> Upload forum rules
24 bit vinyl clips, Examples of 24 bit vinyl and bit-reduced versions
Gretschguy
post Feb 15 2012, 19:03
Attached are several clips for vinyl rips, each in (24/48) and (16/44.1) -- I have many more but 7 I filled up my attachment space.
I used Izotope's SRC and MBit+ algorithms to do the conversion, I converted sample rate first and then bit rate.
The rips were done using Thorens Turntable, Lyra Delos cartride, Parasound phono pre, Burl B2 ADC, Lynx AES16 card, Pure Vinyl software.
If anyone has better conversion technology than Izotope I would be interested to hear those samples for my own comparison, as a practical matter I would like to have the best possible bit reduced versions in my library in addition to my 24 bit versions.
If anyone is interested in specific notes on what I'm hearing as the differences in my playback system then let me know.
The sources are:
Dire Straits "Romeo And Juliet"
Prefab Sprout "Faron Young"
Yes "Roundabout"
The National "Bloodbuzz Ohio"
Cat Stevens "Father And Son"
Roxy Music "Running Wild"
John Lennon "Mind Games"
Thanks for checking these out.
Attached File(s)
Attached File  Romeo_And_Juliet__30s___24_48_.wav ( 6.98MB ) Number of downloads: 194
Attached File  Romeo_And_Juliet__30s___16_44_.wav ( 4.31MB ) Number of downloads: 137
Attached File  Roundabout__30s___24_48_.wav ( 8.53MB ) Number of downloads: 107
Attached File  Roundabout__30s___16_44_.wav ( 5.27MB ) Number of downloads: 92
Attached File  Bloodbuzz_Ohio__30s___24_48_.wav ( 8.37MB ) Number of downloads: 106
Attached File  Bloodbuzz_Ohio__30s___16_44_.wav ( 5.16MB ) Number of downloads: 89
Attached File  Father_And_Son__30s___24_48_.wav ( 8.37MB ) Number of downloads: 123
Attached File  Father_And_Son__30s___16_44_.wav ( 5.17MB ) Number of downloads: 115
Attached File  Faron_Young__30s___24_48_.wav ( 7.9MB ) Number of downloads: 174
Attached File  Faron_Young__30s___16_44_.wav ( 4.88MB ) Number of downloads: 112
Attached File  Running_Wild__30s___16_44_.wav ( 5.11MB ) Number of downloads: 104
Attached File  Running_Wild__30s___24_48_.wav ( 8.27MB ) Number of downloads: 99
Attached File  Mind_Games__30s___16_44_.wav ( 5.05MB ) Number of downloads: 89
Attached File  Mind_Games__30s___24_48_.wav ( 8.24MB ) Number of downloads: 111
mixminus1
post Feb 15 2012, 22:55
@Gretschguy, a couple questions:
1) You said earlier that you were using your Burl to capture at 24/96, but the samples you posted are 24/48. Are these files new captures performed with the Burl running @ 48 kHz, or downsampled from your original 96 kHz captures?
2) Regarding performing an ABX test with your system: What have you been using for playback of your 24-bit files (and related to that, exactly how have you been comparing the "hi-res" and downsampled versions)? The output of the Lynx card to your Burmester DAC? If so, and you're running Windows, the freeware foobar2000 audio player has an ABX plugin that would make performing an ABX test simple, especially as foobar can be set to always output 24-bit audio to your audio interface, regardless of whether the file being played is 16 or 24 bit (16-bit files are just padded with zeros).
Comparing different sample rates could be tricky, though, as although foobar has no problem outputting any sample rate known to man, your DAC will most likely mute while switching rates - or I should say, *hopefully* it mutes, and doesn't pop/click/etc - and depending on how long that mute lasts, it could make ABX'ing difficult.
- Gretschguy   24 bit vinyl clips   Feb 15 2012, 19:03
- - Wombat   It shouldn´t be of any advantage to use iZotope di...   Feb 15 2012, 19:35
- - Wombat   I gave this Faron Young sample a try and played it...   Feb 15 2012, 20:44
|- - Gretschguy   QUOTE (Wombat @ Feb 15 2012, 20:44) I gav...   Feb 15 2012, 21:57
|- - greynol   QUOTE (Gretschguy @ Feb 15 2012, 12:57) D...   Feb 15 2012, 22:09
|- - Gretschguy   QUOTE (greynol @ Feb 15 2012, 22:09) QUOT...   Feb 15 2012, 22:28
- - pdq   An interesting experiment for Gretschguy to perfor...   Feb 15 2012, 21:09
|- - Gretschguy   QUOTE (pdq @ Feb 15 2012, 21:09) An inter...   Feb 15 2012, 21:43
- - pdq   From the website for the DAC, it appears that it d...   Feb 15 2012, 21:52
|- - Gretschguy   QUOTE (pdq @ Feb 15 2012, 21:52) From the...   Feb 15 2012, 22:00
- - greynol   Let there be no doubt that any audible differences...   Feb 15 2012, 22:02
|- - Gretschguy   QUOTE (greynol @ Feb 15 2012, 22:02) Let ...   Feb 15 2012, 22:17
- - greynol   It's readily accepted that best practice is to...   Feb 15 2012, 22:21
- - Wombat   QUOTE (Gretschguy @ Feb 15 2012, 21:57) W...   Feb 15 2012, 22:31
|- - Gretschguy   QUOTE (Wombat @ Feb 15 2012, 23:31) QUOTE...   Feb 15 2012, 22:40
- - greynol   If you cannot demonstrate that what you're hea...   Feb 15 2012, 22:35
|- - Gretschguy   QUOTE (greynol @ Feb 15 2012, 23:35) If y...   Feb 15 2012, 22:41
- - AndyH-ha   What are you asking for? Do you have a problem to ...   Feb 15 2012, 22:39
- - mixminus1   @Gretschguy, a couple questions: 1) You said earl...   Feb 15 2012, 22:55
|- - Gretschguy   QUOTE (mixminus1 @ Feb 15 2012, 22:55) @G...   Feb 15 2012, 23:27
|- - greynol   QUOTE (Gretschguy @ Feb 15 2012, 14:27) M...   Feb 15 2012, 23:33
- - greynol   He could just up-convert to the highest bit depth/...   Feb 15 2012, 23:16
- - xnor   Thanks for the samples. A simple analysis showed t...   Feb 16 2012, 00:31
|- - Gretschguy   QUOTE (xnor @ Feb 16 2012, 01:31) Thanks ...   Feb 16 2012, 03:49
- - mjb2006   I wouldn't worry about using SoX. Izotope...   Feb 16 2012, 03:43
|- - Gretschguy   QUOTE (mjb2006 @ Feb 16 2012, 04:43) I wo...   Feb 16 2012, 03:51
- - cliveb   OK, I have listened to Gretschguy's vinyl clip...   Feb 16 2012, 10:17
- - 2Bdecided   Sorry to reply a third time! I've been en...   Feb 20 2012, 14:34
- - Gretschguy   QUOTE (2Bdecided @ Feb 20 2012, 15:34) So...   Feb 21 2012, 03:24
RSS Lo-Fi Version Time is now: 2nd September 2015 - 02:15
