APEv2 tags in MP3, aimed: generally, at implementation, in rel.w/ foobar2000, vs. ID3v2.4
Tigermess
post Dec 29 2011, 19:30
Recent topics on ID3v2.4 and APEv2 implementation in foobar2000 (like this and that and others) raise the chase between ID3v2.4 and APEv2 tags. I'd like to start this topic as a branch of first mentioned topic, concerning APEv2 tags in MP3 files.
I want to choose optimal type of tags for MP3s with which I'll stick for few following years. ID3v2.3, ID3v2.4 and APEv2 are in the game. For long I've been tagging ID3v1+ID3v2.3, recently I started to like idea of multifields but after the discussions above I'm not sure what tag type is the best (selfishly enough for my needs). I'd appreciate multifields but I still want to keep best possible compatibility with most used SW/HW. In this matter after some googling and searching I have some questions about APEv2 and will be glad if you could help, especially if you were dealing with similar questions yourselves.
Q1: Are APE tag names standardized anyhow??
HA wiki says:
Just like Vorbis comment it defines some standard fields, but it also defines some formats for those fields (like what a date should look like).
I couldn't find it. Does any informal standard or recommendation exist? If not, default settings of most used players are standards enough - do iTunes, Winamp, foobar2000, Media Monkey or any hardware players have something in common? Basic field names - ARTIST, ALBUM, TITLE are obvious but others may be tricky. Shall I use spaces between words, no spaces or underscores? (e.g. ALBUM ARTIST is preffered by foobar2000 and Winamp, ALBUMARTIST is pref. by Mp3tag, nevertheless some people use ALBUM_ARTIST. ENCODED BY, ARTIST SORT NAME are other examples). Is more proper YEAR or DATE? DISC or DISCNUMBER? In this regard I see a benefit of imperfect yet precise ID3v2 recommendations specifying which field shall contain which kind of information.
Q2: Is APEv2 designed to contain pictures??
The implementation of pictures in APEv2 tag is very poor. foobar2000 doesn't support it yet (Peter said cautiously it will be done at some point, in Winamp it's in TO-DO state as well (I haven't tried latest version, correct me if I'm wrong), only Mp3tag can save pictures in APE tag. I stumbled upon these statements in APE tag FAQ, probably by Frank Klemm himself:
(ii) What's the point in storing binary data in a tag? I don't think storing images in files is a good idea (and Klemm seems to agree that 'long' tags is not a good idea).
(x) I store images and other goodies in the tags. There's no reason to be afraid of 30kb of extra data with a modern computer...
  • images should never be added to an audio file.
  • if the data is important for the audio-visual representation, an additional container format should be used to store data and relations between the data. A well designed example is the MPEG-4 system stream. Tags should be tags and not the worst possible concept of a container format.
and quote from APE tag format description:
It is strongly recommended that the data size be stored in the tags. The size should normally be in the roughly one kilobyte, never more than 8 kilobytes.
From these statements it looks like images and binary data in general are not welcome in APE format and it isn't designed for it. ID3v2 is having direct support for images and it is supported by many software and hardware players. Is there any problem with pictures in APE tags?
Q3: Is APEv2 suitable to be embedded into MP3?
I'm not sure how's APE in MP3 technically achieved. Are APE tags in MP3 saved on the same level as ID3 tags, or do they use some wrapper or ID3 tag as container? I assume MP3 doesn't define ID3 as the only and proper tag scheme, but it probably has requirements on embedding non-audio (in this case metadata) frames. Does APE meet those requirements?
From the description of APE tag at wikiaudio.org:
The foobar2000 player can also tag MP3 files with APEv2 tags instead of ID3 tags, because they are considerably easier to write and more flexible.However, because ID3 was designed with the MP3 format in mind and APEv2 was not, there are some complications. For example, the string APETAGEX signals the start of an APEv2 tag, but the string TAG signals the start of an ID3v1 tag. If the TAG in APETAGEX ends up where an ID3v1 tag is expected, it may be read incorrectly. ID3 also has an “unsynchronization scheme” to ensure players do not try to play the tag data as audio; APEv2 has no such scheme, and APEv2 tags may result in errors or static at the end of files.
I use MP3val as a favourite tool to validate and repair all types of common errors in MP3 files. One of the most frequently reported error is "Garbage in the end of file". I checked test files tagged with few basic APE tags and they passed, however the statement above reveals that in rare cases APE tag will look like garbage in the end of file and will be ignored or removed by tools such as MP3val. Is it safe to use APE tags in MP3s? Any experience with misinterpreted APE tags or knowing current state of quote above are welcome.
The topic is as long as it can be. Thanks to those who were able to read it until here. In the times when I didn't know much about it, I was cutting MP3 off all tags and reimported them just to make sure that nothing else than ID3 frames I choose will not be there. Now I understand the benefits of APE tags, only the answers on the questions above aren't clear to me. Supposed answers: 1. No, 2. Yes, 3. Yes are in contradiction with excerpts I pasted.
Tigermess
post Dec 29 2011, 23:42
I've seen about 5 links from your post but not APE key!! Thanks! That's great for the start, from now I can be aware how close are my tags to the recommended tags - and then reasonably guess compatibility with software supporting APE in MP3. If we can define tags as we want, why we don't name them in Czech and Brazil Portuguese? smile.gif I suppose everyone wants to be at least basically compatible, and when I do that, I want to do that properly. Unfortunately there aren't keys for Album Artist or Encoder but at least I see some logic... spaces in label names are okay.
(side note to your previous Topic, Rodrigo: even APE doesn't expect multiple strings in Title, what a mess :-)))
Q2: ok binary flag is fine. Just don't understand the statements @ FAQ & format description. First I was thinking that it was about APEv1 and not v2 but then I found that it was from the time when v2 was out. Fear of long tags might be related to problems with streaming and lenght of gap between tracks. It can happen that APE is not designed for large/binary tags even if it allows them and ID3v2 handles them better. One of the formats may have lesser gaps between the tracks and less problems with streaming. Yet thanks for results of your test run.
Q3: ID3v1 is compatibility saviour. I play my music on parties, use it in car stereo, my mobile phone or MP3 player borrowed from my sister and I am planning to purchase multimedia centre to a living room.. probably none of these devices knows APE. I will need both APEv2 and ID3v1 to cooperate. First part of question was technical, I'm not educated in this matter, I was just curious if APE tags reside in MP3 "legally" and basically the same as ID3 (just different type of tags/metadata), or, because they were originally designed for APE files, are in MP3 by some kind of hack which perfectly works but uses grey points in specification, goes beyond recommended values etc. I am interested because of stability - e.g. may a player, which is very old and reads only ID3v1 tags but MP3 handling has properly implemented (no bugs), have problems with skipping APE tag, or can't it wrongly consider as a part of audio stream?
rodrigomartinho
post Dec 30 2011, 06:32
QUOTE (Tigermess @ Dec 29 2011, 20:42) *
I already have my way of naming tags, but if we go further in this and want to make a new one, that maybe can serve for others, I'm in. At present I don't use spaces, but underlines in my custom tags (album_artist, date_of_reference, recording_info and VBR_mode).
What do you mean? It is working for me in foobar. As far as I am concerned, every frame may have multiple values. It only doesn't support multiple keys, so multiple values must be in the same key, separated by a special character I don't remeber now (maybe NULL).
Those files I mentioned, with about 20% of binary data (433 KB of cover arts) are playing gapless in foobar.
I may go with you in this and start saving id3v1 too. Since id3v1 should be in start and apev2 in end of file, shouldn't be a problem. Tests needed though.
About what Florian said, this was long time ago. It doesn't seem to me we should rely on that. It's been already 4 years now that he implemented binary data on ape.
This post has been edited by rodrigomartinho: Dec 30 2011, 06:40
- Tigermess   APEv2 tags in MP3   Dec 29 2011, 19:30
- - rodrigomartinho   Hi again Tigermess. As I stated in the other topic...   Dec 29 2011, 20:26
- - Tigermess   I've seen about 5 links from your post but not...   Dec 29 2011, 23:42
|- - rodrigomartinho   QUOTE (Tigermess @ Dec 29 2011, 20:42) I...   Dec 30 2011, 06:32
- - Tigermess   I've found something to Q2. Florian, Mp3tag de...   Dec 30 2011, 00:50
|- - Gumboot   QUOTE (Tigermess @ Dec 29 2011, 23:50) 1....   Dec 30 2011, 14:05
|- - Tigermess   Gumboot, thanks. I liked your argument about 11 an...   Jan 4 2012, 00:25
|- - rodrigomartinho   QUOTE (Tigermess @ Jan 3 2012, 21:25) I b...   Jan 4 2012, 01:31
- - benski   I'd be happy to finish the implementation of a...   Dec 30 2011, 02:49
|- - rodrigomartinho   QUOTE (benski @ Dec 29 2011, 23:49) I...   Dec 30 2011, 06:39
- - Tigermess   QUOTE (benski @ Dec 30 2011, 02:49) I...   Dec 30 2011, 13:09
|- - rodrigomartinho   QUOTE (Tigermess @ Dec 30 2011, 10:09) QU...   Dec 30 2011, 15:03
|- - rodrigomartinho   QUOTE (rodrigomartinho @ Dec 30 2011, 12...   Dec 30 2011, 17:27
|- - rodrigomartinho   QUOTE (rodrigomartinho @ Dec 30 2011, 14...   Jan 2 2012, 13:43
- - db1989   I am fairly sure that APEv2 and ID3v2 are mutually...   Dec 30 2011, 17:32
|- - rodrigomartinho   QUOTE (db1989 @ Dec 30 2011, 14:32) I am ...   Dec 30 2011, 22:18
- - db1989   I didn’t say that they can’t be added; I said that...   Jan 1 2012, 23:10
|- - rodrigomartinho   QUOTE (db1989 @ Jan 1 2012, 20:10) I didn...   Jan 2 2012, 13:35
- - benski   Winamp assumes that an APEv2 tag might come betwee...   Jan 3 2012, 01:54
- - Tigermess   I speak a little bit portuguese, no need to transl...   Jan 4 2012, 02:34
|- - rodrigomartinho   QUOTE (Tigermess @ Jan 3 2012, 23:34) I s...   Jan 4 2012, 02:40
- - Tigermess   Today I noticed that Soulsearchingsun updated Foob...   Feb 13 2012, 10:49
|- - rodrigomartinho   As far as I have tested it, the mapping in mp3tag ...   Feb 25 2012, 16:13
|- - rodrigomartinho   QUOTE (Tigermess @ Feb 13 2012, 07:49) To...   Mar 5 2012, 02:07
- - Tigermess   How did it go? I got stuck in the beginning, I cou...   Apr 8 2012, 14:00
- - Tigermess   Here's the updated version of table. https://...   Apr 14 2012, 18:57
RSS Lo-Fi Version Time is now: 4th September 2015 - 14:07
