Minimum number of required ABX trials, Split from from topic ID: 92851
sauvage78
post Jan 12 2012, 00:41
The minimal number of trials depends on how successfull you are.
How quickly you are sucessfull shows how confident in yourself you are.
The time & number of sucessfull trials are tied, you should never separate them when judging an ABX log.
With F2K ABX component, 8 sucessfull trials in a row (& if all successfull in a row, it usually means quick) trials is the minimum for me.
As soon as you begin to fail you can easyly increase to 10 or 12 to try to "erease" your failures.
In this case if you fail once or twice you can usually still get a signifiant result although it usually means the ABXing was hard, & by consequence longer as you begin to hesitate.
Usually if you begin to fail more than 3 times on 12 trials, it begins to be so hard & you have so much hesitation that it begins to take forever to ABX. At this stage I usually give up by myself & declare that I cannot ABX as in general it means I am not sure that the audio part I am focusing on actually contains any real artefact.
This post has been edited by sauvage78: Jan 12 2012, 00:42
CDImage+CUE
Secure [Low/C2/AR(2)]
Flac -4
sauvage78
post Jan 12 2012, 00:56
Well there is the theory & there is real life practice. I agree that chosing the number of trials before the test & chosing a higher number of trials to avoid randomness is better ... but just try to organize a real test with several samples, several encoders (& maybe even several bitrates) ... you will quickly realize that the time it takes goes exponential very quickly specially as the part when you actually decide what to test also takes time & usually goes unoticed for beginner who read the test ...
To be short theorical perfection is indeed better, but time is the ennemy. If you cannot take the necessary time to ABX correctly, you'd better prevent yourself from making any quality claims.
That's why serious ABXing on a large scale is rare.
It''s been years that I wanted to re-ABX Apple AAC & CELT & so far I have always been unable to run the test as it would need 3 days in a row of work, which is discouraging as I use 100% lossless anyway.
This post has been edited by sauvage78: Jan 12 2012, 01:01
CDImage+CUE
Flac -4
saratoga
post Jan 12 2012, 01:05
QUOTE (sauvage78 @ Jan 11 2012, 18:56) *
You can mitigate this to some extent by carefully picking what you will ABX. If A/B comparisons of a sample and control reveal no apparent differences, its probably not worthwhile to ABX it. Just announce that you can't tell the difference and move onto something else. Failing an ABX test proves nothing, so no sense doing it needlessly.
Looking at this test, I think the OP did more trials then he needed to, but he did them of the wrong samples. It seems like he only thinks he can ABX one or two of the 10 samples, so the obvious thing to do would have been to do about 10-12 trials of each of those few samples.
- sauvage78   Minimum number of required ABX trials   Jan 12 2012, 00:41
- - greynol   It is expected that you choose the number of trial...   Jan 12 2012, 00:44
- - saratoga   QUOTE (sauvage78 @ Jan 11 2012, 18:41) Th...   Jan 12 2012, 00:45
- - sauvage78   Well there is the theory & there is real life ...   Jan 12 2012, 00:56
|- - saratoga   QUOTE (sauvage78 @ Jan 11 2012, 18:56) To...   Jan 12 2012, 01:05
- - greynol   He should be conducting sets of 16 trials at first...   Jan 12 2012, 01:10
- - sauvage78   I never said I judged this test valid, I only gave...   Jan 12 2012, 01:13
|- - saratoga   QUOTE (sauvage78 @ Jan 11 2012, 19:13) I ...   Jan 12 2012, 01:17
|- - greynol   QUOTE (sauvage78 @ Jan 11 2012, 16:13) I ...   Jan 12 2012, 01:20
- - sauvage78   saratoga: Yes, I had the feeling that you were thi...   Jan 12 2012, 01:27
|- - saratoga   QUOTE (sauvage78 @ Jan 11 2012, 19:27) Ye...   Jan 12 2012, 01:32
|- - greynol   QUOTE (saratoga @ Jan 11 2012, 16:32) del...   Jan 12 2012, 01:42
- - sauvage78   Well I know this topic isn't about me but my...   Jan 12 2012, 02:31
- - greynol   The difference between you and the OP is that you ...   Jan 12 2012, 02:54
- - sauvage78   I don't even need a log anymore to trust /mnt ...   Jan 12 2012, 03:30
- - IgorC   A lot of discussion here but it won't change t...   Jan 12 2012, 03:55
|- - saratoga   QUOTE (IgorC @ Jan 11 2012, 21:55) A lot ...   Jan 12 2012, 04:06
- - sauvage78   Even if I think 5 trials is too low to convince ot...   Jan 12 2012, 04:01
|- - greynol   QUOTE (sauvage78 @ Jan 11 2012, 19:01) Ig...   Jan 12 2012, 04:13
|- - saratoga   QUOTE (sauvage78 @ Jan 11 2012, 22:01) Ev...   Jan 12 2012, 04:13
- - IgorC   I think I understand what sauvage78 wants to say. ...   Jan 12 2012, 04:46
|- - saratoga   QUOTE (IgorC @ Jan 11 2012, 22:46) It...   Jan 12 2012, 04:50
|- - IgorC   QUOTE (saratoga @ Jan 12 2012, 00:50) QUO...   Jan 12 2012, 04:57
- - sauvage78   QUOTE Are you claiming that I (or greynol) have no...   Jan 12 2012, 04:54
|- - saratoga   QUOTE (sauvage78 @ Jan 11 2012, 22:54) QU...   Jan 12 2012, 05:02
|- - IgorC   QUOTE (sauvage78 @ Jan 12 2012, 00:54) It...   Jan 12 2012, 05:03
|- - greynol   QUOTE (IgorC @ Jan 11 2012, 20:03) So it...   Jan 12 2012, 05:19
- - sauvage78   IgorC: I was more trying to say that if TOS8 is ve...   Jan 12 2012, 05:02
|- - IgorC   QUOTE (sauvage78 @ Jan 12 2012, 01:02) Ig...   Jan 12 2012, 05:06
- - nesf   From a complete newbie perspective: It could have ...   Jan 12 2012, 11:08
|- - saratoga   QUOTE (nesf @ Jan 12 2012, 05:08) From a ...   Jan 12 2012, 23:15
- - apodtele   Please read Fallacy of p-value. I just want to po...   Jan 12 2012, 17:09
|- - Porcus   QUOTE (apodtele @ Jan 12 2012, 17:09) Ple...   Jan 12 2012, 22:07
- - krabapple   It looks like we're groping towards a discussi...   Jan 12 2012, 18:00
- - nesf   A Dummies guide for doing some basic two sample an...   Jan 13 2012, 01:59
RSS Lo-Fi Version Time is now: 8th July 2015 - 05:45
