Canít get same CRC when I burn/re-rip it. Due to absence of cue-sheet?, Was: Rip, Burn, Rip and CRC (TOS #6/unclear)
eahm
post Feb 11 2012, 19:29
Hello again guys, I must ask another question again even though only few hours passed from my previous one.
I've did may simple test and none of them worked, I may know why it still not working but I need to hear from an expert.
Here's my problem:
Original CD Audio -> Rip to FLAC = Correct rip with AccurateRip. When I calculate the CRC/MD5 with dBpoweramp it gives me the same CRC for every lossless rip test I do with that very same track.
It seems though that I can't get the same CRC when I burn the track and re rip it. 1) Is my problem the absence of CUE files? 2) Does the track re rip correctly only if I burn it from the CUE file? 3) Is there a way to make a perfect burn without the CUE file? I've tried every possible burning software, burrrn, dBpoweramp, EAC etc.
Thank you again guys.
pdq
post Feb 11 2012, 22:07
Sorry, I only saw your mention of CRC and didn't know you had also done a WAV compare.
Did the data match but with an offset?
- eahm   Canít get same CRC when I burn/re-rip it. Due to absence of cue-sheet?   Feb 11 2012, 19:29
- - psycho   Your problem comes from reading and more important...   Feb 11 2012, 19:36
- - eahm   I thought the CUE file was going to be the problem...   Feb 11 2012, 20:01
- - eahm   I am reading this guide http://blowfish.be/eac/Bur...   Feb 11 2012, 20:20
- - pdq   It would make more sense to compare the audio data...   Feb 11 2012, 20:55
- - eahm   What do you mean? That WAV Compare test I did is f...   Feb 11 2012, 21:02
- - pdq   Sorry, I only saw your mention of CRC and didn...   Feb 11 2012, 22:07
- - eahm   Please look at the attached screenshots, there is ...   Feb 11 2012, 23:23
- - eahm   You've got to be kidding me. The write offset ...   Feb 12 2012, 04:55
- - eahm   I did calculate the write offset and it supposed t...   Feb 12 2012, 06:53
- - pdq   You should really stop relying on CRC. If even a s...   Feb 12 2012, 14:06
- - Bugs.Bunny   If you do want a bit exact copy you will need 2 th...   Feb 12 2012, 15:05
- - eahm   QUOTE (pdq @ Feb 12 2012, 06:06) You shou...   Feb 12 2012, 19:36
- - pdq   Your CRCs don't match. You don't know why ...   Feb 13 2012, 05:09
- - eahm   QUOTE (pdq @ Feb 12 2012, 21:09) Your CRC...   Feb 13 2012, 06:59
- - pdq   Open EAC, click on Tools->Compare WAVs, select ...   Feb 13 2012, 18:12
- - JunkieXL   I have done the same thing you are testing. I was...   Feb 13 2012, 19:07
- - eahm   QUOTE (pdq @ Feb 13 2012, 10:12) Open EAC...   Feb 13 2012, 19:48
|- - psycho   QUOTE (eahm @ Feb 13 2012, 19:48) ...I wa...   Feb 16 2012, 18:43
|- - psycho   QUOTE (eahm @ Feb 13 2012, 19:48) Again, ...   Feb 16 2012, 19:07
- - pdq   Are the six missing samples at the beginning or th...   Feb 13 2012, 19:59
- - eahm   QUOTE (pdq @ Feb 13 2012, 11:59) Are the ...   Feb 13 2012, 20:14
- - pdq   The example shows the missing samples to be at the...   Feb 13 2012, 20:28
- - Bugs.Bunny   Offset (read or write) results in loosing some dat...   Feb 13 2012, 21:32
- - pablogm123   "There are (as far as I know) no drives with ...   Feb 16 2012, 11:17
- - db1989   That depends. If one follows the meticulously hard...   Feb 16 2012, 11:26
- - eahm   QUOTE (db1989 @ Feb 16 2012, 03:26) That ...   Feb 16 2012, 18:38
- - greynol   I'm pretty certain the answer to your question...   Feb 16 2012, 18:41
- - greynol   ...or you can burn an offset test CD with the writ...   Feb 16 2012, 18:57
RSS Lo-Fi Version Time is now: 27th February 2015 - 16:34
