dBpower LAME 320 CBR - "fast" encode fewer artifacts - why?
superbu
post Nov 22 2011, 05:10
I'm not sure if this is in the proper forum, although I did do ABX listening tests, which I'll post below. But all the first one shows it that two different 320kb LAME encodes were ABX-able.
At any rate, I can't figure something out: While comparing 320kb LAME encodes of the popular killer sample "Show Me Your Spine," encoded using dBpoweramp, I found that the well-known "sandpaper scratching" artifact that is prominent in the first few seconds of the song was much more noticeable when I selected "Slow (High Quality)" than when I selected "Fast (Low Quality)." To my ears, the "Fast (Low Quality)" setting produced a result much closer to transparency (though definitely NOT transparent), while with the "Slow (High Quality)" setting the artifacts were VERY obvious.
I can't prove this other than to post the results of comparing those two compressed samples, where I scored 12/12 in differentiating them. There was a faint "cripsy" artifact at a particular point in the "slow" encode that was not present in the "fast" encode, and I'm also hearing that "scratching" sound more prominently in the Slow encode. Again, I scored 12/12:
foo_abx 1.3.4 report
foobar2000 v1.1.2
2011/11/21 00:56:55
File A: L:\Music Folder\1 MP3 Files for flash drive\Show_Me_Your_Spine__Sample (dB 320 quality fast).mp3
File B: L:\Music Folder\1 MP3 Files for flash drive\Show_Me_Your_Spine__Sample (dB 320 quality slow).mp3
00:56:55 : Test started.
00:59:27 : 01/01 50.0%
01:02:12 : 02/02 25.0%
01:04:19 : 03/03 12.5%
01:05:31 : 04/04 6.3%
01:07:33 : 05/05 3.1%
01:08:38 : 06/06 1.6%
01:09:28 : 07/07 0.8%
01:10:02 : 08/08 0.4%
01:10:46 : 09/09 0.2%
01:11:23 : 10/10 0.1%
01:12:09 : 11/11 0.0%
01:12:55 : 12/12 0.0%
01:12:59 : Test finished.
Total: 12/12 (0.0%)
Since I could also ABX the "fast" version 11/11 times with the original WAV, I didn't bother to ABX the "slow" encode with the WAV:
foobar2000 v1.1.2
2011/11/21 01:18:16
File A: C:\Users\superbu\Music\1 WAV Files For Itunes Import\Show_Me_Your_Spine__Sample (TRUE WAV).wav
File B: L:\Music Folder Backup\1 MP3 Files for flash drive\Show_Me_Your_Spine__Sample (db 320 quality fast).mp3
01:18:16 : Test started.
01:19:37 : 01/01 50.0%
01:20:24 : 02/02 25.0%
01:21:04 : 03/03 12.5%
01:21:36 : 04/04 6.3%
01:22:11 : 05/05 3.1%
01:23:00 : 06/06 1.6%
01:23:27 : 07/07 0.8%
01:24:33 : 08/08 0.4%
01:25:35 : 09/09 0.2%
01:26:04 : 10/10 0.1%
01:26:47 : 11/11 0.0%
01:26:52 : Test finished.
Total: 11/11 (0.0%)
Anyway, can someone explain to me how it's possible that the "fast (low quality)" encode could have less prominent artifacts than the "slow (high quality)" encode? I thought the slow encode was supposed to be of better quality.
This post has been edited by superbu: Nov 22 2011, 05:12
db1989
post Nov 25 2011, 08:53
To keep discussion in this thread, Iíll reply to your post from Uploads here:
QUOTE (superbu @ Nov 24 2011, 21:39) *
Apparently too late to edit the above post
Yes, editing is only available for an hour after posting, for various reasons. I amended your initial post just in case.
I meant to say that the Foobar "Show Me Your Spine" samples sounded WORSE than the dBpoweramp encodes. Not sure why that is -- both use LAME 3.98, but the Foobar encodes actually sounded worse than even the "Fast (High Quality)" setting on dBpoweramp.
Were exactly identical encoders and settings used in both foobar2000 and dBpowerAMP? Youíre right to be baffled if so! But again, I think more information will be needed before anyone can propose an explanation for either of the phenomena that youíve described. Perhaps another pair of samples, this time created by foobar2000 and dBpowerAMP respectively? Assuming, that is, that you verify the setup as noted above.
superbu
post Nov 27 2011, 09:57
QUOTE (db1989 @ Nov 25 2011, 08:53) *
Good point, db1989. Unless they are using the exact same version of LAME with the exact same settings, it's not fair to compare them. I really mentioned it only as an aside.
I'm mainly concerned with why the high quality setting on dBpoweramp's LAME at 320kb produces more artifacts in the "Show Me Your Spine" sample than than the low quality setting does, particularly since with dBpoweramp you must select a quality setting -- fast (low), normal (medium), or slow (high).
db1989
post Nov 27 2011, 14:08
QUOTE (superbu @ Nov 27 2011, 08:57) *
Itís a completely fair question, but again the existence of this phenomenon has been known for a while and discussed at various points. Unfortunately, though, I donít know of any specific threads/posts to point you to (besides that given by lvqcl, of course). Perhaps someone who has been paying more technical attention to LAMEómaybe even a developerócould weigh in.
Iím also interested to know whether or not this issue has propagated to version 3.99 (itís not something I could easily test myself at the moment).
RSS Lo-Fi Version Time is now: 30th August 2015 - 16:11
