Any suggestions on minimising tiny encoderís heap usage on ARM7?
okey
post Jan 10 2012, 00:46
I'm working with an LPC2387 chip (72MHz) and a quite limited amount of RAM, and I need to run tinyencoder on it. 'As is', the malloc calls to create buffer space in pack_audio() (in tinypack.c) fail, because there isn't enough heap space. Any suggestions to reduce the heap footprint as much as possible?
The audio data I'm working with is 8KHz 16-bit, and I'm using the TinyEncoder source from the Wavpack download page. I suspect I may be going about this the wrong way since the readme says there is no malloc/free usage...
saratoga
post Jan 10 2012, 00:56
QUOTE (okey @ Jan 9 2012, 18:46) *
How much RAM?
tinypack.c isn't part of the decoder. Its the example program showing you how to use the library. It mallocs some large buffers to hold the input data. If you don't have that much RAM, either don't use the example program (since you probably don't want to actually run it on your device...) or process from smaller buffers.
okey
post Jan 10 2012, 01:22
QUOTE (saratoga @ Jan 10 2012, 11:56) *
How much RAM?
64KiB. Much of which (~36-40KiB) is needed elsewhere.
Thanks. That's pretty much what I needed to know. I had arrived at the conclusion that some of it was intended as an example, but due to some spectacular mental failure I failed to realise that all of was intended as such. Duh.
RSS Lo-Fi Version Time is now: 31st January 2015 - 09:36
