Massive problem with fb2k 1.1.11, when I fiddle around with the preferences, entire computer hangs
makasin
post Feb 18 2012, 12:56
Hey guys, so I just recently acquired a massive issue with foobar on my computer. Whenever I try to access any options and change stuff, for example: I was trying to change some params for transcoding to my ipod, or trying to change audio output method, or really anything once I hit "Apply" foobar starts to hang, then my ENTIRE computer hangs. This has happened to me before using firefox, where I had to reinstall and create a new profile or else it would hang my system. It could be that I am using a very old win7 install that has accumulated lots of shit over the years. I transferred it to an SSD since I didnt want to lose data. ANYWAYS, the problem is very serious and only started once I installed the latest version. I was working on 1.1.10 and it was wonderful. First it started showing the "failed to locate function AMDeviceNotificationGetThreadHandle" on runtime. I know this pertains to the ipod manager and isnt supported by this subforum, but after the new install everything went to hell. I tried resetting all settings (which completely erased my beautiful UI I made for myself, stupid I didnt backup, as well as my entire media library), still nada. Then I uninstalled foobar and reinstalled it, still crapped out. This all happened when I moved my components to the new folder, I think. I am not overclocking anything, nothing terribly special about my setup. I re-enabled all the non-essential services I disabled, which were disabled the entire time I was running foobz flawlessly. Anywho, foobar troubleshooter said this:
The following components found on your system are known to be problematic and should be either uninstalled or updated to their latest versions:
foo_dynamic_range.dll : Dynamic Range Meter 1.0.0
Reason: Repeated crash reports.
foo_vst.dll : VST 2.4 adapter 0.9.0.3
foo_musicbrainz.dll : MusicBrainz Tagger 0.3 beta 2
And here is the latest failure 4.txt (generated 2/18/2012 1:41, before i guess it REALLY started to fuck my system sideways and hang it up)
I uninstalled all of those, and still issues. It generated a few crash reports (but not all of em, since the entire system collapsed)
Illegal operation:
Code: C0000005h, flags: 00000000h, address: 722029E1h
Access violation, operation: write, address: 722029E1h
Call path not available.
Stack (0B9AF794h):
0B9AF774h: 00000000 FFFFFD34 000002E4 FFFFFD34
0B9AF784h: 000002CC 00000019 00000000 00000000
0B9AF794h: 74B5339A 0AE97D80 0B9AF7DC 77119EF2
0B9AF7A4h: 0AE97D80 7C810AF5 00000000 00000000
0B9AF7B4h: 0AE97D80 C0000005 74B776F7 74B776F7
0B9AF7C4h: 0B9AF7A8 0B9AF35C FFFFFFFF 771571D5
0B9AF7D4h: 000B3819 00000000 0B9AF7F4 77119EC5
0B9AF7E4h: 722029E1 0AE97D80 00000000 00000000
0B9AF7F4h: 00000000 00000000 722029E1 0AE97D80
0B9AF804h: 00000000 00000000 00000000 00000000
0B9AF814h: 00000000 00000000 00000000 00000000
0B9AF824h: 00000000 00000000 00000000 00000000
0B9AF834h: 00000000 00000000 00000000 00000000
0B9AF844h: 00000000 00000000 00000000 00000000
0B9AF854h: 00000000 00000000 00000000 00000000
0B9AF864h: 00000000 00000000 00000000 00000000
0B9AF874h: 00000000 00000000 00000000 00000000
0B9AF884h: 00000000 00000000 00000000 00000000
0B9AF894h: 00000000 00000000 00000000 00000000
0B9AF8A4h: 00000000 00000000 00000000 00000000
Registers:
EAX: 74B53388, EBX: 0AE97D80, ECX: 00000000, EDX: 722029E1
ESI: 00000000, EDI: 00000000, EBP: 0B9AF79C, ESP: 0B9AF794
Unable to identify crash location!
Loaded modules:
foobar2000 loaded at 001A0000h - 00356000h
ntdll loaded at 770E0000h - 77260000h
kernel32 loaded at 74B40000h - 74C50000h
KERNELBASE loaded at 74AF0000h - 74B36000h
COMCTL32 loaded at 6F080000h - 6F21E000h
msvcrt loaded at 74CB0000h - 74D5C000h
GDI32 loaded at 76220000h - 762B0000h
USER32 loaded at 74880000h - 74980000h
ADVAPI32 loaded at 75F40000h - 75FE0000h
sechost loaded at 76710000h - 76729000h
RPCRT4 loaded at 75B80000h - 75C70000h
SspiCli loaded at 747C0000h - 74820000h
CRYPTBASE loaded at 747B0000h - 747BC000h
LPK loaded at 76110000h - 7611A000h
USP10 loaded at 763D0000h - 7646D000h
SHLWAPI loaded at 74820000h - 74877000h
DSOUND loaded at 735B0000h - 73622000h
ole32 loaded at 74990000h - 74AEC000h
WINMM loaded at 71FD0000h - 72002000h
POWRPROF loaded at 73580000h - 735A5000h
SETUPAPI loaded at 759E0000h - 75B7D000h
CFGMGR32 loaded at 761F0000h - 76217000h
OLEAUT32 loaded at 75EB0000h - 75F3F000h
DEVOBJ loaded at 75E60000h - 75E72000h
UxTheme loaded at 70DD0000h - 70E50000h
SHELL32 loaded at 74D90000h - 759DA000h
zlib1 loaded at 5A4C0000h - 5A4D4000h
shared loaded at 73A30000h - 73A5B000h
imagehlp loaded at 75E80000h - 75EAA000h
dbghelp loaded at 6DA00000h - 6DAEB000h
COMDLG32 loaded at 76690000h - 7670B000h
gdiplus loaded at 70E90000h - 71020000h
Secur32 loaded at 71860000h - 71868000h
CRYPT32 loaded at 762B0000h - 763CD000h
MSASN1 loaded at 74980000h - 7498C000h
IMM32 loaded at 76470000h - 764D0000h
MSCTF loaded at 75C70000h - 75D3C000h
HsSrv2 loaded at 10000000h - 10037000h
VERSION loaded at 72620000h - 72629000h
dwmapi loaded at 70DB0000h - 70DC3000h
foo_cdda loaded at 6BB00000h - 6BB4E000h
foo_dsp_effect loaded at 00360000h - 0039A000h
foo_dsp_echo loaded at 003A0000h - 003BE000h
foo_tradersfriend loaded at 739F0000h - 73A27000h
foo_lock loaded at 00500000h - 00519000h
foo_fileops loaded at 6BAB0000h - 6BAF7000h
foo_input_std loaded at 6B950000h - 6BAAB000h
foo_dsp_channeldividerF loaded at 00760000h - 0078C000h
foo_chacon loaded at 6B920000h - 6B944000h
foo_freedb2 loaded at 6B8E0000h - 6B920000h
foo_albumlist loaded at 6B880000h - 6B8DC000h
foo_uie_playlists_dropdown loaded at 02620000h - 0265C000h
foo_burninate loaded at 6B840000h - 6B87E000h
foo_convolve loaded at 026B0000h - 02701000h
foo_comserver2 loaded at 02710000h - 02766000h
foo_input_monkey loaded at 02790000h - 027D9000h
foo_ui_std loaded at 6B750000h - 6B835000h
MSIMG32 loaded at 71190000h - 71195000h
foo_dsp_prvb loaded at 027E0000h - 0280B000h
foo_dsp_std loaded at 6B700000h - 6B748000h
foo_verifier loaded at 02970000h - 029B3000h
foo_out_wasapi loaded at 02B80000h - 02BA6000h
foo_out_ks loaded at 02BB0000h - 02BDA000h
foo_vis_shpeck loaded at 6B6B0000h - 6B6F1000h
foo_masstag loaded at 046F0000h - 04744000h
foo_infospect loaded at 03370000h - 033A7000h
foo_dop loaded at 05560000h - 05730000h
WS2_32 loaded at 761B0000h - 761E5000h
NSI loaded at 76100000h - 76106000h
QUARTZ loaded at 6B530000h - 6B6A7000h
foo_dsp_dolbyhp loaded at 6B500000h - 6B524000h
foo_playcount loaded at 6B4C0000h - 6B4FE000h
foo_dsp_xover loaded at 04760000h - 047A4000h
foo_bitcompare loaded at 04920000h - 04948000h
foo_r128norm loaded at 6B490000h - 6B4B6000h
foo_input_dts loaded at 6B420000h - 6B483000h
foo_unpack loaded at 6B3F0000h - 6B41E000h
foo_podcatcher loaded at 04F00000h - 04F86000h
foo_midi loaded at 6B310000h - 6B3ED000h
BASS loaded at 11000000h - 11063000h
MSACM32 loaded at 6B2F0000h - 6B304000h
BASSMIDI loaded at 10600000h - 10632000h
foo_vst loaded at 6B290000h - 6B2E4000h
foo_dsp_channeldividerF2B loaded at 04B30000h - 04B5D000h
foo_ui_columns loaded at 05CD0000h - 05E5C000h
foo_w7shell loaded at 04C80000h - 04CBD000h
foo_dynamic_range loaded at 04E10000h - 04E6D000h
foo_osd loaded at 04CC0000h - 04CF1000h
foo_converter loaded at 6B210000h - 6B28C000h
foo_out_asio loaded at 04EB0000h - 04EE2000h
foo_rgscan loaded at 6B1C0000h - 6B20B000h
CLBCatQ loaded at 76120000h - 761A3000h
USERENV loaded at 725F0000h - 72607000h
profapi loaded at 721F0000h - 721FB000h
ntmarta loaded at 71CB0000h - 71CD1000h
WLDAP32 loaded at 74C60000h - 74CA5000h
propsys loaded at 6EDF0000h - 6EEE5000h
LINKINFO loaded at 6D960000h - 6D969000h
apphelp loaded at 6E1A0000h - 6E1EC000h
gameux loaded at 6AF40000h - 6B1B8000h
XmlLite loaded at 6AF10000h - 6AF3F000h
wer loaded at 6EFD0000h - 6F031000h
ntshrui loaded at 6AEA0000h - 6AF10000h
srvcli loaded at 71610000h - 71629000h
cscapi loaded at 6DAF0000h - 6DAFB000h
slc loaded at 6E180000h - 6E18A000h
CRYPTSP loaded at 721D0000h - 721E6000h
rsaenh loaded at 72180000h - 721BB000h
WindowsCodecs loaded at 73AB0000h - 73BAB000h
explorerframe loaded at 6AD30000h - 6AE9F000h
DUser loaded at 6AD00000h - 6AD2F000h
DUI70 loaded at 6AC40000h - 6ACF2000h
WINTRUST loaded at 74D60000h - 74D8D000h
sud loaded at 6AB80000h - 6AC3B000h
ADVPACK loaded at 6AB50000h - 6AB7E000h
mswsock loaded at 71C70000h - 71CAC000h
wshtcpip loaded at 71C60000h - 71C65000h
wship6 loaded at 6E0A0000h - 6E0A6000h
WLIDNSP loaded at 6D7C0000h - 6D7E7000h
PSAPI loaded at 770B0000h - 770B5000h
DNSAPI loaded at 6D7F0000h - 6D834000h
mdnsNSP loaded at 725C0000h - 725E1000h
Iphlpapi loaded at 71D20000h - 71D3C000h
WINNSI loaded at 71D10000h - 71D17000h
rasadhlp loaded at 725B0000h - 725B6000h
fwpuclnt loaded at 73A60000h - 73A98000h
Stack dump analysis:
Address: 74B5339Ah (kernel32+1339Ah), symbol: "BaseThreadInitThunk" (+12h)
Address: 77119EF2h (ntdll+39EF2h), symbol: "RtlInitializeExceptionChain" (+63h)
Address: 74B776F7h (kernel32+376F7h), symbol: "UnhandledExceptionFilter" (+0h)
Address: 771571D5h (ntdll+771D5h), symbol: "WinSqmSetIfMaxDWORD" (+31h)
Address: 77119EC5h (ntdll+39EC5h), symbol: "RtlInitializeExceptionChain" (+36h)
Environment:
App: foobar2000 v1.1.11
UI: Default User Interface 0.9.5
Components:
Core (2012-02-04 13:05:48 UTC)
foobar2000 core 1.1.11
foo_albumlist.dll (2012-02-04 13:04:12 UTC)
Album List 4.5
foo_bitcompare.dll (2008-12-05 22:08:02 UTC)
Binary Comparator 1.2
foo_burninate.dll (2012-02-18 08:29:29 UTC)
Audio CD Writer 3.0.3
foo_cdda.dll (2012-02-04 13:03:52 UTC)
CD Audio Decoder 3.0
foo_chacon.dll (2010-04-07 09:03:40 UTC)
Chacon 3
foo_comserver2.dll (2006-07-31 19:13:20 UTC)
COM Automation server 0.7 alpha 6
foo_converter.dll (2012-02-04 13:04:00 UTC)
Converter 1.5
foo_convolve.dll (2006-08-05 04:57:26 UTC)
Convolver 0.3
foo_dop.dll (2011-06-12 21:17:16 UTC)
iPod manager 0.6.9.6
foo_dsp_channeldividerF.dll (2012-02-14 06:20:54 UTC)
channeldividerF Ver 0.62
foo_dsp_channeldividerF2B.dll (2012-02-14 06:21:01 UTC)
channeldividerF2B Ver 0.62
foo_dsp_dolbyhp.dll (2010-01-22 20:40:28 UTC)
Dolby Headphone Wrapper 1.4.1
foo_dsp_echo.dll (2010-06-06 02:07:36 UTC)
Echo DSP 1.0
foo_dsp_effect.dll (2012-02-18 08:29:29 UTC)
Effect DSP 0.9.2
foo_dsp_prvb.dll (2010-06-30 03:04:52 UTC)
Programmable reverb DSP 1.2
foo_dsp_std.dll (2012-02-04 13:04:14 UTC)
Standard DSP Array 1.0
foo_dsp_xover.dll (2010-04-08 04:04:58 UTC)
Crossover 0.42
foo_dynamic_range.dll (2011-04-04 23:07:28 UTC)
foo_fileops.dll (2012-02-04 13:03:02 UTC)
File Operations 2.1.3
foo_freedb2.dll (2012-02-04 13:03:02 UTC)
freedb Tagger 0.6.4
foo_infospect.dll (2008-02-02 04:02:58 UTC)
Infospect 1.0.3
foo_input_dts.dll (2012-02-18 08:29:29 UTC)
DTS decoder 0.3.0
foo_input_monkey.dll (2012-02-18 08:29:30 UTC)
Monkey's Audio Decoder 2.1.5
foo_input_std.dll (2012-02-04 13:05:10 UTC)
Standard Input Array 1.0
foo_lock.dll (2010-01-11 19:18:36 UTC)
Pause on Lock 0.5
foo_masstag.dll (2009-09-18 17:01:36 UTC)
Masstagger 1.8.4
foo_midi.dll (2012-02-18 08:29:29 UTC)
MIDI synthesizer host 1.153
foo_osd.dll (2012-02-18 08:29:30 UTC)
On-Screen Display GDI+ 1.69
foo_out_asio.dll (2012-02-18 08:29:29 UTC)
ASIO support 2.1.1
foo_out_ks.dll (2006-08-05 04:54:58 UTC)
Kernel Streaming Output 1.2.2
foo_out_wasapi.dll (2009-05-20 05:45:18 UTC)
WASAPI output support 2.1
foo_playcount.dll (2012-02-18 08:29:30 UTC)
Playback Statistics 3.0.2
foo_podcatcher.dll (2010-04-24 15:44:10 UTC)
Podcatcher 0.1.7.4 (beta, Apr 24 2010)
foo_r128norm.dll (2011-12-19 03:19:40 UTC)
EBU R128 Normalizer 1.11
foo_rgscan.dll (2012-02-04 13:03:48 UTC)
ReplayGain Scanner 2.1.2
foo_tradersfriend.dll (2010-05-16 00:18:12 UTC)
Live Show Tagger 0.7.1
foo_ui_columns.dll (2010-05-03 13:38:32 UTC)
Columns UI 0.3.8.6
foo_ui_std.dll (2012-02-04 13:04:08 UTC)
foo_uie_playlists_dropdown.dll (2009-09-24 07:44:46 UTC)
Playlists Dropdown 0.7.6
foo_unpack.dll (2012-02-04 13:03:26 UTC)
ZIP/GZIP/RAR Reader 1.6
foo_verifier.dll (2009-10-05 18:39:20 UTC)
File Integrity Verifier 1.1
foo_vis_shpeck.dll (2009-09-28 18:32:16 UTC)
Shpeck - Winamp vis plugins wrapper 0.3.7
foo_vst.dll (2011-03-05 16:19:04 UTC)
foo_w7shell.dll (2010-01-17 11:09:20 UTC)
Windows 7 integration 0.2.9.1
Recent events:
w7shell: WA_DISALLOW_PEEK successfully set
w7shell: WA_HAS_ICONIC_BITMAP successfully set
w7shell: WA_FORCE_ICONIC_REPRESENTATION successfully set
w7shell: WA_FLIP3D_POLICY successfully set
w7shell: all green
Startup time : 0:05.668305
iPod manager: Device properties: DBVersion: 5, FireWireGUID: 000A270022643D69, SQLiteDB
iPod manager: 105 post process SQL commands, version 9
iPod manager: Apple iPod/iPhone connected. Device Instance Path: USB\VID_05AC&PID_1266&MI_00\000A270022643D69&AAPL0
w7shell: taskbar button create notification got
Machine specifications:
OS: Windows 6.1.7601 Service Pack 1 x64
CPU: Intel® Core™ i7 CPU 920 @ 2.67GHz, features: MMX SSE SSE2 SSE3 SSE4.1 SSE4.2
Audio: Speakers (ASUS Xonar Essence ST Audio Device); Digital Output (ASUS Xonar Essence ST Audio Device)
Also, I did just install 10 windows updates last night (dont know how the hell that accumulated, I usually see the updates and run them) all of which were successful. Is anyone having crashes or similar issues? I dont know what the hell to do, my entire music library depends on this program. I could use itunes, but I would rather chop my balls off and eat them myself.
RSS Lo-Fi Version Time is now: 6th March 2015 - 22:15
