FLAC x64 build, 64 bit build of flac.exe
viktor
post Nov 4 2011, 21:34
I saw a benchmark on Phoronix regarding FLAC performance:
So I became curious about it on Windows. The results? A bit disappointing, only about 3-5% increase in performance, probably because of the lack of _asm on x64. If the x86 build is compiled without using NASM, it gets about 10% slower. At least on my AMD Fusion A6-3500. Either way, here it is for your convenience!
Download:
  1. Microsoft Visual C++ 2010 SP1 Redistributable Package (x64)
  2. FLAC 1.2.1 x64
This post has been edited by viktor: Nov 4 2011, 22:22
viktor
post Nov 4 2011, 21:55
results for my reference, possibly more to come soon:
- MSVC x86: 68s
- MSVC x86 NASM: 60s
- MSVC x64: 57s
- MINGW x86: 70s
- MINGW x64: 57s
This post has been edited by viktor: Nov 4 2011, 22:44
forart.eu
post Dec 1 2011, 16:23
QUOTE (viktor @ Nov 4 2011, 21:55) *
- MSVC x86: 68s
- MSVC x64: 57s
- MINGW x86: 70s
- MINGW x64: 57s
Cool !
...and where's binaries ?
john33
post Dec 1 2011, 17:18
xcLame and OggDropXPd Developer
I also did some testing with an ICL 12.1 x64 compile and came to much the same conclusion. I can make it available if anyone is interested, but the gains aren't worth shouting about.
John
viktor
post Dec 1 2011, 18:13
QUOTE (forart.eu @ Dec 1 2011, 16:23) *
Cool !
"Download:" in first post.
exx
post Dec 19 2011, 00:24
Using a 2500k @ 4.2 ghz
Tested against the FLAC version bundled with db Poweramp. x64 is perhaps 1-2 seconds faster per album. Within margin of error, imo. Reading from a hard drive, writing to a RAM disk. FLACCL is still 4x faster with a GTX470.
forart.eu
post Dec 27 2011, 13:08
Dunno if this can help, but i recently had a talk with Eric Gur (Processor Client Application Engineer @ Intel Corp.) about MT libraries, here's his answer:
For threading I recommend using Intel's free TBB library. It's very fast, cross platform, simple to use and has an important feature - malloc replacement.
I used it in a previous project - 1M lines of code, multithreaded application on Linux x64. Just the malloc replament boosted performance by 3x without changing any code (1 line in the makefile).
Dunno if can help, but could be really interesting !
QUOTE ( @ Dec 19 2011, 00:24) *
OT: Same here, what about 4.2 oc settings ?
This post has been edited by db1989: Dec 27 2011, 14:43
Reason for edit: merging posts; please edit instead
lamedude
post Jan 2 2012, 08:00
Thanks for the tip. How to do it is at section 10.2 on page 63.
Can flac.exe show how long it takes or are you using another program to measure speed?
Isayama
post Feb 18 2012, 18:10
QUOTE (john33 @ Dec 1 2011, 17:18) *
I'd like to test your compile John, is it possible to make it available on RW (I found there your ICL 11.1 32 bit compile) or send it directly here? Is it optimized for any kind of processor instruction set (SSE2, SSE3...), or otherwise how can I get info on how to do it (I run an Intel Core 2 Duo)? I'll give a try at forart.eu and lamedude method (thanks for the link to the tutorial)
Same question than lamedude: is there any community preferred tool for measuring flac encoding/decoding speed, or we should just use CLI/foobar's log info?
Many thanks.
Reasons for edit: typos and grammar
This post has been edited by Isayama: Feb 18 2012, 18:13
lvqcl
post Feb 18 2012, 18:32
I use timer.exe from 7-Benchmark: http://sourceforge.net/projects/sevenmax/files/7-Benchmark/
Martel
post Feb 19 2012, 10:37
Malloc replacement in a multi-threaded application is only going to help in case all the threads are doing mallocs/frees repeatedly/in parallel (the normal heap is a serialization/choke point). I'm not sure why an encoder would need to do that when it could have most of the buffers "static" (malloc'd upon startup, freed upon exit).
It's great for server code with lots of messaging and modeled dynamic data types.
IE4 Rockbox Clip+ AAC@192; HD 668B/HD 518 Xonar DX FB2k FLAC;
GeorgeFP
post Feb 19 2012, 11:06
For a x64 multicore FLAC encoder, see here: http://www.hydrogenaudio.org/forums/index....showtopic=76193
kalen3285
post Feb 19 2012, 16:47
QUOTE (GeorgeFP @ Feb 19 2012, 05:06) *
Where can I download this? The links I saw on the first post are dead. Thanks.
Kittens give Morbo gas.
GeorgeFP
post Feb 19 2012, 17:49
The download link is http://www.thinkmeta.de/download/fpStream_1_0_0_23.7z
antman
post Mar 29 2012, 01:12
Post #15
QUOTE (john33 @ Dec 1 2011, 10:18) *
I'd like a copy. I don't see slight gains as being a reason not to use it.
denastig31
post Jan 12 2013, 04:05
Post #16
Hi, my question is not consirned with FLAC x64 build but i guess you guys might help me.
I have a flac source code v1.2.1
I am trying to build the libflac library static for C using VS2010
can i build the library without the the support of OGG and NASM?
what are the steps?
Thank you
-denver
john33
post Jan 12 2013, 16:33
Post #17
QUOTE (denastig31 @ Jan 12 2013, 03:05) *
what are the steps?
Thank you
-denver
From memory, remove 'FLAC__HAS_OGG' and change 'FLAC__HAS_NASM' to 'FLAC__NO_ASM'.
HTH
John
RSS Lo-Fi Version Time is now: 2nd September 2015 - 16:19
