FLAC compression in EAC doesn't work
ghost22
post Mar 18 2012, 10:01
I'm EAC newbie and need help. I want to rip an compress to flac.
EAC Version 1.0 beta 3.
Flac: FLAC - Free Lossless Audio Codec 2001,2002,2003,2004,2005,2006 Josh Coalson from http://flac.sourceforge.net/
I used in compressions options:
checked: use external programm for compression
parameter passing scheme: user defined encoder
use file extetion: .flac
Programm including...: C:\Program Files (x86)\Exact Audio Copy\flac.exe
additional command line: -T "artist=%artist%" -T "title=%title%" -T "album=%albumtitle%" -T "date=%year%" -T "tracknumber=%tracknr%" -T "genre=%genre%" -5 %source%
checked: delete WAV after compression
checked: check for external programs return code
when i "test encoder" everything seems ok: no error occured.
I run EAC "test&copy selected tracks - compressed"
But, it rips and saves in the designated folder in WAV and not .flac
I don't know what else to do? any suggestions?
db1989
post Mar 18 2012, 12:34
Iím sure you wonít have to abandon FLAC. Someone else can find something Iíve missed, or whatever. Perhaps if you post a screenshot of your settings page, there will be more information there. In any case, just wait for a while rather than forgetting FLAC altogether!
One thing I can see in your ALAC examples is this discrepancy:
i %s -o %d -d
vs.
-i "%coverfile%" -o "%original%" -d "%dest%"
They canít both be right, so thatís probably part of your problem.
Again, thereíll almost certainly be a way to get FLAC working. Be patient!
- ghost22   FLAC compression in EAC doesn't work   Mar 18 2012, 10:01
- - db1989   Does it make a difference if you add %destination%...   Mar 18 2012, 10:06
- - ghost22   to db1989: if I add %destination% at the end i ge...   Mar 18 2012, 10:58
- - db1989   Actually, no, I see now that our guide for using E...   Mar 18 2012, 11:43
- - ghost22   to db 1989 my next option would be to use ALAC fo...   Mar 18 2012, 12:03
- - db1989   Iím sure you wonít have to abandon FLAC. Someone e...   Mar 18 2012, 12:34
- - Apesbrain   Here is my working commandline. I believe it is t...   Mar 18 2012, 13:59
- - db1989   Aargh, I said %destination% instead of %dest% and ...   Mar 18 2012, 14:07
- - ghost22   to db 1989 Thank you for your post. I tried your ...   Mar 18 2012, 16:20
- - Apesbrain   Two things I would try: 1. Copy FLAC.EXE and one ...   Mar 18 2012, 20:14
- - lvqcl   I wonder why External Compresser Test window shows...   Mar 18 2012, 21:26
- - ghost22   Thanks to everybody. In the meantime I uninstalled...   Mar 19 2012, 17:12
|- - laslaw01   I'm having the same exact issues. Everything i...   May 28 2012, 20:39
|- - roadworrier   QUOTE (laslaw01 @ May 28 2012, 20:39) I...   Feb 23 2014, 17:11
- - tezet   I have a working setup on my x64 Windows 8.1 syste...   Feb 23 2014, 22:40
- - Parkmad   Sorry to hijack a thread (even one that got bumped...   Mar 22 2015, 17:36
- - Apesbrain   Try stripping the commandline options down to the ...   Mar 22 2015, 17:50
- - Parkmad   Thanks for the suggestion, it still returned the s...   Mar 22 2015, 19:09
- - Apesbrain   What is the error message? I have the same config...   Mar 22 2015, 19:51
- - Parkmad   The error I am seeing is "The external compre...   Mar 22 2015, 22:19
- - Parkmad   I determined the problem. FLAC didn't like th...   Mar 23 2015, 04:14
RSS Lo-Fi Version Time is now: 7th May 2015 - 10:29
