Which is the highest frequency that You can hear?
Which is the highest frequency that You can hear (at normal loudness level)?
8 kHz [ 1 ] ** [0.92%]
10 kHz [ 2 ] ** [1.83%]
12 kHz [ 9 ] ** [8.26%]
14 kHz [ 7 ] ** [6.42%]
15 kHz [ 16 ] ** [14.68%]
16 kHz [ 18 ] ** [16.51%]
17 kHz [ 27 ] ** [24.77%]
18 kHz [ 13 ] ** [11.93%]
19 kHz [ 5 ] ** [4.59%]
20 kHz and higher [ 11 ] ** [10.09%]
Total Votes: 122
IgorC
post Feb 24 2012, 01:33
It will be interesing to see hearing abilities of Hydrogenaudio's members.
http://www.noiseaddicts.com/2009/03/can-yo...s-hearing-test/
Please perform the test on your normal loudness levels.
sizetwo
post Feb 24 2012, 07:49
17 khz, 36 year old using speakers.
- IgorC   Which is the highest frequency that You can hear?   Feb 24 2012, 01:33
- - marc2003   just 12kHz here. 35 years old.   Feb 24 2012, 01:48
- - eahm   QUOTE (marc2003 @ Feb 23 2012, 17:48) jus...   Feb 24 2012, 02:25
- - Batman321   17 KHz here. 35 Years old.   Feb 24 2012, 02:48
- - kraut   via earphones 15kHz, 62 years.   Feb 24 2012, 04:11
- - IgorC   As headphones genereally are more revealing, I...   Feb 24 2012, 04:35
|- - Kujibo   QUOTE (IgorC @ Feb 23 2012, 19:35) As hea...   Feb 24 2012, 08:16
|- - mjb2006   QUOTE (Kujibo @ Feb 24 2012, 00:16) With ...   Feb 24 2012, 18:10
- - Xrcr9709   I hear up to 15kHz, I "guess" a sound at...   Feb 24 2012, 04:44
- - sizetwo   17 khz, 36 year old using speakers.   Feb 24 2012, 07:49
- - onkl   I had to record the output just to check if there...   Feb 24 2012, 08:48
- - halb27   'folding back down to lower frequencies' p...   Feb 24 2012, 10:08
|- - Kujibo   QUOTE (halb27 @ Feb 24 2012, 01:08) @Kuji...   Feb 24 2012, 22:27
|- - greynol   QUOTE (halb27 @ Feb 24 2012, 01:08) ...   Feb 26 2012, 21:57
- - dhromed   30 years. ~17.2KHz using a 16-18KHz sweep in fooba...   Feb 24 2012, 10:18
|- - Arnold B. Krueger   QUOTE (dhromed @ Feb 24 2012, 04:18) 30 y...   Feb 24 2012, 13:28
||- - dhromed   QUOTE (Arnold B. Krueger @ Feb 24 2012, 13...   Feb 24 2012, 14:17
|- - Remedial Sound   QUOTE (dhromed @ Feb 24 2012, 04:18) Ther...   Feb 24 2012, 19:05
|- - lvqcl   QUOTE (Remedial Sound @ Feb 24 2012, 22:0...   Feb 24 2012, 19:56
|- - Remedial Sound   QUOTE (lvqcl @ Feb 24 2012, 13:56) QUOTE ...   Feb 25 2012, 03:11
|- - dhromed   QUOTE (Remedial Sound @ Feb 25 2012, 03:1...   Feb 25 2012, 14:36
|- - Ed Seedhouse   Well, at age 68 I hear sounds right up to 15 khz, ...   Feb 25 2012, 15:45
|- - Intruder66   15 kHz with (mid-quality) speakers at the age of 1...   Feb 25 2012, 16:38
|- - dhromed   QUOTE (Intruder66 @ Feb 25 2012, 16:38) 1...   Feb 25 2012, 18:51
- - skamp   I'm almost 30 years old, and I could hear all ...   Feb 24 2012, 11:26
- - C.R.Helmrich   If you are running Windows 7 (or Vista probably), ...   Feb 24 2012, 13:42
- - pdq   Only up to 12 kHz (tested two years ago when I was...   Feb 24 2012, 14:32
- - Martel   This test is totally messed up under Linux (Ubuntu...   Feb 24 2012, 15:42
- - LithosZA   Up to 18Khz in foobar2000 WASAPI output -> 16bi...   Feb 24 2012, 15:54
- - zipr   Equipment and environment can make a big differenc...   Feb 24 2012, 16:21
- - kode54   15KHz and 30 years old. Also, be careful with not...   Feb 24 2012, 17:12
- - halb27   16 kHz, age 62. Thank you, mjb2006, for the link t...   Feb 24 2012, 19:12
|- - mjb2006   QUOTE (halb27 @ Feb 24 2012, 11:12) 16 kH...   Feb 24 2012, 20:40
|- - onkl   QUOTE (halb27 @ Feb 24 2012, 19:12) 16 kH...   Feb 25 2012, 07:59
- - halb27   Thanks for the advice. I will do it.   Feb 25 2012, 00:01
- - extrabigmehdi   18 khz, and almost 35 years old, so my ears are st...   Feb 25 2012, 01:02
- - m45t3r   18kHZ with phones, 17kHz with speaker. I'm 2...   Feb 25 2012, 03:23
- - robojock   17 kHz, age 33   Feb 25 2012, 06:31
- - extrabigmehdi   Hum I've redone the test with the speakers, an...   Feb 25 2012, 06:49
- - iGold   My hearing limit is 17kHz (37 years old), my wife ...   Feb 25 2012, 08:47
- - Steve Forte Rio   Left ear - ~18 kHz, right ear - ~18.5 kHz (my own ...   Feb 25 2012, 12:13
- - derty2   I am over 40 years of age, I could hear all tones ...   Feb 25 2012, 16:57
- - no404error   17/19kHz (speakers/headphones), 30 y/o.   Feb 25 2012, 18:16
- - dhromed   Is it possible to produce some samples of intentio...   Feb 25 2012, 18:54
|- - saratoga   QUOTE (dhromed @ Feb 25 2012, 12:54) Is i...   Feb 26 2012, 01:16
|- - C.R.Helmrich   QUOTE (saratoga @ Feb 26 2012, 02:16) QUO...   Feb 26 2012, 12:20
- - somemightsay   When I first ran the tests, I had the TV on a litt...   Feb 25 2012, 19:10
- - halb27   I tried all the advices given here on my standard ...   Feb 26 2012, 00:58
- - mudlord   22khz, 23 y/o Sennheiser HD201   Feb 26 2012, 01:16
|- - saratoga   QUOTE (mudlord @ Feb 25 2012, 19:16) 22kh...   Feb 26 2012, 04:59
- - googlebot   Being synaesthetic the answer should be about 790 ...   Feb 26 2012, 01:25
- - millifoo   17khz on Sennheiser HD600's. I'm 46 years ...   Feb 26 2012, 01:53
|- - Kujibo   QUOTE (millifoo @ Feb 25 2012, 16:53) 17k...   Feb 26 2012, 21:38
- - FreaqyFrequency   17k, 20 years old. I'm okay with this.   Feb 26 2012, 03:42
- - Emon   Tested myself using my EMU 1212m, the software has...   Feb 26 2012, 04:06
- - hlloyge   Somewhere between 16.5 and 17 kHz, 37 yrs old.   Feb 26 2012, 10:32
- - [JAZ]   15Khz here. Looks like my hearing has worsened the...   Feb 26 2012, 11:15
- - randal1013   i can definitely hear 17khz. 18 and up i hear *som...   Feb 26 2012, 12:49
- - 2012   Had to download the files and upsample to 48000 (T...   Feb 26 2012, 18:49
- - Reiginsei   I can't hear anything past 14 kHz. But on hea...   Feb 26 2012, 19:06
- - greynol   I'm glad to see that I can still faintly hear ...   Feb 26 2012, 19:15
- - RealityRipple   Plugged in some cheap Samsung earbuds, cranked my ...   Feb 26 2012, 21:34
- - AllanP   I can hear 19 KHz very strong and 20 KHz weak, my ...   Feb 26 2012, 21:55
- - extrabigmehdi   I have done again the test , and this time perhap...   Feb 27 2012, 01:13
|- - saratoga   QUOTE (extrabigmehdi @ Feb 26 2012, 19:13...   Feb 27 2012, 01:16
|- - extrabigmehdi   QUOTE (saratoga @ Feb 27 2012, 00:16) QUO...   Feb 27 2012, 01:43
|- - IgorC   QUOTE (extrabigmehdi @ Feb 26 2012, 21:43...   Feb 27 2012, 01:56
|- - extrabigmehdi   QUOTE (IgorC @ Feb 27 2012, 00:56) QUOTE ...   Feb 27 2012, 02:06
|- - saratoga   QUOTE (extrabigmehdi @ Feb 26 2012, 20:06...   Feb 27 2012, 02:26
- - christopher   QUOTE (Martel @ Feb 24 2012, 14:42) This ...   Feb 27 2012, 01:59
|- - greynol   QUOTE (christopher @ Feb 26 2012, 16:59) ...   Feb 27 2012, 02:41
|- - christopher   QUOTE (greynol @ Feb 27 2012, 01:41) QUOT...   Feb 27 2012, 03:13
|- - extrabigmehdi   QUOTE (greynol @ Feb 27 2012, 01:41) QUOT...   Feb 27 2012, 03:14
- - IgorC   Also a simple analysis can be applied. And some p...   Feb 27 2012, 02:18
- - greynol   There is no such problem with Audition. FWIW I ha...   Feb 27 2012, 03:47
- - christopher   I guess I'll just mark it down to bad luck on ...   Feb 27 2012, 04:26
- - saratoga   So I guess the take home here is that 74% of peopl...   Feb 27 2012, 04:54
- - IgorC   That's mine conclusion as well. Just a simple...   Feb 27 2012, 05:50
- - greynol   20kHz or more is the sum of bins 20kHz, 21kHz and ...   Feb 27 2012, 06:15
- - IgorC   Yep, I was thinking of that too. Considering eac...   Feb 27 2012, 06:25
- - greynol   I don't find it unreasonable to think that the...   Feb 27 2012, 06:31
- - IgorC   Great, Greynol. But wait. This time lets think ...   Feb 27 2012, 06:57
|- - mzil   QUOTE (IgorC @ Feb 27 2012, 00:57) Sugges...   Feb 27 2012, 09:09
- - halb27   The graphs show what I wrote about earlier in this...   Feb 27 2012, 10:27
- - Bjossi   17 kHz, 23 years old. I hear 17 kHz pretty clearly...   Feb 27 2012, 17:14
|- - BoraBora   I donwloaded the samples in wav then listened to t...   Feb 28 2012, 02:18
- - smz   Strange: using the noiseaddicts.com test I can hea...   Feb 28 2012, 03:51
- - IgorC   I will ask Administrators to close this poll. A ne...   Feb 28 2012, 04:15
Closed TopicStart new topic
RSS Lo-Fi Version Time is now: 5th August 2015 - 10:24
