How to get best audio quality with foobar, effects or anything else?
JackBlack9
post Jan 28 2012, 15:59
Hi, I hope this is the right section.
I've got a notebook with a creative soundblaster audigy 2 NX (usb) and 2.0 Edifier R1600plus.
I'm trying to reach the best audio quality with foobar. Can you help me?
I've installed asio4all and then also foobar bassexciter to add windows media player trubass and wow effects on foobar but I don't know how to configurate them.
I want to take out the max from my speaker.
Thank you!
This post has been edited by JackBlack9: Jan 28 2012, 16:53
AudioTree
post Feb 6 2012, 20:37
QUOTE (JackBlack9 @ Jan 28 2012, 15:59) *
For playing a MP3 file, the chain of audio is as follows:
MP3 file ---> media player ---> driver --> soundcard --> cable --> speakers
On the digital side of this, audio can be treated as stream of numbers (samples), on the analog side audio is represented in voltages.
A media player like foobar opens the file and decodes it into samples. These samples are then simply fed into the buffer of the soundcard driver.
That's for the digital part of it. Now the soundcard transforms the samples into voltages which are send out on the output port, and via the cable to the speaker. The speaker than again transforms these voltages into vibrations of the air - which we can hear as sound.
The only serious way to measure audio quality is to compare of what is played back with what was recorded.
When recording audio, the most important factors are the microphone and the room.
Accordingly on the playback side the most important factors are the speakers and the room.
So if you'd really want to improve audio quality, the best thing to do is to invest into good speakers.
There's very little you can do on the digital side.
- The decoder has negligible influence. Every decoder should produce the same output from the same file within some rounding tolerance.
- The only transformation the media player makes is to scale the samples with the volume control. For best audio quality it should be clear to leave the volume control at the maximum, because if you scale it you will loose some (however minor) degree of numerical precision. Always scale on the far end of the chain if possible.
But wait... what about super-mega-bass-enhancers, equalizers, etc?
One word: DON'T
.. Unless you'd like to accurately measure the frequency response of your system. And even than you have to consider that using an equalizer will always distort your audio in some way (for example increasing the noise floor).
- The driver shouldn't do anything to the numbers except from handling them to the soundcard. So using ASIO instead of direct x drivers will change nothing - the numbers are the same.
- Concerning shielding of the motherboard: Yes, it's an issue on many laptops. There are some exceptions, the Mac Book/Mac Book Pros are shielded, as well is my Elitebook workstation and as far as I know Lenovo Thinkpads.
Will an external soundcard help? Depends...
Usually it doesn't! This is because the soundcard is connected via Firewire (or USB) to the motherboard - so the noise might propagate to the external soundcard.
The only thing that really helps is to get rid of the grounding by covering the ground pins with tape or prepare a 2-pole cable to fit into the 3-pole socket of your laptop's AC adapter.
- JackBlack9   How to get best audio quality with foobar   Jan 28 2012, 15:59
- - kraut   QUOTE I'm trying to reach the best audio quali...   Jan 28 2012, 16:10
|- - JackBlack9   QUOTE (kraut @ Jan 28 2012, 16:10) QUOTE ...   Jan 28 2012, 16:53
- - Kohlrabi   QUOTE (JackBlack9 @ Jan 28 2012, 15:59) I...   Jan 28 2012, 17:02
|- - JackBlack9   Why not use ASIO? Well.. I hear a deeper bass effe...   Jan 28 2012, 17:27
|- - Kohlrabi   QUOTE (JackBlack9 @ Jan 28 2012, 17:27) W...   Jan 28 2012, 17:40
- - larryfine   According to my humble opinion I think that DSP...   Jan 28 2012, 17:35
- - derty2   I think what I posted a few hours ago at another t...   Jan 28 2012, 18:34
|- - JackBlack9   Thank you for your replies. I'm absolutely new...   Jan 28 2012, 19:18
- - Kohlrabi   JackBlack9 welcome to our nice, little community ...   Jan 28 2012, 20:47
|- - pawelq   QUOTE (Kohlrabi @ Jan 28 2012, 14:47) Mos...   Jan 28 2012, 21:46
|- - RavenGT   QUOTE (pawelq @ Jan 28 2012, 16:46) I rec...   Jan 29 2012, 00:14
- - JackBlack9   Thank you very much. I think asio4all will be usef...   Jan 28 2012, 21:24
- - mudlord   Got ABX tests to back up your claims?   Jan 29 2012, 00:21
|- - pawelq   QUOTE (mudlord @ Jan 28 2012, 18:21) Got ...   Jan 29 2012, 15:40
- - JackBlack9   Does WASAPI works on XP? I can't understand ho...   Jan 29 2012, 01:06
|- - RavenGT   QUOTE (JackBlack9 @ Jan 28 2012, 20:06) D...   Jan 29 2012, 05:02
|- - mobyduck   QUOTE (JackBlack9 @ Jan 28 2012, 16:06) I...   Jan 29 2012, 10:05
- - kraut   QUOTE Previously there have been lots of problems ...   Jan 29 2012, 03:09
|- - TangoTiburones   QUOTE (kraut @ Jan 28 2012, 20:09) QUOTE ...   Jan 29 2012, 06:04
- - JackBlack9   thank you. what is kernel stream?   Jan 29 2012, 12:34
- - RonaldDumsfeld   QUOTE what is kernel stream? Simply put - it...   Jan 29 2012, 12:48
|- - JackBlack9   QUOTE (RonaldDumsfeld @ Jan 29 2012, 12:4...   Jan 29 2012, 13:29
||- - Kohlrabi   QUOTE (JackBlack9 @ Jan 29 2012, 13:29) W...   Jan 29 2012, 14:34
||- - Wander   QUOTE (Kohlrabi @ Jan 29 2012, 14:34) To ...   Jan 29 2012, 14:46
|- - shakey_snake   QUOTE (RonaldDumsfeld @ Jan 29 2012, 06:4...   Jan 29 2012, 17:56
|- - JackBlack9   QUOTE (shakey_snake @ Jan 29 2012, 17:56)...   Jan 29 2012, 18:11
- - Wander   A lot of people, especially those who are not that...   Jan 29 2012, 14:14
- - JackBlack9   It's ok, sound is relative as almost everythin...   Jan 29 2012, 15:18
|- - Wander   To use WASAPI you need to download this component ...   Jan 29 2012, 15:28
- - db1989   He is saying that using Kernel Streaming will not ...   Jan 29 2012, 20:02
- - AudioTree   QUOTE (JackBlack9 @ Jan 28 2012, 15:59) I...   Feb 6 2012, 20:37
RSS Lo-Fi Version Time is now: 30th January 2015 - 17:49
