MIDI plugin quality?, is it bad?
yosuke30
post Feb 10 2012, 18:30
Hey everyone,
Im using foobar2k for quite a while now and I don't want to use
another player anymore, but there's a little problem.
I've downloaded the midi plugin for foobar and put it into the plugin folder, and it works.
But the quality is not really good. If i listen to the same midi in wmp it sounds as it should do.
I'm using midi files for the rpg maker and when i listen to the midis there, they sound like in wmp, so i guess
somethings not right with the plugin for f2k.
Is it just bad or do exists other midi plugins?
kode54
post Feb 11 2012, 20:41
Group: Admin
There is no "should sound" to this whole format, unless the composer used a specific synthesizer when producing the file, and expected everyone who would listen would have the same exact synthesizer.
foobar2000 cannot use the system synthesizer because it does not support on-demand rendering, only real time playback.
If you really want it to sound like that horrible gm.dls bank, you may dig up Audio Compositor or similar and convert the bank to SF2 format.
I happen to flip around between a mix of Colossus.SF2 (not strictly legit) with SGM and AnotherXG, and the two Yamaha VST instruments, S-YXG50 and S-YXG2006LE.
- yosuke30   MIDI plugin quality?   Feb 10 2012, 18:30
- - kode54   You need to download a SoundFont sample bank, or a...   Feb 10 2012, 23:14
- - yosuke30   Sadly I have no idea what to change under that opt...   Feb 11 2012, 08:46
- - yosuke30   Hey again, sorry for posting twice. Can no one he...   Feb 11 2012, 18:21
- - lvqcl   Try Shan's soundfont. ADDED: It seems that the...   Feb 11 2012, 18:41
- - yosuke30   Thanks lvqcl, I'm browsing trough the site. Ca...   Feb 11 2012, 18:53
- - John2K   Try these: http://www.ntonyx.com/soft/32MbGMStere...   Feb 11 2012, 19:01
- - yosuke30   sorry again for my lack of knowledge... I thought ...   Feb 11 2012, 19:35
|- - John2K   QUOTE (yosuke30 @ Feb 11 2012, 18:35) I t...   Feb 11 2012, 20:19
- - yosuke30   Ok now I have this: http://imgur.com/CVINW Is th...   Feb 11 2012, 20:13
- - yosuke30   It sounds muuuuch better now. Nearly perfect. But ...   Feb 11 2012, 20:26
- - kode54   There is no "should sound" to this whole...   Feb 11 2012, 20:41
|- - mudlord   QUOTE (kode54 @ Feb 11 2012, 14:41) If yo...   Feb 12 2012, 09:05
- - yosuke30   I did not understand a single word from your last ...   Feb 11 2012, 20:47
- - Vagabond   MIDI doesn't have a normal sound. The one you...   Feb 12 2012, 01:26
- - yosuke30   And that's why I want foobar to sound like wmp...   Feb 12 2012, 08:00
- - yosuke30   Totally missed this post, sorry. Downloaded VSampl...   Feb 12 2012, 10:44
- - mudlord   There should be a Roland VSC soundfont floating ar...   Feb 12 2012, 12:04
- - yosuke30   GREAT! That's it! Thank you so much, I...   Feb 12 2012, 12:44
|- - John2K   QUOTE (yosuke30 @ Feb 12 2012, 11:44) GRE...   Feb 20 2012, 15:07
- - kode54   I am surprised that Audio Compositor even costs an...   Feb 13 2012, 01:59
|- - mudlord   QUOTE (kode54 @ Feb 12 2012, 19:59) I am ...   Feb 21 2012, 12:38
- - revangel   If you want a absolutely great experience listenin...   Mar 2 2012, 17:26
- - zerowalker   What plugin does Zoomplayer use, as a certain midi...   Nov 28 2013, 12:24
- - Faziri   A VST called SGM produces pretty epic sound that s...   Jun 17 2014, 02:22
- - kode54   This looks promising: Musyng Kite 990MB GM/GS sou...   Jun 19 2014, 02:29
- - EddieAlucard   I've been using Timbres of Heaven soundfont al...   Jun 24 2014, 07:00
- - kode54   Yeah, BASSMIDI uses a floating point mixing proces...   Jun 24 2014, 07:45
- - EddieAlucard   I noticed something unusual. If I let the EMIDI de...   Jun 30 2014, 01:34
RSS Lo-Fi Version Time is now: 6th July 2015 - 06:53
