New ASIO driver: issues, bug/problem reports, etc., 2012-01-02: version 2.1
Nordfinn
post Dec 18 2011, 17:19
Old driver worked perfectly for me. This one is not working. I have updated components before with no problems, and can't see that I am doing anything wrong, but, get this message:
Unrecoverable playback error: Could not start the worker process - The system cannot find the file specified.
The driver is in the components folder with the rest of the drivers, however.
I read your disclaimer about ASIO, but this mode is important to me. I switch back and forth a lot between internet radio stations, some at 48,000 some at 44.1. If I use my card's (Asus Xonar Essence) interface, I have to switch back and forth manually. (And definitely sounds better, despite your disclaimer.)
The old driver has apparently disappeared from my system with the update. Can I get it, please?
Thanks much,
N.
Mr.Grey
post Dec 18 2011, 20:56
I mean foo_out_asio folder
- Nordfinn   New ASIO driver: issues, bug/problem reports, etc.   Dec 18 2011, 17:19
- - kode54   Hi. If you looked at the contents of the archive p...   Dec 18 2011, 17:27
- - Nordfinn   Thanks very much. I removed and then reinstalled ...   Dec 18 2011, 18:01
|- - shakey_snake   QUOTE (Nordfinn @ Dec 18 2011, 12:01) Str...   Dec 18 2011, 18:14
- - Peter   Version 2.0.2 is up on the site, among other thing...   Dec 18 2011, 18:38
- - Nordfinn   New error messages: Unrecoverable playback error: ...   Dec 18 2011, 18:54
- - Peter   Well, that's progress. Please try the test ver...   Dec 18 2011, 19:39
|- - Nordfinn   QUOTE (Peter @ Dec 18 2011, 13:39) Well, ...   Dec 18 2011, 21:01
|- - Nordfinn   QUOTE (Nordfinn @ Dec 18 2011, 15:01) QUO...   Dec 18 2011, 21:20
- - mikk   Hi, with new 2.x asio plugins, my kx asio device i...   Dec 18 2011, 20:20
|- - Mr.Grey   QUOTE (mikk @ Dec 18 2011, 21:20) Hi, wit...   Dec 18 2011, 20:26
||- - Peter   QUOTE (Mr.Grey @ Dec 18 2011, 20:26) ASIO...   Dec 18 2011, 20:46
|||- - mikk   QUOTE (Peter @ Dec 18 2011, 20:46) QUOTE ...   Dec 18 2011, 20:57
||- - mikk   QUOTE (Mr.Grey @ Dec 18 2011, 20:26) QUOT...   Dec 18 2011, 20:55
|- - kode54   QUOTE (mikk @ Dec 18 2011, 11:20) With 2....   Dec 18 2011, 20:30
- - Mr.Grey   I mean foo_out_asio folder   Dec 18 2011, 20:56
|- - mikk   QUOTE (Mr.Grey @ Dec 18 2011, 20:56) I me...   Dec 18 2011, 21:02
|- - Mr.Grey   QUOTE (mikk @ Dec 18 2011, 22:02) QUOTE (...   Dec 18 2011, 21:08
- - Case   mikk, can you try deleting ASIOhost64.exe from the...   Dec 18 2011, 21:01
|- - mikk   QUOTE (Case @ Dec 18 2011, 21:01) mikk, c...   Dec 18 2011, 21:06
- - Case   Sticking to old version is not a solution. The new...   Dec 18 2011, 21:50
- - Case   Version 2.0.3 was just uploaded. It fixes issues i...   Dec 18 2011, 22:10
|- - mikk   QUOTE (Case @ Dec 18 2011, 22:10) Version...   Dec 19 2011, 10:24
- - kraut   I have tried twice to install new version. I use m...   Dec 18 2011, 22:26
|- - keijo   QUOTE (kraut @ Dec 18 2011, 23:26) I have...   Dec 19 2011, 02:12
|- - Peter   QUOTE (keijo @ Dec 19 2011, 02:12) ASIO o...   Dec 19 2011, 08:41
- - Nordfinn   Problems with 2.0.3: Almost working, but some stre...   Dec 19 2011, 02:01
|- - Peter   QUOTE (Nordfinn @ Dec 19 2011, 02:01) Pro...   Dec 19 2011, 10:54
|- - Nordfinn   QUOTE (Peter @ Dec 19 2011, 04:54) QUOTE ...   Dec 19 2011, 12:50
||- - Nordfinn   QUOTE (Peter @ Dec 19 2011, 04:54) Would ...   Dec 19 2011, 14:24
|- - Nordfinn   QUOTE (Peter @ Dec 19 2011, 04:54) QUOTE ...   Dec 19 2011, 18:48
- - A_Man_Eating_Duck   @keijo Have you upgraded to the very latest drive...   Dec 19 2011, 02:28
- - kraut   I just went to preferences, components page, and s...   Dec 19 2011, 09:21
- - Seeking_Lossless   I'm using Lexicon Lambda with Foobar version 1...   Dec 19 2011, 11:00
- - a3aan   The new asio driver (up to 2.0.3) sometimes causes...   Dec 19 2011, 13:54
- - Case   If you have a loopback cable to connect the speake...   Dec 19 2011, 17:25
- - db1989   http://www.hydrogenaudio.org/forums/index.php?show...   Dec 19 2011, 19:05
|- - Nordfinn   QUOTE (db1989 @ Dec 19 2011, 13:05) http:...   Dec 19 2011, 19:32
- - Peter   New update attached - may or may not help. There h...   Dec 19 2011, 21:43
|- - Nordfinn   This is working for me. Problem solved: everythin...   Dec 19 2011, 22:05
- - Peter   Version 2.0.4 released. For anyone else writing A...   Dec 20 2011, 09:19
- - helohe   with the old plugin, I used to get a BSOD when pla...   Dec 20 2011, 14:46
- - Peter   I'm having trouble understanding why Xonar is ...   Dec 20 2011, 14:58
|- - Seeking_Lossless   QUOTE (Peter @ Dec 20 2011, 21:58) I...   Dec 21 2011, 10:56
- - Nordfinn   Helohe--Just to say that I have exactly the same c...   Dec 20 2011, 15:10
- - Kurtegikov   Hello, I have a question about ASIO behavior: I un...   Dec 20 2011, 16:12
- - helohe   I only had the problem with asio. I'm using wi...   Dec 20 2011, 16:13
- - Peter   Xonar DirectSound was buggy too until I came up wi...   Dec 21 2011, 11:47
- - Seeking_Lossless   Is that true? Even with DirectSound? I think peopl...   Dec 21 2011, 12:48
- - MaceDD   Ola, I'm the new guy. The New Plugin is work...   Dec 22 2011, 17:50
- - NEMO7538   Version 2.0.4 does not work here (Win XP Pro SP3 3...   Dec 22 2011, 20:42
|- - MaceDD   QUOTE (NEMO7538 @ Dec 22 2011, 20:42) Ver...   Dec 23 2011, 03:59
||- - Kohlrabi   QUOTE (MaceDD @ Dec 23 2011, 03:59) Try t...   Dec 23 2011, 08:34
|- - Peter   QUOTE (NEMO7538 @ Dec 22 2011, 20:42) Ver...   Dec 23 2011, 14:06
- - Oery   v2.0.4 work fine, on my both system: 1. X-FI Xtrem...   Dec 23 2011, 09:23
- - Jackal29a   Installed 2.0.4 on my 2 PCs (both Foobar 1.1.10 ru...   Dec 23 2011, 21:15
- - exa065   I am unable to debug an ASIO driver in VisualStudi...   Jan 10 2012, 13:23
- - Gainless   Just wanted to mention that I get several timeouts...   Jan 13 2012, 09:57
- - Dexter_prog   I think the delay is gone for me, but it is still ...   Jan 13 2012, 20:45
|- - Dexter_prog   QUOTE (Dexter_prog @ Jan 13 2012, 16:45) ...   Feb 4 2012, 18:24
- - Dandruff   Cool, ASIO support version 2.1 doesn't even ne...   Jan 16 2012, 12:28
|- - exa065   QUOTE (Dandruff @ Jan 16 2012, 07:28) Coo...   Jan 16 2012, 18:33
- - Dexter_prog   Well, still skippy at >90% of cpu usage.   Feb 4 2012, 20:59
- - Dandruff   Not skippy here under high CPU load (RME HDSP 9632...   Feb 7 2012, 09:41
- - takoyaki   I have audiophilleo1 which can bit-perfect test. ...   Mar 24 2012, 14:31
- - Sandrine   What was your DSP chain? Replaygain on or off?   Mar 24 2012, 14:40
|- - takoyaki   QUOTE (Sandrine @ Mar 24 2012, 22:40) Wha...   Mar 24 2012, 16:41
- - ekzotic   in win8 i should have set win7 compatibility on as...   Aug 18 2012, 11:15
Closed TopicStart new topic
RSS Lo-Fi Version Time is now: 27th April 2015 - 10:41
