Make Foobar2000 to remove files from hard drive, Moved from Development (TOS #6)
daved92pol1
post Feb 21 2012, 11:56
Hello, I use Foobar as my default music player, I was wondering if theres possible way to select and remove music from the list and pernamently of hard drive ?
the steps are: theres a song on the list, that i want to get rid of it even from hard drive, so i did by selecting remove pernamently, from list and hard drive but it might play still that song
after when its done, i might get it back because foobar is still playing this song which it might have it still on RAM untill the song has change so software will remove it from RAM
its just like music player in Ubuntu/Kubuntu called Amarok 1.4.10
tpijag
post Feb 21 2012, 15:01
The context menu REMOVE option is intended to remove track from playlist. It is not a delete command. You need to use the context menu FILE OPERATIONS >Delete file option.
If you do not have that option, reinstall foobar2000 over your existing install and install -file operations- option during insta..
EagleScout1998
post Feb 21 2012, 18:03
A follow up question: Is it possible, when deleting a file via foobar2000, to have file actually be deleted rather than sent to the Recycle Bin?
daved92pol1
post Feb 21 2012, 21:45
as far as i know, Amarok doesn't put song to recycle bin, it stays in RAM, thats what i saw when i removed 120MB track in linux, the memory increased by 120MB of the software that it used to run. and about that file operating, i cant find it after reinstalling foobar2000
marc2003
post Feb 21 2012, 21:48
file operations is an extra component you have to select manually during install. read each dialog before clicking next...
daved92pol1
post Feb 21 2012, 21:52
I've got it, thank you , now its easier to manipulate playlists
RSS Lo-Fi Version Time is now: 4th May 2015 - 16:27
