Something that's been bugging me about FLAC...
TempestGarden
post Dec 25 2011, 21:24
So, I have been using FLAC for many, many years now and I have ripped countless CDs and encoded them to FLAC for archive purposes as well as general listening. In all these years, something has been bothering me that I don't understand about this codec and I have decided to post here and see if I can get an answer to this nagging question. Not sure why I waited this long to bring this up, but anyways, here goes...
As you all know, FLAC has various "compression" settings which you can select when encoding the file (which never made sense to me since this is supposed to be a lossless codec). Now I understand that these "compression" levels have been likened to how WinZip compresses a file. I sorta get the analogy but there is something else here that still doesn't make sense to me. To illustrate my question/point better, I did a little experiment and listed my results below. I ripped the same exact song at 4 different "compression" levels and the resulting bitrate that I got for each rip is listed as well.
(Uncompressed) - 1412 kbps
Level 0 - 986 kbps
Level 5 (default) - 933 kbps
Level 8 - 931 kbps
So, based on these results, here is what is bothering me. Between the uncompressed setting and the level 8 setting, there is a loss of almost 500 kbps of data. In my mind, that is quite a substantial amount. I totally understand that whatever setting you chose will ultimately affect the end result bitrate of the file. I get that. What makes no sense to me at all though, is how a file (at level 8 setting) can lose almost 500 kbps of data and still be considered "lossless".
How is that possible? What is in those ~500 kbps worth of data that is getting shaved off? I just don't understand how you can be losing this much data and still have the resulting file be considered lossless. Maybe it's too technical of an answer for me to understand but I figured if anyone would be able to answer this for me, the folks on the forum here would.
So, yeah... this has been nagging at me for awhile. Any help to make me understand this better would be greatly appreciated.
This post has been edited by TempestGarden: Dec 25 2011, 21:25
halb27
post Dec 26 2011, 11:34
A simple model for lossless audio compression:
Instead of describing each wave sample as a 16 bit integer as is done with wav files, it can be describred as the difference to the previous wave sample. As the difference is a small value usually it can usually be described with far less than 16 bit. All it takes is an efficient and flexible coding scheme for encoding the difference values.
Real life lossless codecs like FLAC are more sophisticated taking in account more than 1 of the previous samples and the correlelation between left and riigh channel as was said before.
This post has been edited by halb27: Dec 26 2011, 11:43
- TempestGarden   Something that's been bugging me about FLAC...   Dec 25 2011, 21:24
- - saratoga   QUOTE (TempestGarden @ Dec 25 2011, 15:24...   Dec 25 2011, 21:28
- - benski   From a layman's point of view, most of the ini...   Dec 25 2011, 21:30
- - db1989   It’s called lossless compression for a reaso...   Dec 25 2011, 21:31
|- - TempestGarden   Maybe because I didn't fully understand how it...   Dec 25 2011, 22:44
|- - saratoga   QUOTE (TempestGarden @ Dec 25 2011, 16:44...   Dec 25 2011, 23:08
|- - db1989   QUOTE (TempestGarden @ Dec 25 2011, 21:44...   Dec 26 2011, 01:07
|- - mjb2006   I think what the OP needs is just to understand th...   Dec 26 2011, 04:49
- - psycho   TempestGarden, imagine this scenario. You have a ...   Dec 25 2011, 23:20
|- - TempestGarden   Yes, this does help and is a great example! I ...   Dec 25 2011, 23:27
|- - Roseval   The compression ratio is a source of misunderstand...   Dec 25 2011, 23:41
|- - Speckmade   QUOTE (psycho @ Dec 25 2011, 23:20) I lov...   Dec 26 2011, 06:04
|- - saratoga   That is a simple form of entropy coding, which is ...   Dec 26 2011, 07:34
|- - Speckmade   QUOTE (saratoga @ Dec 26 2011, 07:34) QUO...   Dec 26 2011, 21:09
|- - TBeck   I have to agree. I don't know of any lossless...   Dec 27 2011, 00:15
|- - Speckmade   QUOTE (TBeck @ Dec 27 2011, 00:15) no app...   Dec 27 2011, 03:50
- - Grinderman   QUOTE (TempestGarden @ Dec 25 2011, 21:24...   Dec 25 2011, 23:49
|- - TempestGarden   ^ Another great, easy to understand example. Thank...   Dec 26 2011, 00:26
- - slks   To paraphrase what's already been said - The ...   Dec 26 2011, 10:54
- - halb27   A simple model for lossless audio compression: Ins...   Dec 26 2011, 11:34
- - Ron Jones   QUOTE (Grinderman @ Dec 25 2011, 15:49) T...   Dec 26 2011, 19:03
RSS Lo-Fi Version Time is now: 29th January 2015 - 15:41
