16 Pages V  « < 10 11 12 13 14 > »
LAME 3.99 is out, 2012-02-28: version 3.99.5 has been released
robert
post Dec 4 2011, 10:28
Post #276
LAME developer
@Jebus
Albert Faber originally wrote the code for the DLL for his CDex project.
For new programs, do use the libmp3lame.dll instead.
Do you want to replace RG by r128 ?
Jebus
post Dec 5 2011, 18:41
Post #277
ah, I didn't realize - thought it was the preferred public API. I'm using my own native C# RG implementation; I may also implement r128 at a later date.
Could someone add libmp3lame.dll be to the Rarewares Lame bundles? I need both 32-bit and 64-bit versions, and don't have access to ICL. It would be muchly appreciated!
This post has been edited by db1989: Dec 5 2011, 20:13
Reason for edit: removing unnecessary full quote
john33
post Dec 5 2011, 19:00
Post #278
xcLame and OggDropXPd Developer
Will do, over the next 24 hours. wink.gif I'll add them separately.
Reason for edit: "
John
JJZolx
post Dec 5 2011, 20:55
Post #279
So, what's the verdict? Is 3.99.3 going to be it for a while? There have been a slew of releases in very short order. Could we see a 3.99.4 soon to fix more bugs? I'm hesitant to encode anything with 3.99.3 after the missteps with 3.99 and 3.99.1 and 3.99.2.
halb27
post Dec 5 2011, 21:15
Post #280
You don't have to re-encode when a new subversion comes out. As far as I can see the new subversion were only a.bout special tagging issues.
This post has been edited by halb27: Dec 5 2011, 21:19
zipr
post Dec 6 2011, 04:25
Post #281
Robert and Mr. Odd:
I'm using mp3gain v1.25
When I did run "check integrity," it told me that there were minor problems and that there were multiple id3v2 tags encountered.
So I checked my EAC settings. I had LAME set up to tag the file:
-V2 --add-id3v2 --pad-id3v2 --ta "%artist%" --tl "%albumtitle%" --tt "%title%" --tn "%tracknr%" --tg "%genre%" --ty "%year%" %source% %dest%
And also on the EAC compression tab I had 'Add ID3 tag' checked as well. So I think that there were actually two sets of tags being written. If I unchecked the box and tested, I was still getting id3v2 tags, but no errors in foobar or in mp3gain.
So I think the problem is solved for me. I'm still curious as to why this caused problems in 3.99 but not in 3.98?
apodtele
post Dec 6 2011, 15:35
Post #282
QUOTE (zipr @ Dec 5 2011, 22:25) *
... as was suggested in post #266.
Nonetheless, LAME should have replaced the old tag instead of piling on. It is a bug in LAME.
john33
post Dec 6 2011, 15:43
Post #283
QUOTE (Jebus @ Dec 5 2011, 17:41) *
Compiles of the dll with exports and libs (ICL 12.1), x86 and x64, now at Rarewares on the lame-libs page. smile.gif
John
robert
post Dec 6 2011, 16:05
Post #284
LAME developer
QUOTE (apodtele @ Dec 6 2011, 15:35) *
LAME creates the file, there is nothing to replace. Sorry, no bug in LAME.
Jebus
post Dec 6 2011, 16:19
Post #285
QUOTE (john33 @ Dec 6 2011, 07:43) *
Thanks so much - you rule!
This post has been edited by Jebus: Dec 6 2011, 16:19
bilbo
post Dec 7 2011, 19:53
Post #286
QUOTE (apodtele @ Dec 6 2011, 22:26) *
The program must protect itself from idiots. Or, security holes would be user errors too. It is an EAC bug, because it should check
if the file contains the tag already before writing its own.
First of all, the program is listed as a beta version.
Second, you have a choice of beginner mode or advanced mode. Beginner is default. Do you think it needs a stupid mode?
Glass half full!
zipr
post Dec 8 2011, 04:38
Post #287
Whether or not it was idiotic of me to leave the 'write id3 tag' box checked, I still am curious as to why it's only an issue using 3.99, and something I've never encountered with all of the other versions of LAME I've used (back to 3.96.1)...
Regardless, it's no longer an issue for me, and I learned a bit more about EAC in the process.
bilbo
post Dec 8 2011, 22:45
Post #288
QUOTE (zipr @ Dec 7 2011, 22:38) *
Not meant for you!
Glass half full!
greynol
post Dec 8 2011, 23:31
Post #289
QUOTE (bilbo @ Dec 8 2011, 13:45) *
Not meant for you!
I split away the useless off-topic argument but wanted to keep zipr's post since it relates back to differences between the current version of Lame and previous versions. Your post was kept in order to preserve some context and it links back to the binned side-discussion. Sorry for any confusion.
My eyes are equipped with false negative prevention.
dxiv
post Dec 13 2011, 06:03
Post #290
QUOTE (john33 @ Dec 6 2011, 14:43) *
If that's not too much trouble, could you please add a modified lame_enc.dll to use .ini settings as well? Thanks.
This post has been edited by dxiv: Dec 13 2011, 06:04
robert
post Dec 13 2011, 10:08
Post #291
LAME developer
QUOTE (zipr @ Dec 8 2011, 04:38) *
As of v3.99, LAME writes unicode tags by default (and when compiled with unicode support). The byte order marker (BOM) look like sync bits. Seeing your location, you eventually can live with Latin-1 text encoding, add --id3v2-latin1 in front of the other tagging options to avoid unicode tags.
john33
post Dec 13 2011, 11:00
Post #292
QUOTE (dxiv @ Dec 13 2011, 05:03) *
Yes, sorry, I meant to look at these variations but they slipped my mind! wink.gif I'll try to get them done in the next day, or so.
John
john33
post Dec 14 2011, 17:10
Post #293
John
apodtele
post Dec 14 2011, 21:14
Post #294
QUOTE (john33 @ Dec 14 2011, 11:10) *
Would ini file settings have a precedence over other settings?
I do not like Winamps mp3 encoder set up that is very outdated.
Can I use this to overwrite Winamp plugin?
db1989
post Dec 14 2011, 22:19
Post #295
Yes, that is basically the entire purpose of that particular DLL.
Edit: Well, sort of tongue.gif
This dll uses an '.ini' file to set up the encoder. This is designed for use with applications that use the dll but do not provide full preset support.
This post has been edited by db1989: Dec 14 2011, 22:23
dxiv
post Dec 14 2011, 23:17
Post #296
QUOTE (john33 @ Dec 14 2011, 16:10) *
(lamedll_mod3.99.3) Available at Rarewares now in the same place as before. smile.gif
Thanks again, much obliged.
apodtele
post Dec 15 2011, 00:29
Post #297
QUOTE (db1989 @ Dec 14 2011, 16:19) *
QUOTE ( [url="http://www.rarewares.org/mp3-lame-libraries.php")
http://www.rarewares.org/mp3-lame-libraries.php[/url] ]This dll uses an '.ini' file to set up the encoder. This is designed for use with applications that use the dll but do not provide full preset support.
This implies that the ini file has lower precedence, but this is not clear or explicit.
john33
post Dec 15 2011, 10:57
Post #298
QUOTE (apodtele @ Dec 14 2011, 23:29) *
The code for the dll has been modified so that it ignores all parameters from the 'host' application that are specified in the .ini file.
John
lvqcl
post Dec 15 2011, 15:49
Post #299
DoctorO
post Dec 15 2011, 16:39
Post #300
likewise.
yes the Winamp mp3 encoder settings dialog isn't great / needs to be updated to whatever the suggested guidelines are now, but it otherwise works.
-daz
RSS Lo-Fi Version Time is now: 5th May 2015 - 20:33
