16 bit, 24 bit and Noise Floor
botface
post Feb 28 2012, 20:13
I'm involved in a discussion on a home recording forum. We are not discussing post processing, mixing or mastering just the simple capture of a single acoustic instrument.
I'm suggesting that with a recording environment that yields a noise floor of -60dbfs it makes no difference at whether you capture in 16 bit or 24 bit as you effectively only have 10 bits to work with and so any theoretical benefits of using 24 bit are lost
I'm getting arguments back like :
Specifically 24 bit capture files will still provide the widest range of dynamic and the greatest resolution for capturing anything
With 16 bit you have that many steps and with 24 you have that many more ... which means the more bits you have, the less grainy your resolution is
To give an example: You have a scale of 0 to 100. If you print it on a 10cm piece of metall you barely have enough place to distinguish 1mm distances. If you print it onto a 1m bar, you can have plenty more subdivisions. Of course 100 is still 100 and zero is still zero, but you have many more subdivisions. Same with digital signal. Say you would use a 2 db resolution: then you would have just four different levels to represent the different signal levels which would have to be somehow digitalized onto these four steps.
With 16 bit you have 2^16 possible steps (65536) and with 24 bits 2^24 possible steps (16777216, quite a bit more...). Whether you believe them to be more useful to represent an audio signal I leave to your own ears.I'm not claming that the perceived distance between noise level and maximum level is bigger with 24 bits than with 16 bits. It's just that you have many more subdivisions in between, and that is audible.
If the full theoretically possible dynamical span gets more quantizing levels per dB so must also the same dynamical span of let's say 60dB gain above recorded noise floor. I' can't see where this argument is wrong ... Maybe we're talking about different things?
16 bit recordings have a theoretical dynamic span of 96dB; 24 bit recordings one of 144 dB. If I take the number of possible representations of level with 16 bit, then I have 2^16/96 = 682,7 (rounded) steps per 1dB. WIth a 24 bit recording I have 2^24/144 = 116508,4 (again rounded) steps per 1 dB. So it seems that the dynamical resolution is much finer with 24 bit.
The scale is the same, but with 24 bits we get bigger number of smaller steps than with 16 bit at any part of the scale which allows for better resolution.
You can want to increase the dynamic range by cutting off the noise, and stretching what is left down to the negative infinity level to fill the whole range, and higher resolution of 24 bit will become very handy compared to 16 bit.
I've given examples, I've worked through the arithmetic, I've provided analogies but nobody seems to think the noise floor of the recording environment has any impact on the ability of 24 bit to capture more detail. Can any of you provide any examples or analogies that you've found to work in the past.
mjb2006
post Feb 28 2012, 21:22
Most explanations—even those for technical audiences—of the effect of sample rate and bit depth in sampling generally boil down to the idea of "capturing more detail". I think this is a big part of the problem; everything that people learn about digital audio gets integrated with this basic tenet. You can talk until you're blue in the face about noise, Nyquist, and everything else, but you're still going to run up against this perception: there is a squiggly line which is being segmented along the X and Y axes with a certain degree of precision in order to represent it as a series of numbers, and if you crank up the knobs that control the precision along one axis or the other, you're going to get a better representation of the original squiggly line, so why not do that. When someone's thinking that way, what can you do? You can tell them that if all the music is between 0 and 5, making a knob that goes to 11 instead of 10 is not going to give you "more detail". But they just aren't convinced. So I'm not sure what you can really do. There's still a need for a sampling primer for audiophile myth-busting purposes.
spindle
post Mar 4 2012, 12:12
QUOTE (mjb2006 @ Feb 28 2012, 20:22) *
Forgive me but, through ignorance, I fall pretty well into that category and I certainly can't follow the technicalities of this thread. Could you possibly point me at such a primer (for numpties) that will help me understand why 'finer granularity' is not necessarily better and is not the complete story?
TIA
2Bdecided
post Mar 7 2012, 11:41
ReplayGain developer
QUOTE (spindle @ Mar 4 2012, 11:12) *
Imagine you're measuring it with a ruler.
"Finer Granularity" means more (closer) tick marks on your ruler. There's always some discrepancy between the distance you're measuring, and the nearest mark to it on your ruler.
The difference between the real value and the nearest tick mark is an error.
You know the maximum error in any case: it's half the distance between the rick marks - because that's the greatest amount you'll have to round up (or down) to hit a tick mark.
In audio, when the audio signal you've stored isn't quite what you started out with, the difference is noise*. So now we know how much noise has been added due to "measuring" - a noise level equal to half the distance between the "tick marks". Calculate this, and that noise turns out to be nearly 100dB below the maximum signal level.
Given the sound levels in real life, and the ones our ears can cope with, that's enough. Pushing the measurement noise further down by increasing the number of bits does give close tick marks = "finer granularity", but the improvement is inaudible. It's also tricky to go much beyond 16-bits because basic electronics have ~20-bits of noise at best - and everything, from microphone through mixing desk to amplifier needs electronics - not to mention the digital/analogue converters.
* - it could be noise or distortion, but we'll use dither to ensure it's never distortion and always noise. We'll probably also use noise shaping to push the noise level further down in the most audible range, at the expense of slightly more noise at the frequency extremes where our ears aren't so sensitive.
- botface   16 bit, 24 bit and Noise Floor   Feb 28 2012, 20:13
- - saratoga   You are correct and those people you quoted do not...   Feb 28 2012, 20:17
- - greynol   As a simple experiment, you can create a pure tone...   Feb 28 2012, 20:18
|- - Ethan Winer   QUOTE (greynol @ Feb 28 2012, 14:18) As a...   Mar 1 2012, 19:59
|- - Glenn Gundlach   QUOTE (greynol @ Feb 28 2012, 11:18) As a...   Mar 2 2012, 07:36
|- - Garf   QUOTE (Glenn Gundlach @ Mar 2 2012, 07:36...   Mar 2 2012, 12:07
|- - Arnold B. Krueger   This is another one of those situations where your...   Mar 2 2012, 14:02
|- - 2Bdecided   QUOTE (Arnold B. Krueger @ Mar 2 2012, 13...   Mar 3 2012, 19:56
- - hlloyge   Oh, just work in 24 bits so you can have more prec...   Feb 28 2012, 20:21
- - DVDdoug   Let's look at the "ruler" example - ...   Feb 28 2012, 20:26
- - greynol   Please, before submitting any more abject analogie...   Feb 28 2012, 20:43
|- - saratoga   QUOTE (greynol @ Feb 28 2012, 14:43) Plea...   Feb 28 2012, 20:51
|- - Garf   QUOTE (greynol @ Feb 28 2012, 20:43) Plea...   Feb 29 2012, 15:48
- - KMD   greynol is right, sounds below the noise floor are...   Feb 28 2012, 20:46
- - greynol   You're right. Case in point: create a 1k tone...   Feb 28 2012, 21:22
|- - saratoga   QUOTE (greynol @ Feb 28 2012, 15:22) You...   Feb 28 2012, 21:30
- - mjb2006   Most explanations—even those for technical audienc...   Feb 28 2012, 21:22
|- - spindle   QUOTE (mjb2006 @ Feb 28 2012, 20:22) Most...   Mar 4 2012, 12:12
|- - saratoga   QUOTE (spindle @ Mar 4 2012, 06:12) Forgi...   Mar 5 2012, 07:53
|- - Arnold B. Krueger   QUOTE (spindle @ Mar 4 2012, 06:12) Forgi...   Mar 5 2012, 13:27
||- - spindle   QUOTE (Arnold B. Krueger @ Mar 5 2012, 12...   Mar 6 2012, 13:36
|- - 2Bdecided   QUOTE (spindle @ Mar 4 2012, 11:12) Forgi...   Mar 7 2012, 11:41
- - greynol   I should have led with my second example.   Feb 28 2012, 21:39
- - WernerO   QUOTE (botface @ Feb 28 2012, 20:13) I...   Feb 29 2012, 08:36
|- - knutinh   QUOTE (WernerO @ Feb 29 2012, 09:36) That...   Feb 29 2012, 11:00
|- - Arnold B. Krueger   QUOTE (knutinh @ Feb 29 2012, 05:00) QUOT...   Mar 2 2012, 01:24
- - icstm   your point about single tones vs white noise is al...   Feb 29 2012, 18:56
|- - Garf   QUOTE (icstm @ Feb 29 2012, 18:56) your p...   Mar 1 2012, 08:40
|- - botface   QUOTE (Garf @ Mar 1 2012, 07:40) The orig...   Mar 1 2012, 10:13
- - 2Bdecided   Try lossyWAV with --bitdist to see how many bits i...   Mar 1 2012, 10:51
|- - Garf   QUOTE (2Bdecided @ Mar 1 2012, 10:51) Try...   Mar 1 2012, 11:19
- - googlebot   A noise floor can be considered part of the signal...   Mar 2 2012, 20:59
|- - knutinh   QUOTE (googlebot @ Mar 2 2012, 21:59) A n...   Mar 2 2012, 21:09
|- - googlebot   As discussed earlier in the thread it is not trivi...   Mar 2 2012, 21:18
|- - Garf   QUOTE (knutinh @ Mar 2 2012, 21:09) QUOTE...   Mar 4 2012, 10:12
- - Notat   I wish I knew of such a reference. I'll take a...   Mar 5 2012, 05:45
- - bandpass   Here's a wood-working analogy Suppose that y...   Mar 5 2012, 15:16
|- - icstm   QUOTE (bandpass @ Mar 5 2012, 14:16) Here...   Mar 6 2012, 11:05
- - icstm   QUOTE (Garf @ Mar 2 2012, 11:07) As far a...   Mar 5 2012, 16:51
|- - Arnold B. Krueger   QUOTE (icstm @ Mar 5 2012, 10:51) QUOTE (...   Mar 5 2012, 17:34
|- - Arnold B. Krueger   QUOTE (icstm @ Mar 5 2012, 10:51) QUOTE (...   Mar 5 2012, 17:45
|- - googlebot   QUOTE (Arnold B. Krueger @ Mar 5 2012, 17...   Mar 5 2012, 20:52
|- - icstm   QUOTE (Arnold B. Krueger @ Mar 5 2012, 16...   Mar 6 2012, 10:53
|- - Arnold B. Krueger   QUOTE (icstm @ Mar 6 2012, 04:53) QUOTE (...   Mar 6 2012, 14:12
|- - 2Bdecided   QUOTE (icstm @ Mar 6 2012, 09:53) OK, but...   Mar 7 2012, 11:55
- - Wombat   What about a simple experiment? Create a silent 16...   Mar 5 2012, 21:15
|- - googlebot   QUOTE (Wombat @ Mar 5 2012, 21:15) What a...   Mar 5 2012, 21:18
- - Wombat   QUOTE (googlebot @ Mar 5 2012, 21:18) Tha...   Mar 5 2012, 21:22
- - icstm   I understand that. So I guess the problem is with ...   Mar 7 2012, 13:46
- - KMD   Noise "floor" is an bad phrase as signal...   Mar 7 2012, 13:53
RSS Lo-Fi Version Time is now: 28th February 2015 - 14:59
