Crazy problem: USB port provides bad sound, but only at low CPU usage, Was: CrazyProblem:BadSound@lowCPU-usage (Please use your space bar.)
reselty
post Jan 20 2012, 12:14
Hello
USB port provides poor sound quality
Itís a Windows XP or Hardware not a DJ-Soft Problem.
Only I do not know, where I could ask such a question otherwise.
Problem occurs when sound output via USB (via Jack OK).
- Via ext USB Sound Card
- Via USB Headphone / Mic earphones (which have a well-integrated sound card)
No Problem when:
+ powered USB hub between PC and sound card "sound OK" ( "bad sound" without power )
+ The REALLY WEIRD: if I increase CPU usage, e.g. if I move a window in Windows continuously the output is OK
Attachment: 2 WAV sound files:
http://dl.dropbox.com/u/39224041/USB-out-WAV%27s.zip
I'm alternating every 10 seconds during playback,
- move a window in a circle permanently CPU Usage 60..64% >> Sound ok
- Then without window moving CPU Usage 2...7% >> sound bad
Each WAV starting with window moving(so: 10s good, 10s bad, and so on (etc))
Could it be due to the USB power? (Not yet measured)
I've read that some USB devices could damage PC.
"This could, in extreme cases damage the USB port on the host or upset the energy management of the computer, which can lead to unstable behavior."
Possible? While yes: enough to measure only via Soft-PC-Diagn.Tool e.g. SpeedFan? Or do I have to measure with a MultiMeter?
Could it be speed of USB?
My PC has USB2.0, however I have not found out about whether "Hi-Speed" or "Full Speed"
What ever could it be???
Am glad to rest every tip, even to the other proposals in which forum should be posted!
Thank you
Reselty
slks
post Jan 20 2012, 14:46
If you could tell us how the audio sounded "bad" we could give a better answer.
My gut reaction to this is that it should not be possible - USB only transfers digital data, which means that the data either gets to the external sound card, or it doesn't. There should be no degradation in quality, at least until the signal reaches the end of its digital path in the external sound card, and gets converted to analog. But I'm willing to consider that errors interrupting the digital data transfer could cause audible problems. It could be something like power saving schemes trying to shut off the USB ports, like the previous poster suggested. IIRC, data flow control over USB is also done through the CPU, so putting the CPU under heavy load could cause interruptions to the data flow. (However, data interruptions while the CPU is under less loads, I could not understand.) I imagine such interruptions would sound like skips in the audio, possibly only milliseconds in duration, which would make them sound more like small pops, similar to dust in the grooves of a vinyl record.
Perhaps someone with more computer engineering background, or knowledge on how these external sound cards work (do they have their own buffer to fight data flow interruptions? how large is this buffer? etc.) could fill in the gaps of my knowledge. A more detailed description from you as to what exactly happens to the sound when it gets "bad" would also help in diagnosis.
edit: Wow, I glazed over your .wav samples somehow. The clips sound distorted to me from the beginning to end, and opening them up in an audio editor confirms that they peak at 0 dB throughout. That is to say, they've been recorded way too loud. Try recording them again with the volume turned way down, so that we can hear what it going on, not just clipping distortion wink.gif
This post has been edited by slks: Jan 20 2012, 14:55
What I do with all the audio tech? This: http://last.fm/user/sls
reselty
post Jan 27 2012, 22:31
Answer 4 slks
Thanks a lot about your thoughts.
USB only transfers digital data - as I thought..
errors interrupting the digital data transfer - didn't thought about that, but why not! perhaps like zima explained
someone with more computer engineering background - would be nice..
about the uploaded sound - hope you'll listen to the new uploaded files, for me it is not easy to explain in words the craziness. But today I first tried with the USB-Headset and it sounded not anymore like sound (would had the possibility to record it), than I tried the ext.soundcard WITHOUT power (forgotten) and there was no problem.
- reselty   Crazy problem: USB port provides bad sound, but only at low CPU usage   Jan 20 2012, 12:14
- - Roseval   As this looks to be CPU load related, sometimes po...   Jan 20 2012, 13:46
|- - reselty   Hi Roseval ThanX for the fast answer! Tried it...   Jan 20 2012, 14:35
- - slks   If you could tell us how the audio sounded "b...   Jan 20 2012, 14:46
|- - reselty   Answer 4 slks Thanks a lot about your thoughts. ...   Jan 27 2012, 22:31
- - hlloyge   Reinstall chipset drivers, check DMA settings if y...   Jan 20 2012, 15:13
|- - reselty   hlloyge Thanks I tried - No Changings (Chipset-Dri...   Jan 20 2012, 20:00
|- - reselty   QUOTE (hlloyge @ Jan 20 2012, 16:13) Rein...   Jan 27 2012, 22:52
- - Ouroboros   It seems illogical that it should work better at h...   Jan 20 2012, 15:17
|- - reselty   QUOTE (Ouroboros @ Jan 20 2012, 16:17) It...   Jan 27 2012, 23:24
- - JimH   QUOTE (reselty @ Jan 20 2012, 05:14) No P...   Jan 20 2012, 16:44
- - Maggi   you could also have a look into your system's ...   Jan 20 2012, 17:09
|- - reselty   QUOTE (Maggi @ Jan 20 2012, 18:09) you co...   Jan 28 2012, 01:46
|- - Maggi   QUOTE (reselty @ Jan 28 2012, 01:46) QUOT...   Jan 31 2012, 15:26
|- - reselty   Thanks for Inputs Maggi and Arnold I tried many o...   Feb 1 2012, 15:01
- - reselty   Thanks 4 the moment to all of you !!! ...   Jan 20 2012, 20:02
|- - Nessuno   Try to boot in a different OS install, a live Linu...   Jan 21 2012, 01:34
- - A_Man_Eating_Duck   What is the model number of your motherboard? Som...   Jan 20 2012, 21:33
- - zima   reselty, the description in your first post would ...   Jan 21 2012, 08:00
- - reselty   Thanks to all of you So much answers and I could...   Jan 27 2012, 22:17
- - reselty   Thanks JimH That's why the powered hub works b...   Jan 27 2012, 23:31
- - saratoga   Overloaded USB voltage regulator seems most likely...   Jan 28 2012, 00:11
- - A_Man_Eating_Duck   what motherboard\PC do you have?   Jan 28 2012, 02:48
- - reselty   Hi - Found the problem Thanks a lot to all of you ...   Jan 28 2012, 13:34
- - reselty   Infos you asked me in between my absence and for o...   Jan 28 2012, 13:59
- - zima   C-states: http://en.wikipedia.org/wiki/Advanced_Co...   Jan 28 2012, 14:29
- - reselty   Thnx again I'll only use it, when necessary.....   Jan 28 2012, 16:46
- - A_Man_Eating_Duck   When i had random bacon sizzling noises on my m-au...   Jan 28 2012, 20:00
|- - reselty   QUOTE (A_Man_Eating_Duck @ Jan 28 2012, 21...   Jan 30 2012, 17:44
- - Arnold B. Krueger   I think you are onto something with the USB power ...   Jan 31 2012, 14:13
RSS Lo-Fi Version Time is now: 4th March 2015 - 09:57
