and offered them as a downloadable package that one could use to compare 'blind' -- the subject doesn't know what order the 4 different versions are in (though he does know what formats were used in the test) , and is tasked with identifying them.
Nine people so far have returned answers (I haven't yet, due to pesky amounts of travel I've been doing lately) and the author has kindlyl shared these preliminary results. Red indicates incorrect identifications
With the caveat that this is hardly a rigorous scientific test (which the test author has acknowledged all along) , and assuming good faith on the part of the subjects, I find these results surprising. I'm also at a loss to evaluate the probabilities here. Not just the fact that it's a four-way choice , but also because some subjects only got as far as ID ing the lossless. As a statistics maven friend of mine said, "We have to either look at a test of 9 people on identifying the original versus other, or a test of 7 people on picking all four versions." He also tells me the number of replies here is too small to do a chi-square test to determine p-value the traditional way. And also "I think there is evidence here (presuming the experiment was carried out appropriately) that people can identify the original audio (6/9 better than 25%), and that they can identify all four versions (2/7 better than 4%)." I agreed that it's possible -- no one has ever denied that -- but I was surprised at how *many* were able to do it here. So he and I explored the significance of the number of correct lossless vs not lossless replies (6/9) . My stats maven's analysis of that:
The probability of 6 guessing correctly out of 9 is...
1/4 * 1/4 * 1/4 * 1/4 * 1/4 * 1/4 * 3/4 * 3/4 * 3/4
(i.e. 6 people do something with a 1 in 4 chance and 3 people do the opposite, i.e. something with a 3 in 4 chance)
... but we then have to multiply that by what's called 9C6, that is how many ways there are of picking 6 people from 9 people, because we don't care which 6 people are right. 6C9 is the same as 9C3, i.e. the number of ways of picking 3 people from 9 people = 9!/(3!*6!) = 9*8*7/3*2
So, the whole thing comes to 0.008652. Pretty unlikely.
That's not a p-value however. The p-value would be slightly larger because it would be the probability of 6 OR MORE people guessing correctly, not of PRECISELY 6 guessing correctly, which is the number above.
So, we calculate the probability of 7 guessing correctly...
0.001236
And of 8...
0.000103
And of 9...
3.8147E-06
So, summing those...
The probability that 6 or more people would guess correctly with a 1/4 chance is 0.001, so that's our p-value. Highly significant
i.e., highly significant assuming a significance threshold of p=0.05 (which we agreed is traditional but not always appropriate, sometimes it needs to be smaller, e.g. if there's good independent reason to believe the phenomenon should be very unlikely or even 'impossible').
NB This wasn't performed as an ABC/hr type preference test, as would normally be done with codecs. It's just people listening and comparing at home, by various (unspecified) means. (I'm leaving out lots of back and forth from various forum members, one of whom for example pointed up a section of music that he felt especially reveals the differences)
I'd be curious to hear what HA has to say. I can probably even provide the original sound files if people want to try it themselves (the order shown in the table is not necessarily the file order).
This post has been edited by krabapple: Mar 22 2012, 18:36
krabapple
post Mar 22 2012, 21:38
btw, the test author has also since offered up a test of hi rz vs redbook.....
https://groups.google.com/group/surroundsou...a5ca293f8c20d24
2Bdecided
post Mar 23 2012, 16:06
ReplayGain developer
QUOTE (krabapple @ Mar 22 2012, 20:38) *
This is a nice recording, though obviously SACD/DSD sourced (rising noise above 50kHz) - but one of the stereo 48kHz conversions is messed up - there's aliasing from 24kHz-48kHz. The other one is fine (no aliasing at all).
lossyWAV can only find a few brief moments where it thinks the track needs more than 16-bits. It's happy with 14-bit for the vast majority and 12 for more than half of it. (without noise shaping).
I can't check it properly because I can't play 192kHz - but at 96kHz I can't hear anything wrong with any of them, even during the very quietest parts.
FWIW I suspect some use of dynamic range compression in the original recording, but it sounds fine to me.
- krabapple   Help me make (statistical) sense of these DTS test results   Mar 22 2012, 18:33
- - 2Bdecided   QUOTE (krabapple @ Mar 22 2012, 17:33) I ...   Mar 22 2012, 19:02
|- - krabapple   QUOTE (2Bdecided @ Mar 22 2012, 14:02) QU...   Mar 22 2012, 21:31
|- - absinthe33   QUOTE (krabapple @ Mar 22 2012, 21:31) Of...   Mar 23 2012, 18:31
- - DVDdoug   QUOTE Being often confronted with claims that DTS ...   Mar 22 2012, 21:18
|- - krabapple   QUOTE (DVDdoug @ Mar 22 2012, 16:18) QUOT...   Mar 22 2012, 21:36
- - krabapple   btw, the test author has also since offered up a t...   Mar 22 2012, 21:38
|- - 2Bdecided   QUOTE (krabapple @ Mar 22 2012, 20:38) bt...   Mar 23 2012, 16:06
- - 2Bdecided   Wow - a DVD audio disc image. That's real hand...   Mar 23 2012, 00:07
|- - krabapple   QUOTE (2Bdecided @ Mar 22 2012, 19:07) Wo...   Mar 23 2012, 16:16
- - 2Bdecided   I can only listen in stereo, and I cannot hear any...   Mar 23 2012, 11:47
|- - krabapple   QUOTE (2Bdecided @ Mar 23 2012, 06:47) I ...   Mar 23 2012, 16:23
|- - 2Bdecided   QUOTE (krabapple @ Mar 23 2012, 15:23) OK...   Mar 23 2012, 19:31
|- - krabapple   QUOTE (2Bdecided @ Mar 23 2012, 14:31) QU...   Mar 23 2012, 20:00
|- - 2Bdecided   QUOTE (2Bdecided @ Mar 23 2012, 18:31) OK...   Mar 23 2012, 22:50
- - krabapple   btw my facts about the codec were incorrect -- acc...   Mar 23 2012, 16:46
- - absinthe33   Hi, you can probably mount the ISO in a virtual dr...   Mar 24 2012, 12:52
- - krabapple   QUOTE (absinthe33 @ Mar 24 2012, 07:52) H...   Mar 26 2012, 01:11
RSS Lo-Fi Version Time is now: 30th July 2015 - 07:46
