> foobar2000 Development Forum Rules
This forum is for developer discussions only. If you have a problem / bug report / idea / feature request that isn't related to foobar2000 SDK, post it in an appropiate forum instead - tech support questions go to support forum, everything else goes to general forum.
All non-developer posts on this forum will be removed. Continued abuse of this forum will result in admin actions (warnings, account suspension).
fixed Playlist Viewer for DUI?
Zarty
post Nov 17 2011, 14:24
Is writing a simple fixed Playlist Viewer component for DUI a reasonable project? If so, are there any 'nearly the same' examples that could be the starting point?
The need is for a UI object that is very much the same as the core Playlist Viewer but has the additional option of being able to be set to always look the same/named playlist whether it is active/playing or not. So, for example, you could have a tabbed playlist in one pane and a Playlist view in a separate pane.
I have done development using Visual Studio before but never for Foobar2000 components. Before I consider having a go, I thought it would be wise to find out if this potential project was feasible or not? The idea would be to keep it as simple and clean as it's possible to be. Work the same as the existing Playlist Viewer but with just two additional options I think... View Active and View Named (with a dropdown field that lists the available playlists).
Zarty
ps. I'm assuming there isn't any liklihood of the existing Playlist Viewer being enhanced in this way? Hope I'm wrong.
RSS Lo-Fi Version Time is now: 27th May 2015 - 23:54
