Lame3.99.5y, A 3.99.5 functional extension
halb27
post Mar 18 2012, 11:12
You can download it from here.
What’s the functional extension?
It offers a VBR quality setting -V0+.
-V0+ is -V0 with extra properties. These properties can improve upon difficult-to-encode spots in the music like temporal smearing issues as with problem sample eig or with tremolo problem isues as with problem sample lead-voice. eig and lead-voice are fine to me when using -V0+.
How is it done?
-V0+ uses a strategy which is targeting at providing maximum possible audio data space for hard-to-encode spots in the music. -V0+ increases the accuracy demands for spots in the music with detected impulses, and it has a general demand for audio data bitrate to stay rather high.
What’s the price to pay?
Average bitrate goes up a little bit. For my standard test set of various pop music average bitrate is 256 kbps with -V0+, whereas -V0 takes 252 kbps.
Moreover, in order to prevent another 10 kbps increase in average bitrate, the fast and lossless mp3packer procedure is recommended to be called for the produced mp3 file. Used with a bat file invoked from the explorer’s folder context menu this is comfortably done for the mp3 files of an entire folder.
The 10 kbps bitrate bloat is a consequence of the strategy for providing maximum possible data space. For doing so a 17.5 kHz lowpass is also used internally. If you don’t like that use a lowpass according to your likings. But even if you are able to distinguish higher frequencies in an isolated listening test, this doesn’t mean you can take profit of that with real life music. Not talking about the fact that the musical contents of higher frequncies is next to nothing.
This post has been edited by halb27: Mar 18 2012, 11:37
halb27
post Sep 8 2012, 19:46
Big trouble!
I managed to put a premature version into the zip file!
That's why you got at an average bitrate around 300 kbps, GeSomeone.
I'm deeply sorry for this.
The correct version is in the zip file now.
A big thanks to Dynamic whose findings lead to the revelation of the issue (and will lead to a new version because he found that -V n+ is worth while for lower quality settings too).
This post has been edited by halb27: Sep 8 2012, 19:48
goa pride
post Sep 9 2012, 21:37
QUOTE (halb27 @ Sep 8 2012, 19:46) *
Big trouble!
is this developer version of Lame recommended for electronic music?
Dynamic
post Sep 9 2012, 22:37
QUOTE (goa pride @ Sep 9 2012, 21:37) *
I guess there's plenty of potential for highly tonal signals and sharp transients to combine in some kinds of electronic music.
This version is probably best reserved for problem cases because it does add quite a lot to the bitrate.
Come to think of it, I should probably try out the Angel Falls guitar picking problem sample this fixes with another encoder like Helix (using the VBR -X2 -U2 -V60 setting from the 128kbps MP3 listening test where Helix tied with LAME) just to see if it has the same issue. No time tonight, but maybe another time.
This post has been edited by Dynamic: Sep 9 2012, 22:38
Dynamic
post Sep 10 2012, 17:57
QUOTE (Dynamic @ Sep 9 2012, 22:37) *
I did hear the same problem in the 0.9 to 1.9 second range of the Angels Fall problem sample in the Helix VBR encode as well (which was actually 126 kbps).
In a day or two, I might try ABXing this using the main (constrained VBR) or experimental (purer VBR) OPUS encoders too (around 48, 64, 80, 96 kbps are worth a try at first because it's more bit-rate efficient than MP3 so 64-80 is likely to be the good for everyday use range (-V5 ish for LAME) and 96-128 is probably in the -V4 to -V2 (high to very high quality) sort of range on early impressions and results of some formal tests in the public domain).
I suspect that the option of long/short block selection per frequency band that's in the opus toolbox, could prove very useful in meeting the conflicting demands of simultaneous tonal and transient signals without enormous momentary bitrate, though the detection / decision might or might not be implemented to deal with it ideally, as this sort of sample is probably still a relatively rare problem sample that might not have been tuned for at this relatively early stage.
If I do test opus I'll probably post in the thread for this problem sample and link it to the relevant Opus thread. If anything interesing comes up that could be relevant to tuning lame3.99.5y further I'll post a link here also.
- halb27   Lame3.99.5y   Mar 18 2012, 11:12
- - halb27   Some remarks about ‘why a new variant after 3.99.5...   Mar 18 2012, 11:13
|- - GeSomeone   QUOTE (halb27 @ Mar 18 2012, 12:13) As a ...   Mar 19 2012, 00:22
- - halb27   -V0+ is now more or less what was -V1+ before, add...   Mar 19 2012, 08:08
- - ggunnell   I use dbPoweramp as a Lame front end. Currently d...   Apr 14 2012, 21:25
|- - chi   QUOTE (ggunnell @ Apr 14 2012, 22:25) …, ...   Apr 15 2012, 05:53
- - halb27   I can confirm your idea and chi's result. For ...   Apr 15 2012, 09:43
|- - ggunnell   QUOTE (halb27 @ Apr 15 2012, 03:43) I can...   Apr 15 2012, 17:15
- - halb27   So you compiled both Lame 3.99.5 and 3.99.5y yours...   Apr 15 2012, 20:20
|- - ggunnell   QUOTE (halb27 @ Apr 15 2012, 14:20) So yo...   Apr 16 2012, 05:57
- - ShotCaller   halb, seeing that -V0+ tends to be in the 300+ kbp...   Apr 16 2012, 05:40
|- - halb27   QUOTE (ShotCaller @ Apr 16 2012, 05:40) h...   Apr 16 2012, 07:31
|- - skamp   QUOTE (halb27 @ Apr 16 2012, 08:31) An op...   Apr 16 2012, 07:39
||- - halb27   QUOTE (skamp @ Apr 16 2012, 07:39) QUOTE ...   Apr 16 2012, 07:54
||- - soundping   QUOTE (skamp @ Apr 16 2012, 01:39) QUOTE ...   Apr 16 2012, 21:22
|- - GeSomeone   QUOTE (halb27 @ Apr 16 2012, 08:31) 3.99....   Apr 18 2012, 00:37
- - halb27   That's why freeformat isn't of practical u...   Apr 16 2012, 23:08
- - naturfreak   A simple question to satisfy my curioustiy: Will ...   Apr 17 2012, 14:06
- - halb27   I welcome this, but it's up to the Lame devs.   Apr 17 2012, 19:28
- - halb27   Using a higher lowpass frequency has an effect on ...   Apr 18 2012, 00:50
|- - IgorC   QUOTE (halb27 @ Apr 17 2012, 20:50) Main ...   Apr 18 2012, 02:53
- - halb27   Big trouble! I managed to put a premature ver...   Sep 8 2012, 19:46
- - goa pride   QUOTE (halb27 @ Sep 8 2012, 19:46) Big tr...   Sep 9 2012, 21:37
- - Dynamic   QUOTE (goa pride @ Sep 9 2012, 21:37) is ...   Sep 9 2012, 22:37
|- - Dynamic   QUOTE (Dynamic @ Sep 9 2012, 22:37) Come ...   Sep 10 2012, 17:57
- - halb27   QUOTE (goa pride @ Sep 9 2012, 22:37) is ...   Sep 9 2012, 23:29
RSS Lo-Fi Version Time is now: 27th April 2015 - 09:27
