2 Pages V  < 1 2
Representing frequency of n Hz needs sampling rate >2n Hz, not =2n, From: Badly drawn waveforms vs. the audio thatís actually output/93496
pdq
post Feb 22 2012, 19:52
Post #26
I recall a study in which members of an orchestra were asked to compare two tones very close in frequency (I think it was A440).
Many of the members were able to distinguish tones only 1 Hz apart, and one member was able to distinguish tones only 0.1 Hz apart.
I then ask myself, did he need to hear the tones for a full ten seconds each so that there was one full cycle difference between them?
greynol
post Feb 22 2012, 19:54
Post #27
Regarding what happens at the edges, sinc pulses die out fairly rapidly, don't they; especially when realistic levels are taken into account?
This post has been edited by greynol: Feb 22 2012, 20:29
Anyone having rabbit for Easter?
Woodinville
post Feb 22 2012, 20:25
Post #28
QUOTE (xnor @ Feb 22 2012, 10:20) *
Even a 8192 samples long filter doesn't cause anything I could hear. Maybe because the passband has to be a lower to make the filter audible, e.g. 18 kHz instead of 21 kHz? Anyway the filter is quite steep. -6 dB at 21 kHz and -90 dB at 21.0157 kHz.
You want to make the filter as steep as possible, not with as much rejection as possible. If I had access to matlab right now I'd give you firpm paramaters, but I tried what I recall in octave via remez and it just died instead. sad.gif
J. D. (jj) Johnston
Woodinville
post Feb 22 2012, 20:27
Post #29
QUOTE (pdq @ Feb 22 2012, 10:52) *
Different problem than you're thinking of for frequency determination, you have here a fixed reference, and a high SNR environment to determine match or not.
J. D. (jj) Johnston
xnor
post Feb 22 2012, 21:07
Post #30
QUOTE (Woodinville @ Feb 22 2012, 20:25) *
It doesn't get much steeper than that with 8192 samples. I used a windowed sinc filter (Fc=21 kHz) and chose the best window function I could find to give about 90 dB rejection - not more - in my second try. Diffing the original file with the filtered one leaves some high frequency, low level ringing behind. Can't hear that either at normal levels.
This post has been edited by xnor: Feb 22 2012, 21:11
"we are having an educated and deep technical discussion"-amirm
bandpass
post Feb 22 2012, 22:57
Post #31
QUOTE (greynol @ Feb 22 2012, 18:54) *
Not really; it's because they they die out slowly that we need to window them to make reasonably-lengthed filters.
QUOTE (Woodinville @ Feb 22 2012, 19:25) *
You can use sox to create some sharp FIRs (if you're happy to use a slightly longer filter than remez/firpm would give); e.g.
sox castanets-2_2496.wav output.wav sinc -a 90 -n 32767 -21k
For 90dB attenuation low-pass, 32767 taps, 6dB corner @ 21kHz; which gives a TBW of 16.6Hz.
Porcus
post Feb 23 2012, 00:04
Post #32
QUOTE (greynol @ Feb 22 2012, 19:49) *
A simple impulse will set them in motion, just like any other mechanical device.
That is not to say that this 'motion' can be used to detect a frequency.
Woodinville
post Feb 23 2012, 05:00
Post #33
QUOTE (bandpass @ Feb 22 2012, 13:57) *
What I'm thinking of and trying to build is a remez-designed filter with a cutoff frequency of 20kHz and a -90dB point of about 20050 (not 22050!) Hz. I managed do that after some fiddling in Matlab. No such luck in octave.
I'm not saying that it's a good idea to use such a filter, to be sure.
It's also possible to make a "bad" filter by having too much passband ripple, but that's kind of cheating.
J. D. (jj) Johnston
icstm
post Feb 23 2012, 11:16
Post #34
That brings back memories, problem is I cannot remember any of it now. I would probably have to review my own code (I became quite good to commenting my code to read like pseudo code, which should hopefully help me now). Now all I need to do is dig out my old 10-yr old PC that should still have a copy of MatLab...
2 Pages V  < 1 2
RSS Lo-Fi Version Time is now: 26th March 2015 - 20:20
