FhG encoder - how to automatically add the "tool" tag?, adding "tool" tag to each converted track
Pete7874
post Jan 19 2012, 20:57
Using Foobar2000, when I convert something using for example the Nero AAC codec, it automatically adds a "Tool" tag/attribute to each file. This "tool" attribute tells me that a given track was encoded using Nero 1.5.4.0.
I recently started using the FhG AAC codec (fhgaacenc.exe), and this codec does not add such a tag/attribute. Is there any way to configure either the codec itself or Foobar2000 so that it would?
I like being able to see what codec was used to create a particular AAC file.
slks
post Jan 20 2012, 07:31
I believe the "Tool" tag is added by the encoder itself. You should look in the documentation for the FhG encoder, and see if there is a command-line option that will cause it to add the Tool field. It may be that the FhG encoder does not support this.
However, if you're encoding these files yourself, you could always add either a Comment tag or a custom tag field named Tool, and put the encoder/version in there manually.
What I do with all the audio tech? This: http://last.fm/user/sls
Shadoko
post Jan 22 2012, 01:24
Nero uses the "encodingTool" metadata tag. You can set this tag by yourself with the help of the "AtomicParsley" tool.
Pete7874
post Jan 22 2012, 21:44
Thanks, although I was hoping for an automated way of doing it, as part of creating the FhG-converted file itself.
sluggy
post Jun 23 2012, 15:53
QUOTE (Pete7874 @ Jan 19 2012, 19:57) *
Yeah this would be good if fraunhofer could add this, it would be helpfull so you could tell which encoder version was used and which preset.
lvqcl
post Apr 15 2013, 21:16
Winamp 5.7 Beta 4 Build 3364 to Beta 5 Build 3367 changelog
- [enc_fhgaac] Write encoder version & setting to @too atom (tool) in mp4 metadata
ManekiNeko
post Apr 16 2013, 02:27
QUOTE (lvqcl @ Apr 15 2013, 21:16) *
Nice biggrin.gif. Confirmed:
'Encoded by: fhgaac v03.02.11;VBR=5' is now displayed in the metadata
RSS Lo-Fi Version Time is now: 28th March 2015 - 20:10
