Multichannel Channel Order
xslig
post Dec 12 2011, 22:21
I've found that the option "--channel-order=" only works with raw PCM.
I had a 5 channel WAV (FL,FR,LFE,BL,BR) that I encoded. I then used "wvunpack -s foo.wv" and got back "channels: 5 (unassigned speakers)"
I wanted to have the channels assigned so
wavpack --channel-order=FL,FR,LFE,BL,BR foo.wav
and got back "this WAV file already has channel order information!"
I converted the WAV to raw PCM then
wavpack --channel-order=FL,FR,LFE,BL,BR foo.raw --raw-pcm=48000,24,5
which worked.
Is the option "--channel-order=" supposed to work like this?
I would think it's counter-intuitive that one couldn't change the channel order of a WAV file with the "--channel-order=" option.
Edit:
It was actually a WAVEX if that makes any difference.
This post has been edited by xslig: Dec 12 2011, 22:37
bryant
post Dec 13 2011, 21:43
WavPack Developer
Group: Developer (Donating)
I agree that having SoX unconditionally write a "best guess" for the dwChannelMask field is sub-optimal, and I suggested as much when I submitted the patch in this sox-devel mailing list thread.
But I still believe that this is better than writing zero because zero does not mean unknown as some are suggesting; zero means undefined and is just as definitive (and just as much a guess) as a non-zero value. This is why some programs (like Foobar2000) refuse to play files with a zero channel mask (at least it did at that time). I think that for the vast majority of users having a logical value in that field is better than zero, and the users who require zero there are probably more sophisticated and able to get around any issues generated.
Microsoft:
Having nChannels exceed the number of bits set in dwChannelMask can produce inconsistent results and should be avoided if possible.
Gumboot
post Dec 13 2011, 22:26
QUOTE (bryant @ Dec 13 2011, 20:43) *
How is this semantic distinction a step forward?
QUOTE (Microsoft)
Should nChannels exceed the number of bits set in dwChannelMask, then the remaining channels are not assigned to any particular speaker location. An audio device would render the remaining channel data to output ports not in use.
We have it there that a file with dwChannelMask=0 has no channels assigned to any particular speaker location. Not that those channels fall outside of the set of known channels. It is quite emphatically a lack of information.
The claim that "this WAV file already has channel order information" is baffling to me. After reconsidering I did wonder if --channel-order is an instruction for the output, rather than the input, and that when used it will find each channel by its name in the input and then put it in that order in the encoded file, but that would be a different error.
Microsoft:
I could only repeat my previous response to that quote.
bryant
post Dec 14 2011, 01:59
WavPack Developer
QUOTE (Gumboot @ Dec 13 2011, 14:26) *
It's only semantics, but I would disagree with this interpretation of the Microsoft docs. I think that a value of zero does specifically indicate that the channels fall outside the set of known channels. And the specs indicate that the known channels must appear in the prescribed order, so you can't use zero just to indicate "not in the MS order".
It is an instruction for interpreting the input when it is not unambiguously defined. If the order specified in the option is identical to the Microsoft order, then the option only determines the channel mask, but if the order specified is different then the channels will be reordered in the stream. This is actually kind of handy for reformatting files; you can pipe raw audio (or WAV without WAVEX) into wavpack with the --channel-order option and then pipe that into wvunpack to create a valid WAVEX file with the correct channel order and mask.
Gumboot
post Dec 16 2011, 23:06
QUOTE (bryant @ Dec 14 2011, 00:59) *
Where's that?
Where's that? I see:
QUOTE (Microsoft)
The channels that are specified in dwChannelMask should be present in the order shown in the preceding table, beginning at the top.
But, of course, that refers only to those channels that have been specified in dwChannelMask, and when that is zero obviously no channels have that constraint.
RSS Lo-Fi Version Time is now: 28th March 2015 - 23:12
