Playback statistics, Show recently played - shows nothing, Split from: "foo_playcount crash" (topic 89667) (TOS #5)
djchristian
post Feb 19 2012, 03:05
foo_playcount doesn't work for me. Using foobar2000 v1.1.10
This post has been edited by db1989: Feb 19 2012, 06:47
Reason for edit: deleting pointless full quote of above post
tpijag
post Feb 19 2012, 04:17
Are you expecting any sort of valid troubleshooting assistance? Should we guess whether you are having the exact same issue as what you quoted from 6 months ago? Here is some help offered with an effort to match the level of thought you gave to your post. wink.gif
foo_playcount works for me
Maybe you could provide more detail?
This post has been edited by tpijag: Feb 19 2012, 04:18
db1989
post Feb 19 2012, 06:55
As was pointed out in post #2, foo_playcount is not a “3rd Party Plugin”. It is developed by Peter, the author of foobar2000. This thread has been moved to Support, the correct location for topics regarding apparent problems with the main application and official components.
This post has been edited by db1989: Feb 19 2012, 06:57
djchristian
post Feb 19 2012, 08:30
QUOTE (tpijag @ Feb 19 2012, 05:17) *
Well im running Win 7 64. Other than that if i go to Library --> Playback statistics --> Show recently played, it shows nothing and it's empty no matter how many tracks i've played.
This post has been edited by djchristian: Feb 19 2012, 08:40
lvqcl
post Feb 19 2012, 09:44
1. Make sure that Library -> Playback Statistics -> Monitor playing tracks is checked.
2. Are these files in fb2k library?
djchristian
post Feb 19 2012, 10:58
QUOTE (lvqcl @ Feb 19 2012, 10:44) *
1. Already checked
2. If you mean the dll file it's in the components dir of fb2k. The files/tracks are on another drive.
lvqcl
post Feb 19 2012, 11:32
I mean that the tracks should be in monitored folders. Open Preferences -> Media Library and add folder(s) with audio files to the library.
tpijag
post Feb 19 2012, 17:40
This thread now has a new OP since his problem has nothing to do with with his original quoted text and has been cut off to it's own thread. At the risk of being pedantic, I would like to ask the OP to at least skim read through the Forum rules posted at the top of this thread. There is also a link to a nice big sticky post that could be read. If the poster would consider letting us know what version of foo_playcount is being used we all may avoid chasing about empty rabbit holes. The component has changed quite a bit over time and if using the newest version, chasing about library issue might be pointless, YMMV:
Starting from version 3.0, collection of playback statistics is no longer restricted to your Media Library content. You can use this component without using Media Library at all, however, you should keep your non-ML music referenced from a playlist for foobar2000 to maintain the statistics.
EDIT: could you confirm that the tracks you are testing are playing until completion of track or the minimum 60 seconds needed to register as played?
This post has been edited by tpijag: Feb 19 2012, 17:44
djchristian
post Feb 24 2012, 02:35
QUOTE (lvqcl @ Feb 19 2012, 11:32) *
Thanks it works, well sorta. It only lists the last tracks i've played if i played them for a certain amount of time like one minute or something? If i switch them fast or just browsing between the tracks it won't show up in the recently played list at all.
tpijag
post Feb 24 2012, 03:31
^^^^^one post up^^^^you are seeing the behavior of the component as designed
This post has been edited by tpijag: Feb 24 2012, 03:33
djchristian
post Feb 25 2012, 00:19
QUOTE (tpijag @ Feb 24 2012, 03:31) *
Can i change that 60 seconds mark to for example 1 second?
Andreasvb
post Feb 25 2012, 00:43
No, only the developer of the component.
Windows 8.1u3 Pro x64 Media Center // foobar2000 1.3.7
RSS Lo-Fi Version Time is now: 6th March 2015 - 18:46
