Foobar 1.1.11, WASAPI and playback of files with different samplerates, [fixed in beta 3 of plugin: hydrogenaudio.org/forums/?showtopic=94907]
radiator27
post Feb 13 2012, 17:17
Hi
I'm using the latest WASAPI output plugin, ATI Radeon HD 5750 HDMI to Denon 1911 Receiver (computer is running Windows 7 Home Premium, 64 bit)
With foobar version 1.1.11 there is no playback when switching to a flac-file with a different samplerate than the previous - e.g. playing a 44.1 kHz flac and selecting a 96 kHz flac. I have to click on the new file several times before the new file will play.
If i use the Direct Sound output the problem goes away. And if I downgrade to foobar version 1.1.10 the problem also goes away, so i suspect that foobar version 1.1.11 does not report a proper output format every time a new file is selected. Maybe this is related to the new cross-fade functionality, that somehow breaks WASAPI output samplerate change?
My solution so far is to stay with version 1.1.10, but I hope that this can be fixed in a future version. :-)
blindpainkiller
post Feb 22 2012, 19:43
I have the same problem. Also, I more often than not hear a distinct "pop" when I switch tracks, no matter what sample rate. Both these problems started in 1.1.11 and only happen with WASAPI.
I run foobar on Vista 32bit on a Xonar Essence STX.
- radiator27   Foobar 1.1.11, WASAPI and playback of files with different samplerates   Feb 13 2012, 17:17
- - kode54   Cross fading is specific to DirectSound output.   Feb 13 2012, 17:31
- - bacondither   I have the same problem with version 1.1.11 and WA...   Feb 13 2012, 22:13
- - Jackal29a   I thought neither of my Xonar cards (ST & D2X,...   Feb 14 2012, 21:53
- - WarZard-X   I have exactly the same problem with 1.1.11 and WA...   Feb 18 2012, 19:21
- - WarZard-X   Does no one else have this problem with Wasapi ...   Feb 22 2012, 17:53
- - blindpainkiller   I have the same problem. Also, I more often than n...   Feb 22 2012, 19:43
- - gfh   Confirm. AMD Radeon 6950 HDMI to Denon 1912 Receiv...   Mar 16 2012, 14:19
- - Sandrine   1.1.12 beta1 is out, all testers to the fore   Mar 25 2012, 11:38
- - radiator27   Unfortunately version 1.1.12 beta 2 does not solve...   Mar 26 2012, 08:55
- - Sandrine   You should report this, it's not assured that ...   Mar 26 2012, 19:50
- - Mr.Ferrari   Same problem here with both 1.11 & 1.12beta + ...   Mar 27 2012, 06:07
- - Kohlrabi   In the meantime, try ASIO if you need to feed bit-...   Mar 27 2012, 08:35
|- - Mr.Ferrari   QUOTE (Kohlrabi @ Mar 27 2012, 09:35) In ...   Mar 27 2012, 16:21
|- - Dakeryas   Same problem here on an Audinst HUD USB Dac. I alw...   Mar 27 2012, 17:41
- - Mr.Ferrari   Could any developer please say something. So we kn...   Mar 30 2012, 15:54
- - WarZard-X   Will this ever be fixed?   Apr 30 2012, 10:32
- - Peter   Problem acknowledged, thanks for reporting. Unfort...   Apr 30 2012, 12:19
- - MaCs   I don't think it is WASAPI-related. I have exa...   May 11 2012, 13:32
- - bsw11   I have the same or similar problem switching betwe...   May 12 2012, 01:05
|- - db1989   QUOTE (bsw11 @ May 12 2012, 01:05) This r...   May 12 2012, 08:36
- - bsw11   QUOTE (db1989 @ May 12 2012, 00:36) QUOTE...   May 12 2012, 18:13
- - WarZard-X   Finally it's fixed with Wasapi Plugin 3.0 beta...   May 13 2012, 18:03
Closed TopicStart new topic
RSS Lo-Fi Version Time is now: 1st September 2015 - 12:17
