LAME: different compilers producing significantly different bitstreams, Split from “LAME 3.99 is out”
Alex B
post Jan 28 2012, 15:16
The new 32-bit lame.exe seems to work fine for me on XP Pro SP3 (I have an AMD Phenom II CPU that supports SSE2), but it produces entirely different output than LAME 3.99.3 from the previous "main" bundle. I did not expect that. As far as I can see, the change log does not indicate any further "quality tweaking".
In some cases 3.99.4 seems to produce significantly smaller VBR bitrates than 3.99.3. I tested the settings -V1, -V5 and -V8. When the source tracks were quiet and uncompressed (classical, ambient, etc) the bit rates were 3-12% smaller than before. When the source tracks were loud and compressed (hard rock, metal, etc) the bitrates were about the same as before (or just very slightly smaller).
This post has been edited by Alex B: Jan 28 2012, 16:08
Kilu
post Feb 10 2012, 17:46
This thread was an interesting read.
So just to be clear, this is now resolved? Should I grab the 3.99.5-test from RareWares, or wait for 3.99.5 proper?
Another thing I'm wondering, I saw some encoding speed differences earlier in the original thread this was split from.
Was there encoding speed differences with 3.99.5-test and 3.99.4 (lvqcl), how about 32bit vs 64bit builds?
Or was that stuff just completely unrelated?
made of radiation
- Alex B   LAME: different compilers producing significantly different bitstreams   Jan 28 2012, 15:16
- - halb27   With my test set 3.99.4 produces an average bitrat...   Jan 28 2012, 22:44
- - Alex B   I uploaded a sample: http://www.hydrogenaudio.org/...   Jan 28 2012, 23:31
|- - JJZolx   QUOTE (Alex B @ Jan 28 2012, 15:31) In so...   Jan 29 2012, 00:18
|- - Alex B   QUOTE (JJZolx @ Jan 29 2012, 01:18) Some ...   Jan 29 2012, 00:43
- - lvqcl   Different compilers/options IMHO.   Jan 28 2012, 23:58
- - Alex B   At least John did not change the announced compile...   Jan 29 2012, 00:12
- - lvqcl   From RareWares main page: "Compiles are now M...   Jan 29 2012, 00:23
|- - bbrabant   QUOTE (lvqcl @ Jan 29 2012, 02:23) Also, ...   Jan 29 2012, 00:40
- - JJZolx   Ok, then back to lvqcl: Why would a different comp...   Jan 29 2012, 00:53
|- - Alex B   QUOTE (JJZolx @ Jan 29 2012, 01:53) Why w...   Jan 29 2012, 01:06
|- - C.R.Helmrich   Indeed. How was the following done, if I may ask? ...   Jan 29 2012, 02:10
- - lvqcl   It seems that the relevant changes are somewhere i...   Jan 29 2012, 12:00
|- - JJZolx   QUOTE (lvqcl @ Jan 29 2012, 04:00) It see...   Jan 29 2012, 23:02
- - john33   Sorry, guys, there was a compiler option error on ...   Jan 30 2012, 12:42
- - halb27   Everything's fine now. Exactly the same averag...   Jan 30 2012, 14:54
|- - john33   QUOTE (halb27 @ Jan 30 2012, 13:54) Every...   Jan 30 2012, 15:11
- - godrick   Does the nature of the compiler error require user...   Jan 30 2012, 15:56
|- - john33   QUOTE (godrick @ Jan 30 2012, 14:56) Does...   Jan 30 2012, 16:01
- - Alex B   Thanks John. The new 32-bit exe compile seems to ...   Jan 30 2012, 17:16
|- - john33   QUOTE (Alex B @ Jan 30 2012, 16:16) Thank...   Jan 30 2012, 18:01
|- - robert   QUOTE (Alex B @ Jan 30 2012, 17:16) Thank...   Jan 30 2012, 18:16
- - Alex B   I don't think libsndfile is involved. I used f...   Jan 30 2012, 18:36
- - mixminus1   I can confirm AlexB's findings vis a vis the b...   Jan 30 2012, 21:49
- - DigitalMan   Assume 64 bit compile is unaffected? Not at machi...   Jan 31 2012, 00:17
- - mixminus1   No, latest 64-bit version of 3.99.4 (20120125) fro...   Jan 31 2012, 00:47
|- - john33   QUOTE (mixminus1 @ Jan 30 2012, 23:47) No...   Jan 31 2012, 09:35
- - john33   OK, done some testing comparing the Rarewares 32 b...   Jan 31 2012, 17:43
- - Pretentiousman   Is it possible for an executable from one compiler...   Jan 31 2012, 17:58
|- - john33   QUOTE (Pretentiousman @ Jan 31 2012, 16:5...   Jan 31 2012, 18:12
|- - JJZolx   QUOTE (Pretentiousman @ Jan 31 2012, 09:5...   Jan 31 2012, 18:12
|- - lvqcl   QUOTE (JJZolx @ Jan 31 2012, 21:12) Perha...   Jan 31 2012, 18:38
|- - apodtele   QUOTE (lvqcl @ Jan 31 2012, 12:38) QUOTE ...   Jan 31 2012, 21:52
|- - C.R.Helmrich   QUOTE (apodtele @ Jan 31 2012, 22:52) Ple...   Jan 31 2012, 23:01
|- - apodtele   Order is defined by precedence and compiler rarely...   Jan 31 2012, 23:36
|- - saratoga   QUOTE (apodtele @ Jan 31 2012, 15:52) QUO...   Feb 1 2012, 00:44
|- - nu774   CODEmain() { volatile double x = 53, y = ...   Feb 1 2012, 02:53
|- - apodtele   QUOTE (nu774 @ Jan 31 2012, 20:53) 54 52 ...   Feb 1 2012, 04:23
|- - nu774   QUOTE (apodtele @ Feb 1 2012, 12:23) You ...   Feb 1 2012, 04:45
||- - nu774   QUOTE (nu774 @ Feb 1 2012, 12:45) QUOTE (...   Feb 1 2012, 11:42
|- - timcupery   QUOTE (apodtele @ Jan 31 2012, 22:23) We ...   Feb 2 2012, 03:56
- - lvqcl   2 seconds of Liszt.wav (LAME -V1): original track...   Jan 31 2012, 18:05
- - JJZolx   But to what degree in terms of overall bitrate? Th...   Jan 31 2012, 18:45
- - Alex B   Here's how EncSpot Pro sees the differences in...   Jan 31 2012, 18:58
- - JJZolx   Here's some more data at different VBR quality...   Feb 1 2012, 00:21
- - lvqcl   Test signal: sine (-12 dBFS) + white noise (-N dBF...   Feb 2 2012, 16:56
- - halb27   Looks like your MSVC10 compile behaves more reason...   Feb 2 2012, 17:46
- - lvqcl   Spectrograms of sine+noise (3 seconds from an mp3 ...   Feb 2 2012, 18:13
|- - apodtele   QUOTE (lvqcl @ Feb 2 2012, 12:13) Spectro...   Feb 2 2012, 19:53
- - halb27   Looks like it's the decision process for decid...   Feb 2 2012, 20:27
- - john33   Just for the record, Robert is looking at this iss...   Feb 2 2012, 20:35
|- - lvqcl   QUOTE (john33 @ Feb 2 2012, 23:35) Just f...   Feb 2 2012, 21:10
|- - john33   QUOTE (lvqcl @ Feb 2 2012, 20:10) ... It...   Feb 2 2012, 23:09
- - Destroid   From the sidelines, I found this discussion of the...   Feb 5 2012, 11:49
- - antman   Agreed Destroid. This has been an interesting rea...   Feb 7 2012, 04:08
- - JJZolx   I'm surprised this thread wasn't split a l...   Feb 7 2012, 04:28
|- - DARcode   The "minutiae" in this thread are actual...   Feb 7 2012, 14:15
- - john33   Robert is currently working on a solution that wou...   Feb 7 2012, 14:27
|- - apodtele   QUOTE (john33 @ Feb 7 2012, 08:27) Robert...   Feb 7 2012, 16:24
|- - john33   QUOTE (apodtele @ Feb 7 2012, 15:24) This...   Feb 7 2012, 17:21
|- - robert   QUOTE (apodtele @ Feb 7 2012, 16:24) This...   Feb 7 2012, 17:38
|- - apodtele   QUOTE (robert @ Feb 7 2012, 11:38) The co...   Feb 7 2012, 21:48
- - john33   There is a test compile (32 bit) now available at:...   Feb 7 2012, 17:13
- - JJZolx   Here's that set of files again, encoded using ...   Feb 8 2012, 00:24
- - halb27   I checked Alex B's Liszt sample, and 3.99.5 be...   Feb 9 2012, 10:56
- - Kilu   This thread was an interesting read. So just to b...   Feb 10 2012, 17:46
|- - john33   QUOTE (Kilu @ Feb 10 2012, 16:46) This th...   Feb 10 2012, 18:27
- - antman   Kilu, in summary, the encoding speed differences w...   Feb 11 2012, 02:37
- - Kilu   Alrighty, thanks guys. I think I'll wait for t...   Feb 11 2012, 03:25
- - john33   3.99.5 test 2 on the link below fixes the decoding...   Feb 13 2012, 10:21
- - psycho   3.99.5 is out, compiles anyone?   Feb 15 2012, 21:54
|- - john33   QUOTE (psycho @ Feb 15 2012, 20:54) 3.99....   Feb 15 2012, 23:28
- - lvqcl   There's still no mention of 3.99.5 at http://s...   Feb 15 2012, 22:06
RSS Lo-Fi Version Time is now: 1st February 2015 - 05:10
