Vinyl is equivalent to which digital bit-depth and sampling rate?
KMD
post Mar 13 2012, 12:49
What sample rate and bit depth , dithered, would create a digital recording with the same bandwidth and signal to noise ratio as vinyl
- KMD   Vinyl is equivalent to which digital bit-depth and sampling rate?   Mar 13 2012, 12:49
- - dhromed   Somewhat below Redbook.   Mar 13 2012, 12:57
- - Kees de Visser   This old thread gives some answers: http://www.hyd...   Mar 13 2012, 13:32
- - KMD   Ok so I'm getting 44Khz 12 Bit from there. Pe...   Mar 13 2012, 13:50
|- - 2Bdecided   QUOTE (KMD @ Mar 13 2012, 12:50) Ok so I...   Mar 13 2012, 14:40
- - pdq   There was a listening test here a few years back. ...   Mar 13 2012, 14:14
- - KMD   The question is do very low signal to noise rati...   Mar 13 2012, 14:49
|- - 2Bdecided   QUOTE (KMD @ Mar 13 2012, 13:49) The ques...   Mar 13 2012, 15:15
- - KMD   If people think vinyl LP sounds better than 12 Bit...   Mar 13 2012, 15:26
|- - 2Bdecided   QUOTE (KMD @ Mar 13 2012, 14:26) If peopl...   Mar 13 2012, 15:39
- - John_Siau   QUOTE (KMD @ Mar 13 2012, 06:49) What sam...   Mar 13 2012, 15:41
- - KMD   listening tests at super high quality are hard to ...   Mar 13 2012, 16:01
|- - Rotareneg   QUOTE (KMD @ Mar 13 2012, 09:01) If it ex...   Mar 13 2012, 17:34
|- - krabapple   QUOTE (KMD @ Mar 13 2012, 10:01) listenin...   Mar 13 2012, 19:50
|- - Arnold B. Krueger   QUOTE (KMD @ Mar 13 2012, 11:01) listenin...   Mar 21 2012, 11:29
- - Arnold B. Krueger   QUOTE (KMD @ Mar 13 2012, 07:49) What sam...   Mar 21 2012, 11:43
|- - Porcus   QUOTE (Arnold B. Krueger @ Mar 21 2012, 11...   Mar 22 2012, 15:49
|- - pdq   QUOTE (Porcus @ Mar 22 2012, 10:49) QUOTE...   Mar 22 2012, 16:01
|- - Arnold B. Krueger   QUOTE (Porcus @ Mar 22 2012, 10:49) QUOTE...   Mar 22 2012, 20:44
|- - Glenn Gundlach   QUOTE (Arnold B. Krueger @ Mar 22 2012, 11...   Mar 23 2012, 04:29
|- - Woodinville   QUOTE (Glenn Gundlach @ Mar 22 2012, 20:2...   Mar 23 2012, 11:48
|- - DonP   QUOTE (Glenn Gundlach @ Mar 22 2012, 23:2...   Mar 24 2012, 13:26
- - icstm   ^^^ so isn't quite funny that all those ppl wh...   Mar 22 2012, 12:45
|- - Nessuno   QUOTE (icstm @ Mar 22 2012, 12:45) ^^^ so...   Mar 22 2012, 15:54
|- - Ethan Winer   QUOTE (icstm @ Mar 22 2012, 07:45) all th...   Mar 24 2012, 20:05
||- - Woodinville   QUOTE (Ethan Winer @ Mar 24 2012, 12:05) ...   Mar 26 2012, 10:03
|- - Fandango   QUOTE (icstm @ Mar 22 2012, 13:45) ^^^ so...   Mar 26 2012, 10:18
|- - Arnold B. Krueger   QUOTE (Fandango @ Mar 26 2012, 05:18) QUO...   Apr 15 2012, 12:42
- - greynol   While CDDA only goes to 22k, I don't believe i...   Mar 22 2012, 14:02
- - pdq   If such jitter were a problem (which it is not) th...   Mar 24 2012, 14:05
|- - DonP   QUOTE (pdq @ Mar 24 2012, 09:05) If such ...   Mar 25 2012, 12:41
- - icstm   QUOTE (Woodinville @ Mar 26 2012, 09:03) ...   Apr 16 2012, 09:49
- - cdroid   So I didn't read each and every one of these p...   Sep 2 2014, 07:36
|- - Kohlrabi   QUOTE (cdroid @ Sep 2 2014, 08:36) 1. The...   Sep 2 2014, 08:59
|- - mjb2006   cdroid, welcome to the forum. You will find that w...   Sep 2 2014, 09:15
||- - 2Bdecided   QUOTE (mjb2006 @ Sep 2 2014, 09:15) QUOTE...   Sep 2 2014, 10:23
|- - Arnold B. Krueger   QUOTE (cdroid @ Sep 2 2014, 02:36) So I d...   Sep 2 2014, 16:10
|- - mjb2006   QUOTE (Arnold B. Krueger @ Sep 2 2014, 09...   Sep 3 2014, 05:07
- - lithopsian   QUOTE Misapprehension number 3: There are no gaps ...   Sep 3 2014, 11:51
|- - Arnold B. Krueger   QUOTE (lithopsian @ Sep 3 2014, 06:51) QU...   Sep 3 2014, 19:15
- - lithopsian   I wonder if you are being deliberately obtuse. Sa...   Sep 3 2014, 19:45
|- - pdq   QUOTE (lithopsian @ Sep 3 2014, 14:45) I ...   Sep 3 2014, 20:18
|- - audiophool   QUOTE (pdq @ Sep 3 2014, 21:18) I don...   Sep 3 2014, 21:41
||- - Kohlrabi   QUOTE (audiophool @ Sep 3 2014, 22:41) I ...   Sep 4 2014, 00:02
||- - Green Marker   QUOTE (Kohlrabi @ Sep 4 2014, 00:02) QUOT...   Sep 4 2014, 05:45
||- - Kohlrabi   QUOTE (Green Marker @ Sep 4 2014, 06:45) ...   Sep 4 2014, 09:18
|- - Green Marker   I think the average audiophile reading this would ...   Sep 3 2014, 21:52
- - mjb2006   You hit the nail on the head. In the typical audio...   Sep 4 2014, 06:12
|- - 2Bdecided   QUOTE (mjb2006 @ Sep 4 2014, 06:12) What ...   Sep 4 2014, 10:12
|- - mjb2006   QUOTE (2Bdecided @ Sep 4 2014, 03:12) QUO...   Sep 4 2014, 15:37
- - 2Bdecided   Here is the process: 1. pick a sampling frequency...   Sep 4 2014, 10:05
- - Vietwoojagig   Maybe this is the right discussion to ask a questi...   Sep 4 2014, 12:35
- - 2Bdecided   It's convolved with (filtered by) a sinc pulse...   Sep 4 2014, 13:12
|- - Green Marker   QUOTE (2Bdecided @ Sep 4 2014, 13:12) How...   Sep 4 2014, 19:53
|- - Arnold B. Krueger   QUOTE (Green Marker @ Sep 4 2014, 14:53) ...   Sep 4 2014, 20:50
||- - Green Marker   QUOTE (Arnold B. Krueger @ Sep 4 2014, 20...   Sep 4 2014, 20:56
||- - Arnold B. Krueger   QUOTE (Green Marker @ Sep 4 2014, 15:56) ...   Sep 4 2014, 22:34
||- - Green Marker   QUOTE (Arnold B. Krueger @ Sep 4 2014, 22...   Sep 4 2014, 23:04
||- - Kohlrabi   QUOTE (Green Marker @ Sep 5 2014, 00:04) ...   Sep 4 2014, 23:28
|||- - Green Marker   QUOTE (Kohlrabi @ Sep 4 2014, 23:28) QUOT...   Sep 5 2014, 00:04
|||- - saratoga   QUOTE (Green Marker @ Sep 4 2014, 19:04) ...   Sep 5 2014, 00:16
||||- - Green Marker   QUOTE (saratoga @ Sep 5 2014, 00:16) No a...   Sep 5 2014, 00:36
||||- - saratoga   QUOTE (Green Marker @ Sep 4 2014, 19:36) ...   Sep 5 2014, 00:53
|||- - 2Bdecided   QUOTE (Green Marker @ Sep 5 2014, 00:04) ...   Sep 5 2014, 11:02
||- - Arnold B. Krueger   QUOTE (Green Marker @ Sep 4 2014, 18:04) ...   Sep 5 2014, 01:29
||- - Green Marker   QUOTE (Arnold B. Krueger @ Sep 5 2014, 01...   Sep 5 2014, 08:42
||- - Arnold B. Krueger   QUOTE (Green Marker @ Sep 5 2014, 03:42) ...   Sep 5 2014, 12:54
|- - saratoga   QUOTE (Green Marker @ Sep 4 2014, 14:53) ...   Sep 4 2014, 23:11
- - Thad E Ginathom   Speaking as a self-selected sample of one... Mont...   Sep 4 2014, 18:11
- - xnor   A sinc filter is an ideal low pass filter. DC to f...   Sep 5 2014, 12:57
- - cdroid   I've read some of your responses and I'm s...   Sep 6 2014, 02:44
|- - splice   Sigh... this place needs a :facepalm: icon. QUOT...   Sep 6 2014, 04:17
|- - sld   QUOTE (cdroid @ Sep 6 2014, 09:44) First ...   Sep 6 2014, 04:56
||- - KozmoNaut   QUOTE (sld @ Sep 6 2014, 04:56) Please pe...   Sep 6 2014, 10:26
||- - Arnold B. Krueger   QUOTE (KozmoNaut @ Sep 6 2014, 05:26) QUO...   Sep 6 2014, 12:34
|- - probedb   QUOTE (cdroid @ Sep 6 2014, 02:44) The fi...   Sep 6 2014, 09:14
|- - Arnold B. Krueger   QUOTE (cdroid @ Sep 5 2014, 21:44) I...   Sep 6 2014, 12:38
|- - Kohlrabi   QUOTE (cdroid @ Sep 6 2014, 03:44) I...   Sep 6 2014, 16:15
|- - saratoga   QUOTE (cdroid @ Sep 5 2014, 21:44) No, I ...   Sep 6 2014, 20:37
|- - Arnold B. Krueger   QUOTE (cdroid @ Sep 5 2014, 21:44) I saw ...   Sep 7 2014, 00:01
- - cdroid   I forgot to reply to the post that irritated me th...   Sep 6 2014, 02:59
|- - splice   QUOTE (cdroid @ Sep 5 2014, 17:59) ... wh...   Sep 6 2014, 04:22
|- - Green Marker   QUOTE (cdroid @ Sep 6 2014, 02:59) In the...   Sep 6 2014, 09:20
- - mjb2006   I'm impressed. Not many people can read Princi...   Sep 6 2014, 11:07
- - Thad E Ginathom   QUOTE (cdroid @ Sep 6 2014, 07:14) I...   Sep 6 2014, 19:12
- - Wombat   Time to fire up my old gear and listen a Burr Brow...   Sep 6 2014, 19:48
|- - Kohlrabi   QUOTE (Wombat @ Sep 6 2014, 20:48) The un...   Sep 6 2014, 20:26
- - xnor   I have studied UFOlogy, and as such I can tell you...   Sep 6 2014, 22:04
- - xnor   The Sony CDP-101, released in 1982, had only one ...   Sep 7 2014, 01:06
|- - Arnold B. Krueger   QUOTE (xnor @ Sep 6 2014, 20:06) The Sony...   Sep 7 2014, 15:58
- - xnor   Oh yeah, the min phase brick wall, how could I for...   Sep 7 2014, 17:26
|- - Arnold B. Krueger   QUOTE (xnor @ Sep 7 2014, 12:26) Oh yeah,...   Sep 7 2014, 19:47
- - mjb2006   @Arnold QUOTE I don't know where you got the i...   Sep 7 2014, 17:41
|- - Arnold B. Krueger   QUOTE (mjb2006 @ Sep 7 2014, 12:41) @Arno...   Sep 7 2014, 20:05
- - wswartzendruber   I skipped about half of the thread, but am I the o...   Sep 8 2014, 08:03
|- - 2Bdecided   QUOTE (wswartzendruber @ Sep 8 2014, 08:0...   Sep 8 2014, 09:59
||- - Arnold B. Krueger   QUOTE (2Bdecided @ Sep 8 2014, 04:59) QUO...   Sep 8 2014, 10:57
|- - Arnold B. Krueger   QUOTE (wswartzendruber @ Sep 8 2014, 03:0...   Sep 8 2014, 10:51
- - Thad E Ginathom   If one is young (or even not so young, like me) an...   Sep 8 2014, 09:50
- - xnor   But analog has infinite resolution!!!...   Sep 8 2014, 12:03
2 Pages V   1 2 >
RSS Lo-Fi Version Time is now: 4th March 2015 - 06:10
