DSP Loudness Control, What is Best Filter architecture
easily_confused
post Jan 10 2012, 05:39
I want to implement bass boost based on volume setting. Basically the low end (below 2KHz) of the Fletcher Munson curves. I don't want to try to dynamically load interpolated biquad filter coefficients based on the volume control. Is ther some other filter architecture that will produce the approx. 0db per octave (loud) to 12 dB per octave (low volume) bass boost in a simpler way. An example of a simple 6dB only analog control is at extron.com http://www.extron.com/company/article.aspx...p;version=print . This would be simple to implement as an iir filter, but I want to go a little fancier. Thanks
2 Pages V   1 2 >
Replies (1 - 24)
pdq
post Jan 10 2012, 13:46
How about taking the unfiltered data, and the data with max bass boost applied, and calculate some linear combination of the two based on volume setting?
Woodinville
post Jan 10 2012, 14:13
You need a time-varying system with knowlege of the absolute gain of the entire system including transducer in order to make this work.
J. D. (jj) Johnston
DVDdoug
post Jan 10 2012, 20:34
I think what you are looking for is a shelving filter (or, something bassed on shelving filters) rather than standard filter that boosts xdB/octave with a constant slope.
This post has been edited by DVDdoug: Jan 10 2012, 20:43
easily_confused
post Jan 10 2012, 21:43
Hmmm, - implementing the exton example is not as simple as I expected.
I guess a biquad configured as a variable gain shelving filter is the simplest. That requires recomputing the coefficients based in a sine table. I wonder where I could look to see who has already done a loudness control for a dsp?
bandpass
post Jan 15 2012, 10:48
SoX has an accurate FFT FIR filter implementation for loudness control; it also has simple biquad shelving filters (based on RBJ's biquad cookbook). I'm guessing maybe you want to take the code from the loudness filter that determines the bass boost (for a particular freq and loudness) and use this to help configure a low-shelf biquad.
Woodinville
post Jan 16 2012, 01:05
Again, you need a signal-dependent EQ that operates with knowlege of the exact overall system gain. You've chosen a hard problem.
J. D. (jj) Johnston
hellokeith
post Jan 16 2012, 05:20
QUOTE (Woodinville @ Jan 15 2012, 19:05) *
JJ,
How is low-volume bass boost different than other "maintaining intensity" problems?
saratoga
post Jan 16 2012, 05:39
I always wondered if they're any good open source implementations of these bass boost algorithms? Or do people typically cook their own from scratch.
Woodinville
post Jan 16 2012, 06:24
QUOTE (hellokeith @ Jan 15 2012, 20:20) *
JJ,
It's not, and they all have the same problem.
J. D. (jj) Johnston
splice
post Mar 18 2012, 12:00
QUOTE (Woodinville @ Jan 15 2012, 21:24) *
... How is low-volume bass boost different than other "maintaining intensity" problems?
I don't see it as a hard problem to solve, if you restrict the solution to recorded music. Most recorded music has been deliberately equalised to sound "right" (as the artist, or at least the mastering engineer, intended) at a specific SPL. Many mastering engineers use an average level of -20dB ref to FS, and adjust monitor levels to give about 86 dB SPL C weighted at their listening position. Audio for home theatre uses a reference of 105 dB at FS. That's pretty close to 86 dB at -20 dB FS. So a loudness compensation control doesn't have to be complicated. It just has to increase the bass level by a fixed ratio as the level (volume control) is reduced.
The required loudness compensation appears to be in the order of 2:1. For example, if you decrease the overall gain by 10 dB, you need to increase the bass by 5 dB at 20 Hz. Most simple tone control circuits max out at about 12 to 18 dB boost or cut. Matching this with a coupled volume control would result in a volume adjustment range of plus or minus 24 to 36 dB. Assuming an 86 dB SPL centre point, the 36 dB figure would correspond to an in-room range from 50 to 122 dB, which is adequate.
In practice, you set the control to "flat" and adjust a master gain so that the music sounds "right". The music should then still sound "right" as you decrease or increase the level from that point.
You might argue that you would need to repeat the setup for each source or track, but in practice most modern music is so heavily compressed ("loudness wars") that one calibration will suffice for most of it. Even before CD, most LPs had reasonably similar levels to each other - set, in this case, by the limitations of the playback cartridge.
Most of the above was excerpted from posts I made a couple of years ago here:
http://www.diyaudio.com/forums/solid-state...ss-control.html
See post #31 for proof of concept circuit.
Regards,
Don Hills
dc2bluelight
post Mar 30 2012, 09:40
First, the Fletcher-Munson data is not accurate. See the work of S. S. Stevens, much better. Ever notice how a Fletcher-Munson loudness compensation control never sounds right? That's because they got it wrong to begin with.
Second, Woodinville is right, it IS a hard problem, it's not a fixed curve, and it is highly dependent on the specific acoustic play level, so it has to be dynamic.
Next...why number them...BIG assumption that everybody mixes to a standard level in a standardized monitoring environment. Not in the music industry! Film, yes, but not music. And that -20dbFS would be nice, but doesn't happen after mastering, especially pop stuff. Not even close. Pretty much have to ignore dbFS in this case, it's not relevant. System acoustic play level is though. But in the context of correcting for differing hearing response at differing levels. You're in no way matching the mix environment, there's just no way to know what it was, and it's not important anyway.
No, you can't do it based on a volume control setting. Been tried by many people for many years, but it doesn't work. The reason is simple: the correction required is dependent on SPL, which a volume control may influence but doesn't predict and is not the only thing that affects it. Hotter signal into it, and you turn it down, but that would change the compensation inappropriately. There were even attempts to calibrate the compensation by adding another control, but it doesn't work because program dynamics are not fixed. No, the correction must be tied to specific SPL, not a control setting. That's actually where many people trying this messed up.
If you look at the Stevens data, or even Fletcher-Munson for that matter, you'll see that the compensation curve families resemble that of a dynamics processor with a dynamic transfer function that changes with frequency, not a fixed filter. The amount you need at 20Hz changes with level at a different rate than the amount you need at 200Hz.
And finally, it's been done, and done quite well. It's called Audyssey Dynamic Volume and Dynamic EQ. Rather than base their idea on existing loudness research, their algorithm is based on what was essentially reverse-engineering human loudness perception. They took LOTs of data on lots of subjects, with lots of different program material and the result is pretty darn good. The big advantage is, once an Audyssey system has been calibrated it knows the exact SPL at every moment regardless of volume control setting or variations in program material, so it can apply the right correction dynamically. Pretty darn smart, those guys.
splice
post Mar 30 2012, 12:12
QUOTE (dc2bluelight @ Mar 30 2012, 00:40) *
That's true, but you're putting up a straw man. I haven't said which "loudness curve" I based my reasoning on, either here or in the thread I referenced. In fact, I used ISO 223:2003, which was referenced by someone else early in the thread.
Is Stevens still about? I haven't seen any work from him for many years.
Ah, yes, but that doesn't make it hard to solve, at least approximately. Say you increase the level at 1 KHz by 6 dB. The change required to produce a similar perceived level increase at, say, 20 Hz is about 3 dB. This ratio holds true over a wide range of phons. So all you need is a coupled level and bass equalisation control that, for every 6 dB of level reduction, adds equalisation resulting in 3 dB of boost at 20 Hz relative to 1 KHz. (Every time the midrange level drops by 6 dB, the bass level drops by 3 dB).
Standardised, or at least similar, monitoring levels are more common than you might think once you move up the ladder a bit. Ask Bob Katz, he could "bore for Africa" on the subject. And the -20 dBFS is relevant for monitoring when mastering, it has no relevance to the final released media level. As for matching the mix environment, try it yourself, assuming you have a competent reproduction chain. For most genres other than the highly artificial (electronica etc), there is a definite SPL at which they sound "right". So even though it may not match the mix environment levels, it sounds balanced to you on your system.
You need two controls. One to set the initial volume level so that it sounds "right", then the coupled control to change the volume to the setting you want to listen at. In theory you would need to do this for each track, or at least each album, but in practice most sources of a given genre and age have similar levels. If you play old vinyl, you should be familiar with the way that the majority of LPs end up being played within a relatively small arc of the volume control. Ditto but different setting for old CDs, and again for current "loudness war" CDs. Apple's Soundcheck and MP3 Replaygain standardise the levels even more.
... And finally, it's been done, and done quite well. It's called Audyssey Dynamic Volume and Dynamic EQ. Rather than base their idea on existing loudness research, their algorithm is based on what was essentially reverse-engineering human loudness perception. They took LOTs of data on lots of subjects, with lots of different program material and the result is pretty darn good. The big advantage is, once an Audyssey system has been calibrated it knows the exact SPL at every moment regardless of volume control setting or variations in program material, so it can apply the right correction dynamically. Pretty darn smart, those guys.
... and missing the point when it comes to music dynamics. Chris acknowledges that the Audyssey dynamically changes the EQ in response to changing program levels. But this is exactly what you do not want when listening to music. As I said elsewhere:
".... Take Ravel's "Bolero". The double bass initially comes in while the levels are still moderate. The loudness of the bass is chosen to be audible but not overpowering. As the piece progresses and the overall levels rise, the bass level also rises but still in proportion to the rest of the players - if the overall level rises by 10 dB, the bass level rises by somewhat less. The point is that "loudness compensation" is built into music by the composers / musicians / mix engineers, and if you make a static adjustment to the volume, you only need to make a static adjustment to the loudness compensation. The rest is already taken care of in the music. "
And why I think loudness compensation is needed:
"... In my opinion, music is best listened to at the SPL at the listener position that it was created for. (Creation may mean the original performance, or the engineer's creation of a mix of separate components recorded at different times in different acoustics - or no acoustic at all in many cases.) If we normally listened at this SPL, there would be no need for any loudness compensation. But we do like to listen at different levels for several good reasons, and when we do so we no longer hear the intended tonal balance. Many of us like to adjust the tonal balance at our chosen listening level so that it is similar to the perceived tonal balance at the "correct" level. Done properly, we find this adjustment effective and pleasing. It is an effective mitigation of the degradation forced by having to listen at a different level to that which the work was intended for.
And on the topic of tonal balance change with level:
"... In the specific case of loudness compensation, we aren't correcting for human hearing deficiencies. We're compensating for deficiencies in the reproduction environment.
In a "live" situation, if we move away from the source we experience an overall level decrease. In addition, the treble decreases somewhat faster than the midrange, and the bass somewhat less. We perceive this as a natural tonal balance change, which needs no correction.
In a reproduction scenario, if we reduce the volume by a similar amount, the tonal balance does not change. Compared to a distance increase, we have too much treble and not enough bass. We perceive this as unnatural. This is why I believe in leaving the HF compensation alone and just boosting the bass. The natural change in HF sensitivity of the ears, as illustrated by the "loudness curves", takes care of the required additional HF attenuation, so only the bass requires compensation. ..."
I suggest you read the referenced thread in DIYAudio, if you haven't done so already. All of the points you raised were also raised there.
This post has been edited by splice: Mar 30 2012, 12:18
Regards,
Don Hills
Woodinville
post Mar 30 2012, 21:05
QUOTE (dc2bluelight @ Mar 30 2012, 01:40) *
Whoa, there, the reason a "loudness control" doesn't work is simple, it doesn't work because it is not time varying (according to signal and absolute presentation level) or signal dependent.
Stevens' curves and Fletcher's curves are not far off, if you remember that one used open ear canals and one closed ear canals. Unsurprisingly, the frequency of the ear canal resonance shifts by approximately an octave as a result. No surprise there.
I wouldn't be so fast to dismiss Fletcher, especially since by any reasonable reading, Stevens is more confirmation than anything else. Claiming "Fletcher got it wrong" is just unjustifiable, and is almost as bad yellow journalism as the crap put forth in the article in Spectrum where it was asserted that Fletcher was trying to figure out how cheap AT&T could make transmission.
If you build a codec based on Fletcher's results (Using modern understanding), you get to AAC, via the original version of AT&T PAC, from before the 'trivestiture". That's not conjecture, that's personal experience.
And Splice, please realize that the thing you want to build must be signal dependent, and must be tied to absolute presentation level as a function of frequency. Signal dependency is not an option, it's a requirement.
This post has been edited by Woodinville: Mar 30 2012, 21:07
J. D. (jj) Johnston
splice
post Mar 31 2012, 01:42
Post #15
QUOTE (Woodinville @ Mar 30 2012, 12:05) *
... And Splice, please realize that the thing you want to build must be signal dependent, and must be tied to absolute presentation level as a function of frequency. Signal dependency is not an option, it's a requirement.
I'm missing some crucial piece of understanding. Please bear with this "bear of very small brain" for a bit...
"Signal dependant" - do you mean in time or frequency?
To me, one implies a dynamic EQ that adjusts itself according to the current level or spectral content of the signal (e.g Audyssey processor), the other a static EQ, the curve of which is adjusted according to the auditory system behaviour described by the "equal loudness" curves.
"Tied to absolute presentation level as a function of frequency" - I interpret this as saying that each chosen presentation SPL must have a matching EQ curve. My assertion is that each *change* in presentation SPL requires a fixed *change* in the EQ curve. Almost, but not quite, the same thing.
"Signal dependency being a requirement" - I take that to be the first part of the process. With no EQ, adjust the listening SPL until the source sounds "right" or "natural" or otherwise sounds pleasing. Now use the "loudness" control to make all level adjustments after that.
(If I were to implement this in DSP instead of analog controls, I'd make it more user friendly by unidirectionally coupling the level and loudness controls for the initial adjustment.)
I think part of the understanding problem is the way that the function being compensated for is dynamic - the amount of compensation required changes as the absolute SPL changes, so how can it be compensated for by a statically adjusted EQ? As I tried to explain earlier, the spectral balance of the music is fixed at source - the "Bolero" example - so a fixed compensation is appropriate. You don't have to adjust the bass tone control as a piece of music goes from pianissimo to fortissimo - the musicians have done that for you already. All the "loudness" control does is mimic what happens when you walk from the front of the hall to the back - although a concert hall is a bad example, perhaps more like an open-air concert.
I've been procrastinating because of the difficulty of building such a circuit in the analog domain - not difficult for me, but a disincentive for anyone wanting to try it who doesn't have constructional skills. It occurred to me last night that I should try my hand at coding a foobar plugin implementation. It would make it easy for anyone wanting to try it out.
Regards,
Don Hills
Regards,
Don Hills
dc2bluelight
post Mar 31 2012, 03:13
Post #16
Perhaps my statement as to Fletcher-Munson getting it wrong was a bit to generalized. Their data was accurate for the conditions in which it was taken, and the test equipment available in that day. But, since those conditions included pure tones as stimuli presented as a frontal field in an anechoic space, the resulting curves don't represent the actual correction needed for real listening environments. The really unfortunate part of Fletcher-Munson is that the curves became widely adopted, but almost entirely misunderstood. They were applied as complete loudness correction curves, when in fact, they represent human hearing response (in those specific test conditions). Loudness compensation doesn't need to correct for human hearing response, it just needs to correct for the variance in response at differing levels.
Later research using more modern measurement equipment and more appropriate methods yielded better data. Yet even though adopted as a standard, Robinson-Dodson's data (pure tones again, but presented with headphones or random incidence) isn't as pertinent to real listening conditions as is really required, and they freely admit that fact in their paper.
There have been many, historically, who have attempted to characterize human loudness perception, some of them fairly well known (Zwicker, or the Bauer-Torick papers), and what's interesting is there reasonable correlation between all of them, particularly in that the ear response is anything but flat even at live music levels of 100dB or so. The exception, interestingly, is the Fletcher-Munson data, which shows response at 100dB that is much flatter than any other curve family. For that reason alone, the F/M data would not appropriate to apply in a loudness compensation scheme.
To complicate things, as most equal loudness curves go, even Fletcher-Munson, the high frequency portion of the curves above 1KHz are parallel, and so no adjustment is required in that range. But designers applying the F/M equal loudness data to a loudness comp circuit often used the entire curve! So we had boost at the top and bottom, and of course, the wrong amount at the bottom in any case.
Stevens work included a wide variety of stimulus methods, from diffuse, free-field, earphones, etc., and included several subjective quantities as well (annoyance, etc.). One of his test systems extended down to 1Hz! And while that's not useful for loudness compensation, it's notable since other research stops at 20Hz.
At the risk of repetition, it's important to note that the equal-loudness contours found in Stevens, F/M or any other do no represent the actual correction needed, but reflect hearing response. The correction system would actually apply a differential curve, which would, in fact, have to be dynamically variable, a fact easily seen on any equal loudness contour family.
So, I'm afraid I'll modify my Fletcher-Munson comment only slightly: Their data is valid for their test conditions, and considering the limitations of test equipment of the day. However, to consider it at all relevant to an actual loudness compensation algorithm would be an error. Perhaps that's more accurate than "they got it wrong", but you see what I mean.
As to the supposed loudness compensation built into music by composers (Ravel, et al), their hypothetical compensation is valid for only one listening position: the conductor's podium. Ever other seat in the house will hear something else. However, no seat will have a basic level change anywhere near 20dB. Yet that's the kind of level shifts we see in recorded music played in private listening conditions. With that kind of offset, and looking at any equal loudness contour curve family, anyone can see for this to work it must be dynamic and must operate with the knowledge of actual playback SPL. No fixed modifier would be correct at anything but one specific SPL.
The dual-control loudness compensation idea has been tried (Yamaha, late 1970s, early 1980s, Apt-Holman, 1978), but has not survived even though the Apt-Holman implementation actually applied correction based on the Stevens data. The reason is simple: people can't be depended upon to make continual subjective evaluation and apply correction. Two knobs might get you close, but only at one SPL (at least some music still has dynamic range), and one volume setting. The knob would require constant adjustment, something no listener will do.
Bob Katz has made some excellent inroads in studios, but there's decades of music already recorded and released without any of that, and still today volumes of music released without standardization. The film industry became standardized, at least in the high-fidelity sense, when Dolby Labs became involved. That's been 40 years. No, it's wild in music to this day, though getting better.
I don't now how else to make the point that compensation must be dynamic, but if all of the above doesn't do it, perhaps ask yourself: if it's so simple as to be a fixed, static correction, why at this point in history have we moved completely away from fixed-curve and dual control systems? Why do the pre-eminaet voices in this field all say it has to be dynamic? Must be something they know.
Woodinville
post Mar 31 2012, 03:40
Post #17
QUOTE (splice @ Mar 30 2012, 17:42) *
You need frequency domain equalization (i.e. a filter curve) that varies with the signal (and of course frequency and presentation level), and where the actual gain of the system post-filter is known to a dB or so.
J. D. (jj) Johnston
Woodinville
post Mar 31 2012, 03:44
Post #18
QUOTE (dc2bluelight @ Mar 30 2012, 19:13) *
Interestingly, F-M and Stevens disagree on loudness growth at low frequencies, and having built systems using both models for loudness growth, I've been much, much more successful with a variation on F-M than I have with Stevens (annoyingly that work belongs to long-former employer, not even a recently former employer, and it hasn't been put to any use at all).
As to the flatness concern, once you realize that the bandwidth of the critical bands emerges as a factor, F-M makes a great deal of sense, actually.
But, as far as loudness ratio, I've had much more success with loudness ratios using a model I can't talk about (snarl, hiss, grumble) very much that are derived from F-M. Fletcher and Munson show more loudness growth at threshold than Stevens, and that's also been my experience.
J. D. (jj) Johnston
dc2bluelight
post Mar 31 2012, 06:20
Post #19
QUOTE (Woodinville @ Mar 30 2012, 21:44) *
Ah, someone with real hands on, now that's a treat!
What would be your comment on why F-M didn't work historically? And why the Stevens-based systems worked markedly better, if much more rare? I'd have some ideas, but I'd rather hear it from someone who made a F-M system actually work.
This would fill in a few holes in what has been a 35 year hot topic for me. F-M always seemed to do too much in the LF in the classic realizations.
splice
post Mar 31 2012, 07:56
Post #20
(Excuse my trimming of quotes, I'm trying to keep post lengths down. If you think I've trimmed too much and misrepresented your points, please say so.)
QUOTE (dc2bluelight @ Mar 30 2012, 18:13) *
... the resulting curves don't represent the actual correction needed for real listening environments. ... Loudness compensation doesn't need to correct for human hearing response, it just needs to correct for the variance in response at differing levels.
That's it exactly. You understand it here, but why do you remain skeptical at the end of your post?
This is where so many seem to get it wrong. As you point out, there's no need to apply an EQ curve that's the inverse of a given "equal loudness" contour of whatever provenance. All that is needed is a correction to compensate for reproducing a source (music) at a different level than that it was originally performed / mastered for. Take a look at the ISO 226:2003 "equal loudness" curves. As a crude example, imagine you're listening to two tones - 20 Hz and 1 KHz - at the 60 phon level. You perceive them as equally loud, although the 1 KHz tone is at 60 dB SPL and the 20 Hz tone is at 110 dB SPL. Now you turn down the "volume" by 20 dB. This is equivalent to moving the 60 phon curve down to the 40 phon curve. The problem is that they don't match. You've lowered the 1 KHz signal from 60 dB SPL to 40 dB SPL, and you've lowered the 20 Hz signal from 110 dB SPL to 90 dB SPL. But you can see from the curves that a 20 Hz signal should be reproduced at 100 dB SPL to match the 40 dB SPL 1 KHz signal in loudness. In short, if you change the level at 1 KHz by x dB, you have to change the level at 20 Hz by x/2 dB. This is a ratio, not a fixed EQ. It doesn't need an absolute reference level to work.
Other researchers have done work in the 1-20 Hz area recently. I have papers by Yeowart and Evans, and Moller and Pederson, but there may well be others.
I'm not proposing a fixed modifier. I'm proposing a fixed ratio (2:1 as a ballpark figure). If the loudness compensation (crudely, the bass level relative to the midrange level) is correctly set at one specific SPL, and the ratio is applied to any level change, then the compensation will also be correct at the new SPL.
I'm aware of the earlier schemes. They did not accurately couple (or in some cases couple at all) the level and "loudness compensation EQ" controls. I do. "Continual subjective evaluation" is thus not required, and the right amount of correction is applied regardless of the listening level.
Most of my listening is to various sub-genres of "rock". My vinyl collection spans some 20 years. Almost all of it plays back within a 20 degree arc of the volume control. My early CDs play back as a group, there's the 90s transition, then most of the last 10 years play back as another group. I accept that other genres may be more varied in their playback levels. My point is that it's not hard to establish a playback level that the music was intended to be heard best at, and this level doesn't vary all that much between like grouped sources.
I don't now how else to make the point that compensation must be dynamic, but if all of the above doesn't do it, perhaps ask yourself: if it's so simple as to be a fixed, static correction, why at this point in history have we moved completely away from fixed-curve and dual control systems? Why do the pre-eminaet voices in this field all say it has to be dynamic? Must be something they know. ...
I remain unconvinced. I'm not proposing a "fixed, static" correction. My proposal is also different than any "dual control" system I have seen, and I have been looking hard. And if by "dynamic" you mean that the EQ adjusts itself based on the (varying) level of the source, then I disagree strongly. That would be equivalent to twiddling the bass tone control to match the loud and quiet parts of the music, and we just don't do that. (Well, I don't, anyway.)
One more time... My system has two knobs. As I originally envisaged it, one knob is more or less "set and forget" for a given genre and input source, especially if the source has Soundcheck or Replaygain. The other knob is the main "volume" control. Adjusting this control also applies the correct amount of "loudness compensation" for that volume. In concept, the bass tone control is ganged to the volume control. Where this differs from other schemes is that the ratio of bass to overall level is fixed, and matches the ratio inherent in the "equal loudness" curves.
An alternative scheme which may be more user friendly is to again have two knobs - one labeled "volume" and one labeled "bass", which actually sets the operating point of the loudness compensation. Adjust the volume control to your desired level, regardless of the original intended playback level, then adjust the bass control to your taste - "not too heavy, not too light". But behind the scenes, the two controls are actually linked, so any subsequent adjustment of the volume control automatically applies the correct level of loudness compensation.
Regards,
Don Hills
Woodinville
post Mar 31 2012, 09:25
Post #21
QUOTE (dc2bluelight @ Mar 30 2012, 22:20) *
Not having hands-on other Stevens systems, I suspect it was getting the skirts on the cochlear filters right. The upward spread that reduces loudness of higher frequencies near masking level can bite pretty hard if you don't get it right.
But that is a conjecture.
J. D. (jj) Johnston
Woodinville
post Mar 31 2012, 09:27
Post #22
QUOTE (splice @ Mar 30 2012, 23:56) *
For a given standard genre, this has a shot at working "ok", I think.
Unusual music will give it fits, though, I suspect.
J. D. (jj) Johnston
dc2bluelight
post Mar 31 2012, 10:01
Post #23
QUOTE (splice @ Mar 31 2012, 01:56) *
Ok, but that's precisely what is required.
Yes, I understand what you are saying, but please understand that this has been done, and did not succeed because because of an error in concept outlined in your previous sentence, "the ratio of bass to overall level is fixed, and matches the ratio inherent in the "equal loudness" curves." The curve families show the ratio of bass to overall level is not fixed, it's a non-linear relationship. Because it's non-linear, every time you change the overall level, you operate at a point where the rate-of-change in bass sensitivity is different, and the lower the overall level the faster the rate of change in bass sensitivity. It's the rate-of-change problem that dictates the fact that compensation cannot be fixed. It must track the rate of change of bass sensitivity of the ear. The ear/brain system has what is essentially a volume expander that is both frequency and level dependent. The expansion ratio is dependent on the specific SPL as well as the specific frequency of stimulus. That's why it takes a family of equal loudness curves to show what's actually going on, and also takes something fairly complex and dynamic to perform the compensation. We're kicking around the details of what curve-set to follow in other posts, but they all have this non-linear ratio characteristic.
Actually, this is exactly what Yamaha and Holman did, as I mentioned before. Yamaha had a Volume knob and a Loudness knob, which set the amount of fixed bass boost. You set the volume, then set the loudness to taste. The Apt-Holman preamp had a Volume control and a Bass control with a contour that matched a differential curve derived from Stevens. Again, you set the volume as desired, then set the bass for the best subjective compensation. However, in Holman's 1977 AES paper, "Loudness Compensation: Use and Abuse", from which his bass control-loudness comp was derived, among his conclusions he states that while variable compensation is required, the only correct solution would be for it to react to program material (sorry, I'll post the exact quote later). The technology to accomplish that accurately and economically didn't exist then, but does now.
It would seem the that this conclusion is supported by the fact that loudness compensation began to vanish from consumer audio gear from the 1980s onward, and with the exception of several DSP based dynamic systems such as the afore mentioned Audyssey, (which by the way, Holman was involved with), Dolby Volume (subjectively less effective, because while it's dynamic, it doesn't have specific SPL information on which to base its correction), loudness compensation has not generally made a reappearance in today's products. If you can answer the question of why that might be, you'll also answer the question of why a simple approach isn't effective and therefore, not used.
splice
post Mar 31 2012, 11:05
Post #24
QUOTE (Woodinville @ Mar 30 2012, 18:40) *
OK, I think I get it. Let me explain it as I understand it and please tell me if I have it right.
As I see it, the source was performed / mastered to sound "right" at a given SPL. This implies listening to it at that SPL, where the relative levels of bass vs midrange are as intended. "Loudness compensation" maintains the perceived balance between bass and midrange when the "volume control" is adjusted to listen at SPLs other than those for which the music was "designed". I suspect we're all in agreement so far?
Where we appear to differ is in how this compensation might be achieved, and how difficult it would be for the listener to use.
I see it as easy to achieve. In principle it is a Baxandall type bass tone control coupled to a "volume" control - lowering the listening level increases the bass boost and vice versa. The coupling ratio is set so that a change in the listening level is matched by a change in the bass level that restores the perceived balance between bass and midrange. The coupling is "one way" - you can adjust the bass separately from the volume, but adjusting the volume will always adjust the bass.
To use it, you play the music, and adjust the volume control to your desired listening level. You then adjust the bass until it sounds right to you - "not too heavy, not too light." (Alternatively, you can initally adjust the volume to a "realistic" or "life size" level and set the bass to "flat".) You can then change the listening level and the "loudness compensation" will track the change, so the perceived bass - midrange balance doesn't change. This will likely require readjustment of the bass as well as the volume control if you make a significant change to the input level, for example from an 80s vintage CD to a 00s vintage CD, but I submit that it is an intuitive adjustment and a small price to pay for the added perfomance. This assumes a standalone implementation for use with classic analog sources, but it can be fully automated if you have all your music on a server with Soundcheck / Replaygain set.
This differs from earlier schemes of loudness compensation.
The "tapped volume control" is at best only an approximation of the desired curve, only works over part of the travel of the volume control, and only tracks properly if the normal listening level occurs close to maximum clockwise rotation of the pot.
The separate loudness control (Yamaha et al) does not track the volume control setting at all. It has to be readjusted for each volume setting change.
If you know of any implementation where the loudness control is coupled to the volume control, I'd like to hear of it. It's so obvious (to me at least) that I can't see why it hasn't been done before. I tend to agree that the must be a catch, that if it really were that easy it would have been done before, but so far no-one has come up with a practical reason why it wouldn't work beyond the added complexity to the user.
Regards,
Don Hills
splice
post Mar 31 2012, 11:36
Post #25
QUOTE (dc2bluelight @ Mar 31 2012, 01:01) *
... if by "dynamic" you mean that the EQ adjusts itself based on the (varying) level of the source, then I disagree strongly. That would be equivalent to twiddling the bass tone control to match the loud and quiet parts of the music, and we just don't do that. (Well, I don't, anyway.)
Why do you think it is required? If you wouldn't manually adjust the bass control during the "performance", for example during the playing of Ravel's "Bolero", why would you want a DSP to do it for you?
... Yes, I understand what you are saying, but please understand that this has been done, and did not succeed because because of an error in concept outlined in your previous sentence, "the ratio of bass to overall level is fixed, and matches the ratio inherent in the "equal loudness" curves." The curve families show the ratio of bass to overall level is not fixed, it's a non-linear relationship. Because it's non-linear, every time you change the overall level, you operate at a point where the rate-of-change in bass sensitivity is different, and the lower the overall level the faster the rate of change in bass sensitivity. It's the rate-of-change problem that dictates the fact that compensation cannot be fixed. It must track the rate of change of bass sensitivity of the ear. The ear/brain system has what is essentially a volume expander that is both frequency and level dependent. The expansion ratio is dependent on the specific SPL as well as the specific frequency of stimulus. That's why it takes a family of equal loudness curves to show what's actually going on, and also takes something fairly complex and dynamic to perform the compensation. We're kicking around the details of what curve-set to follow in other posts, but they all have this non-linear ratio characteristic.
What's non-linear about a 2:1 ratio that holds over at least an 80 dB range? I'm missing something here. (Not my marbles, every morning I look in my toybox and there they are.) I'm getting an impression from you and JJ that loudness compensation EQ has to vary as the signal level varies within a given musical performance, and I find that hard to accept. If it is in fact the case, I have some learning to do. I'll have to get Holman's paper that you referenced.
Regards,
Don Hills
2 Pages V   1 2 >
RSS Lo-Fi Version Time is now: 1st February 2015 - 17:02
