16 Pages V  « < 11 12 13 14 15 > »
LAME 3.99 is out, 2012-02-28: version 3.99.5 has been released
apodtele
post Dec 15 2011, 17:59
Post #301
QUOTE (DoctorO @ Dec 15 2011, 10:39) *
yes the Winamp mp3 encoder settings dialog isn't great / needs to be updated to whatever the suggested guidelines are now, but it otherwise works.
DrO,
Take a look at http://wiki.hydrogenaudio.org/index.php?title=LAME for the guidelines
In comparison to Winamp mp3 plugin, the modern LAME recommendations
-- do not even mention -q
-- do not dwell on bitrates
-- instead settle on --vbr-new by making it default
-- instead explain a lot about -V for VBR that are not offered by Winamp
That is how much Winamp mp3 plugin is behind.
A.
lvqcl
post Dec 15 2011, 18:34
Post #302
QUOTE (apodtele @ Dec 15 2011, 20:59) *
Yes they are:
apodtele
post Dec 15 2011, 18:57
Post #303
That is -q rather than -V, it never changes from 2 with any --preset or quality setting,
This post has been edited by db1989: Dec 16 2011, 14:22
Reason for edit: removing pointless full quote of above post
lvqcl
post Dec 15 2011, 20:24
Post #304
-q is "Quality" when it is equal to Low / Normal / High / Very High. And then "VBR Q" is -V switch.
apodtele
post Dec 15 2011, 21:48
Post #305
QUOTE (lvqcl @ Dec 15 2011, 14:24) *
When I read this http://lame.cvs.sourceforge.net/viewvc/lame/lame/USAGE
I expect -q to be either numeric or Fast / Slow / ... as an algorithm speed rating
and -V is either numeric or High / Low / ... as in quality/kbps or whatever.
Do you see my confusion while lacking Winamp documentation?
The layout is also confusing because VBR Q appears to be the least important (bottom) setting.
What you said and what I see simply does not chime with the Lame documentation.
The only thing that rings the correct bells is "--preset fast standard" and this is what I use.
This post has been edited by apodtele: Dec 15 2011, 22:02
DoctorO
post Dec 16 2011, 00:30
Post #306
apodtele: the link you've directed at me doesn't seem to be the one i remember seeing some time back on what is meant to be done in a UI for controlling lame. which was http://lame.sourceforge.net/lame_ui_example.php and as i've not followed things closely, my comment was worded as such to cater for things having changed with those suggested guidelines (though looks like i remember it being).
either way, no one is disagreeing that Winamp's mp3 encoder config needs to be overhauled, but trying to base what is currently there against documentation which has most likely changed since the encoder's ui was created (which if i remember correctly goes back to the original Winamp dev team) is never going to match up. also without checking, i was under the impression that the encoder's defaults have changed over time time to better fit with more of the 'preferred' options even if it's still based on the -preset method.
then again if you don't like it, you don't have to use it and just use whatever actually fits with what you want to use / get the results you deem important smile.gif (plus i'm pretty sure the mp3 encoder is only available if you're a pro user...).
-daz
This post has been edited by DoctorO: Dec 16 2011, 00:32
krafty
post Dec 16 2011, 01:18
Post #307
Is it a good time to encode with 3.99 or should I stick with 3.98...
Audibly both doesn't matter, but in matter of bugs and the new -V0 lowpass extended, does it make any sense?
dxiv
post Dec 16 2011, 08:35
Post #308
QUOTE (lvqcl @ Dec 15 2011, 14:49) *
The INI-driven DLL wasn't invented just for Winamp users. Other rippers/encoders used to offer less than satisfactory control over LAME's options, older PlexTools for one.
john33
post Dec 16 2011, 10:33
Post #309
xcLame and OggDropXPd Developer
QUOTE (dxiv @ Dec 16 2011, 07:35) *
Actually, I did it originally for older versions of CDex, but any software that uses the old .dll can take advantage of it. wink.gif
John
SnakeSnoke
post Dec 18 2011, 13:25
Post #310
not sure where to post this. I just encoded a 32000Hz wav file with foobar and LAME 3.99.3 64bit (from rarewares) with the setting "-V 5". For the result mp3 file Foobar says: Codec Profile: MP3 VBR V3 (132kbps)
I didn't make any more tests.
Something is wrong here, I guess.
This post has been edited by SnakeSnoke: Dec 18 2011, 13:28
halb27
post Dec 18 2011, 14:11
Post #311
I ran upon this phenomenon while working on 3.99.3x.
-V level is remapped when using 32 kHz sampling frequency. It's a feature.
It would be better of cause if the user demanded -V level would be used to compute the quality item within the Lame tags which tools like foobar use for recalculating the -V level (the -V level isn't stored directly in the mp3 file).
If this is something that bothers you, you can use 3.99.3x where I fixed this. When using 3.99.3x with the usual -V n 3.99.3x works exactly like 3.99.3 does.
lvqcl
post Dec 18 2011, 14:28
Post #312
test32.wav is a 32kHz test file;
lame.exe -V 5 test32.wav => 118.6 kbps
lame.exe --resample 32 -V 5 test32.wav => 102.4 kbps
There is no difference between "-V 5" and "-V 5 --resample 44" for files with 44 kHz samplerate.
exx
post Dec 19 2011, 00:30
Post #313
Was using dbPowerAmp (which uses LAME) to convert some FLAC for my ipod and noticed it wasn't using my CPU to its full potential.
http://i.imgur.com/Kv9bR.png
Only goes up to ~15% per process (max would be 25%). Total encoding speed was around 120-130x, which is much slower than normal. I was doing the same thing yesterday and all 4 cores were maxed. I don't have anything running in the background. Could it be a HD speed issue? The input and output paths were on the same drive, but it's a WD Black so it's not terribly slow, and I didn't hear any drive noise.
Update: have since tried writing to a RAM disk as well as a different drive than the source; it goes a bit faster, but I still can't reliably max out each core. I feel as if there is wasted potential here. The CPU will often be maxed at the start of the batch, but drop off soon after.
Any ideas?
d_headshot
post Dec 21 2011, 04:15
Post #314
What's the deal with the lowpass filter? Is it on both v3.98 and 3.99? Has anyone viewed the frequency spectrum of two files at the same quality setting?
antman
post Jan 2 2012, 04:29
Post #315
My observations:
1. My library with 3.98 V0 clocked in at 35GB, with 3.99 V0 it's at 36.8GB.
2. Usually something NIN or metal is highest encoded song in my collection, with 3.99, it's Nirvana - From the Muddy Banks of the Wishkah - 08 - Sliver @ 307kbps (?!).
3. In Windows Explorer (WinXP) when I highlight over that song, and all 3.99 encodes for that matter, the bitrate comes up at 656kbps.
DARcode
post Jan 3 2012, 11:59
Post #316
Group: Members (Donating)
As mentioned a bitrate increase is to be expected, and I subscribe to shadowking's take on the matter here http://www.hydrogenaudio.org/forums/index....st&p=769219.
WavPack 4.75.0 -b384hx6cmv/qaac 2.49 -V 100
apodtele
post Jan 3 2012, 17:11
Post #317
QUOTE (DARcode @ Jan 3 2012, 05:59) *
I did not get this. If you equate VBR V3 from 2011 and CBR 256kbps from 2000, that's a big big progress. Just compare the file sizes and bitrates.
To V0 people: If you are so paranoid about the quality, stop complaining about the size.
This post has been edited by apodtele: Jan 3 2012, 17:12
greynol
post Jan 3 2012, 17:20
Post #318
QUOTE (d_headshot @ Dec 20 2011, 19:15) *
Are you suggesting that there is a difference that you can actually hear and it has gotten worse with the new version?
If not then I fail to see why this matters!
This post has been edited by greynol: Jan 3 2012, 17:21
d_headshot
post Jan 3 2012, 22:41
Post #319
QUOTE (greynol @ Jan 3 2012, 10:20) *
All versions of lame are transparent to me so I'm not concerned about any difference in sound. I'm just curious about it because I'm in engineering and people like me are interested in stuff like that lol.
This post has been edited by d_headshot: Jan 3 2012, 22:41
instaud
post Jan 8 2012, 14:11
Post #320
QUOTE (greynol @ Jan 3 2012, 18:20) *
As a reader who finds valuable information on this great board I have to say that the only posts distracting from the flow of information are your regular attempts to shove in reminders about TOS #8, even if it was not the typical "320kbps rulez" kind of post.
If you own thousands of CDs you try to inform yourself thoroughly before switching your encoder and reencode. Technical background information and details about the developer's motivation to change things in the code helps with that decision.
naturfreak
post Jan 25 2012, 22:40
Post #321
Update to Version 3.99.4 a few hours ago...
Changelog:
LAME 3.99.4 January 25 2012
* Robert Hegemann
o Fix for tracker item [ 3475581 ] lame crashes at .w64 input file
o Addressing things brought to attention by tracker item [ 3463197 ] 3.99.x problem WFED and PCST frames
+ WFED and PCST frames can now be added, to tag podcasts iTunes recognizes
+ USER frames are now supported
+ COMM frames can now have a description, when passed via --tv "COMM=description=full text"
+ possible divide-by-zero exception should be fixed
+ adding malformed user-defined-frames could result in abnormal program termination, fixed
This post has been edited by naturfreak: Jan 25 2012, 22:43
john33
post Jan 25 2012, 23:31
Post #322
I have all the new compiles ready to go, but I am currently unable to access Rarewares FTP to update the site!! I have emailed Roberto to find out what's up and am awaiting a response.
Temporarily, they can be downloaded from here:
EDIT: Link removed - see below. smile.gif
but please don't pass the link around otherwise my ISP will hit on me for too much traffic!! wink.gif
I'll get them up on Rarewares as soon as I'm able.
This post has been edited by db1989: Jan 28 2012, 11:43
Reason for edit: Please stop unnecessarily full-quoting.
John
john33
post Jan 27 2012, 13:58
Post #323
All compiles now available on Rarewares so the above link is removed. smile.gif
John
bbrabant
post Jan 28 2012, 10:53
Post #324
QUOTE (john33 @ Jan 27 2012, 15:58) *
Thanks for the new Lame compiles but on my windows xp pc (32bit) I am unable to run these compiles. I had no problem running the previous compiles of Lame.
Do I need to install additional libraries ?
Greetz,
Ben
john33
post Jan 28 2012, 10:59
Post #325
I don't believe there are any dependencies. These (32 bit compiles) were tested on Win 2000 Pro and worked fine. The compiler is unchanged. What error message do you get, if any?
I won't be able to reply further until Monday as I'm away now until then.
This post has been edited by db1989: Jan 28 2012, 11:44
Reason for edit: See post #323.
John
RSS Lo-Fi Version Time is now: 29th May 2015 - 16:31
