Minimum number of required ABX trials, Split from from topic ID: 92851
sauvage78
post Jan 12 2012, 00:41
The minimal number of trials depends on how successfull you are.
How quickly you are sucessfull shows how confident in yourself you are.
The time & number of sucessfull trials are tied, you should never separate them when judging an ABX log.
With F2K ABX component, 8 sucessfull trials in a row (& if all successfull in a row, it usually means quick) trials is the minimum for me.
As soon as you begin to fail you can easyly increase to 10 or 12 to try to "erease" your failures.
In this case if you fail once or twice you can usually still get a signifiant result although it usually means the ABXing was hard, & by consequence longer as you begin to hesitate.
Usually if you begin to fail more than 3 times on 12 trials, it begins to be so hard & you have so much hesitation that it begins to take forever to ABX. At this stage I usually give up by myself & declare that I cannot ABX as in general it means I am not sure that the audio part I am focusing on actually contains any real artefact.
This post has been edited by sauvage78: Jan 12 2012, 00:42
CDImage+CUE
Secure [Low/C2/AR(2)]
Flac -4
IgorC
post Jan 12 2012, 03:55
A lot of discussion here but it won't change the disagreement. We can continue to play "now catch me" .
I'm quit of discussion '5/5' as in my consideration I explain my point clear which is: 5/5 is more than acceptable (considering credibility as well as other factors).
saratoga
post Jan 12 2012, 04:06
QUOTE (IgorC @ Jan 11 2012, 21:55) *
If you're not willing to explain why you believe this so that I can help you, I'll just leave you with your link's explanation of why this is not true in general:
Here's another example where numbers can fool us. If we test 20 cables, one by one, in order to know if they have an effect on the sound, and if we consider that p < 0.05 is a success, then in the case where no cable have any actual effect on the sound, since we run 20 tests, we should all the same expect in average one accidental success among the 20 tests ! In this case we can absolutely not tell that the cable affects the sound with a probability of 95%, even while p is inferior to 5 %, since anyway, this success was expected. The test failed, that's all.
For someone so concerned about credibility, you're oddly unwilling to swallow your own pride to save it.
- sauvage78   Minimum number of required ABX trials   Jan 12 2012, 00:41
- - greynol   It is expected that you choose the number of trial...   Jan 12 2012, 00:44
- - saratoga   QUOTE (sauvage78 @ Jan 11 2012, 18:41) Th...   Jan 12 2012, 00:45
- - sauvage78   Well there is the theory & there is real life ...   Jan 12 2012, 00:56
|- - saratoga   QUOTE (sauvage78 @ Jan 11 2012, 18:56) To...   Jan 12 2012, 01:05
- - greynol   He should be conducting sets of 16 trials at first...   Jan 12 2012, 01:10
- - sauvage78   I never said I judged this test valid, I only gave...   Jan 12 2012, 01:13
|- - saratoga   QUOTE (sauvage78 @ Jan 11 2012, 19:13) I ...   Jan 12 2012, 01:17
|- - greynol   QUOTE (sauvage78 @ Jan 11 2012, 16:13) I ...   Jan 12 2012, 01:20
- - sauvage78   saratoga: Yes, I had the feeling that you were thi...   Jan 12 2012, 01:27
|- - saratoga   QUOTE (sauvage78 @ Jan 11 2012, 19:27) Ye...   Jan 12 2012, 01:32
|- - greynol   QUOTE (saratoga @ Jan 11 2012, 16:32) del...   Jan 12 2012, 01:42
- - sauvage78   Well I know this topic isn't about me but my...   Jan 12 2012, 02:31
- - greynol   The difference between you and the OP is that you ...   Jan 12 2012, 02:54
- - sauvage78   I don't even need a log anymore to trust /mnt ...   Jan 12 2012, 03:30
- - IgorC   A lot of discussion here but it won't change t...   Jan 12 2012, 03:55
|- - saratoga   QUOTE (IgorC @ Jan 11 2012, 21:55) A lot ...   Jan 12 2012, 04:06
- - sauvage78   Even if I think 5 trials is too low to convince ot...   Jan 12 2012, 04:01
|- - greynol   QUOTE (sauvage78 @ Jan 11 2012, 19:01) Ig...   Jan 12 2012, 04:13
|- - saratoga   QUOTE (sauvage78 @ Jan 11 2012, 22:01) Ev...   Jan 12 2012, 04:13
- - IgorC   I think I understand what sauvage78 wants to say. ...   Jan 12 2012, 04:46
|- - saratoga   QUOTE (IgorC @ Jan 11 2012, 22:46) It...   Jan 12 2012, 04:50
|- - IgorC   QUOTE (saratoga @ Jan 12 2012, 00:50) QUO...   Jan 12 2012, 04:57
- - sauvage78   QUOTE Are you claiming that I (or greynol) have no...   Jan 12 2012, 04:54
|- - saratoga   QUOTE (sauvage78 @ Jan 11 2012, 22:54) QU...   Jan 12 2012, 05:02
|- - IgorC   QUOTE (sauvage78 @ Jan 12 2012, 00:54) It...   Jan 12 2012, 05:03
|- - greynol   QUOTE (IgorC @ Jan 11 2012, 20:03) So it...   Jan 12 2012, 05:19
- - sauvage78   IgorC: I was more trying to say that if TOS8 is ve...   Jan 12 2012, 05:02
|- - IgorC   QUOTE (sauvage78 @ Jan 12 2012, 01:02) Ig...   Jan 12 2012, 05:06
- - nesf   From a complete newbie perspective: It could have ...   Jan 12 2012, 11:08
|- - saratoga   QUOTE (nesf @ Jan 12 2012, 05:08) From a ...   Jan 12 2012, 23:15
- - apodtele   Please read Fallacy of p-value. I just want to po...   Jan 12 2012, 17:09
|- - Porcus   QUOTE (apodtele @ Jan 12 2012, 17:09) Ple...   Jan 12 2012, 22:07
- - krabapple   It looks like we're groping towards a discussi...   Jan 12 2012, 18:00
- - nesf   A Dummies guide for doing some basic two sample an...   Jan 13 2012, 01:59
RSS Lo-Fi Version Time is now: 31st August 2015 - 12:02
