LAME 3.99 is out, 2012-02-28: version 3.99.5 has been released
lvqcl
post Oct 15 2011, 18:07
October 15 2011: 3.99 beta 1 becomes 3.99
Download: http://www.rarewares.org/mp3-lame-bundle.php
Changelog: http://lame.cvs.sourceforge.net/viewvc/lam...ml/history.html
This post has been edited by greynol: Nov 9 2011, 21:10
Alex B
post Nov 3 2011, 00:38
For comparison here is LAME 3.97. I have no idea about the compiler, but probably my archived encoder is from the past Rarewares "main bundle".
LAME 3.97
C:\Soft\LAME\397>lame -V2 --vbr-new --noreplaygain "S:\Test\Testfile.wav" "F:\Te
st\HA\399speed\lame397.mp3
LAME 3.97 32bits (http://www.mp3dev.org/)
CPU features: MMX (ASM used), 3DNow! (ASM used), SSE (ASM used), SSE2
Using polyphase lowpass filter, transition band: 18671 Hz - 19205 Hz
Encoding S:\Test\Testfile.wav to F:\Test\HA\399speed\lame397.mp3
Encoding as 44.1 kHz VBR(q=2) j-stereo MPEG-1 Layer III (ca. 7.3x) qval=3
    Frame          |  CPU time/estim | REAL time/estim | play/CPU |    ETA
210463/210463(100%)|    3:55/    3:55|    3:56/    3:56|   23.339x|    0:00
32 [   972] %
40 [    54] %
48 [    41] %
56 [    31] %
64 [    21] %
80 [   103] %
96 [   493] %
112 [  3200] %**
128 [  9556] %********
160 [ 54917] %%%%%%%********************************************
192 [ 71955] %%%%%%%%%%%%%%%%%%%%**********************************************
224 [ 40066] %%%%%%%%%%%%*************************
256 [ 21026] %%%%%%%*************
320 [  8028] %%%%****
   kbps        LR    MS  %     long switch short %
  195.8       24.8  75.2        91.5   4.8   3.8
Writing LAME Tag...done
The tendency seems to be to use more LR frames in each new version.
Regarding my speed results from running a single lame instance in a cmd window, perhaps you should ignore them. I ran a few additional tests and the results really vary too much from one run to another. When foobar2000 runs four simultaneous encoder instances, the results seem to be quite reproducible.
This post has been edited by Alex B: Nov 3 2011, 01:10
- lvqcl   LAME 3.99 is out   Oct 15 2011, 18:07
- - IgorC   Congratulations to developers of LAME with their n...   Oct 16 2011, 08:36
- - halb27   Thanks a lot for the new version. Tuning on VBR s...   Oct 16 2011, 13:34
- - ShotCaller   So is the best plan to wait for a few more .1 revi...   Oct 16 2011, 18:49
- - halb27   For learning about 3.99's average bitrate for ...   Oct 16 2011, 18:54
- - lvqcl   My test set: CODE 3.98.4 3.99 -V6: 126 ...   Oct 16 2011, 19:35
- - lameboy   A big Thank You to the LAME devs for the important...   Oct 16 2011, 20:48
- - halb27   I did a short listening test comparing 3.99 agains...   Oct 16 2011, 21:52
|- - IgorC   Interesting report. QUOTE (halb27 @ Oct 16 2...   Oct 16 2011, 22:46
|- - /mnt   QUOTE (halb27 @ Oct 16 2011, 21:52) As a ...   Oct 30 2011, 23:41
|- - halb27   QUOTE (/mnt @ Oct 31 2011, 00:41) I have ...   Oct 31 2011, 20:04
- - halb27   Sorry for having said "There must have gone s...   Oct 16 2011, 23:39
- - IgorC   It's ok , halb27. My sarcasm sometimes drives...   Oct 17 2011, 00:10
- - Wombat   I didnīt really test anything because i donīt use ...   Oct 17 2011, 03:58
- - halb27   I just retested trumpet, and this morning it was n...   Oct 17 2011, 08:07
- - TuNk77   I don't know if this is the right place to ask...   Oct 17 2011, 18:23
|- - john33   Quite simply, it's the fact that one is genera...   Oct 17 2011, 19:10
|- - TuNk77   Thank you for replying john33 and thanks for clari...   Oct 17 2011, 19:21
- - inrobert   Hello. I have a problem with new version. After up...   Oct 17 2011, 23:06
- - robert   Confirmed, fixed sources are available from SF.net...   Oct 18 2011, 01:06
|- - john33   QUOTE (robert @ Oct 18 2011, 01:06) Confi...   Oct 18 2011, 10:40
|- - temp1   QUOTE (john33 @ Oct 18 2011, 03:40) QUOTE...   Oct 18 2011, 11:36
|- - no404error   QUOTE (john33 @ Oct 18 2011, 12:40) QUOTE...   Oct 18 2011, 12:41
|- - inrobert   QUOTE (john33 @ Oct 18 2011, 11:40) QUOTE...   Oct 18 2011, 19:28
- - ShotCaller   What is everyone's thoughts on -V 0 now using ...   Oct 18 2011, 04:09
|- - Northpack   QUOTE (ShotCaller @ Oct 18 2011, 03:09) W...   Oct 18 2011, 10:59
- - halb27   Thanks for the info. I don't like having no or...   Oct 18 2011, 06:29
|- - markanini   QUOTE (halb27 @ Oct 18 2011, 07:29) Thank...   Oct 18 2011, 14:14
|- - halb27   QUOTE (markanini @ Oct 18 2011, 14:14) QU...   Oct 18 2011, 17:00
- - robert   Tuning CBR/ABR is something I have planned to do i...   Oct 18 2011, 11:19
- - robert   That's actually not a bug for the x64 compile,...   Oct 18 2011, 13:20
|- - no404error   QUOTE (robert @ Oct 18 2011, 15:20) That...   Oct 18 2011, 15:22
- - Agent69   QUOTE (john33 @ Oct 15 2011, 13:15) QUOTE...   Oct 18 2011, 20:01
- - punkrockdude   John33: do you know why the x64 version does not w...   Oct 18 2011, 21:22
|- - john33   QUOTE (punkrockdude @ Oct 18 2011, 21:22)...   Oct 18 2011, 21:30
- - Steve Forte Rio   Question for the LAME developer: may I ask you, wh...   Oct 18 2011, 21:41
|- - kwanbis   QUOTE (Steve Forte Rio @ Oct 18 2011, 20...   Oct 22 2011, 01:31
|- - IgorC   ++ My guess is that it's something to do with ...   Oct 22 2011, 09:00
- - lvqcl   Apparently Reaper is a program that uses lame_enc....   Oct 18 2011, 21:52
|- - punkrockdude   lvqcl, thank you very much for the detailed repons...   Oct 18 2011, 22:23
- - ShotCaller   QUOTE (Steve Forte Rio @ Oct 18 2011, 22...   Oct 19 2011, 16:59
- - lameboy   For Mac-users there's a plugin available for X...   Oct 20 2011, 15:19
- - krafty   I too noticed that there is no lowpass using -V0. ...   Oct 23 2011, 20:56
- - Gregory S. Chudov   I'm using lame_enc.dll in CUETools, and have s...   Oct 24 2011, 20:53
- - lvqcl   Why do you want to use lame_enc.dll, but not libmp...   Oct 24 2011, 21:07
- - Gregory S. Chudov   That would be the alternative, yes. But it still w...   Oct 24 2011, 21:13
|- - [JAZ]   QUOTE (Gregory S. Chudov @ Oct 24 2011, 22...   Oct 25 2011, 19:01
- - Frankie   3.99 works fine but on my machine (Intel Dual Core...   Oct 25 2011, 21:43
- - Destroid   I was about to post LAME 3.99 b1.2 test I ran comp...   Oct 26 2011, 11:28
- - Alex B   QUOTE (Alex B @ Oct 3 2011, 20:49) A quad...   Oct 26 2011, 13:19
- - lvqcl   Results of "lame -S -V2 --noreplaygain test.w...   Oct 26 2011, 16:56
|- - Alex B   QUOTE (lvqcl @ Oct 26 2011, 18:56) Result...   Oct 26 2011, 22:08
|- - robert   QUOTE (Alex B @ Oct 26 2011, 23:08) Your ...   Oct 26 2011, 22:53
- - psycho   My results (samples taken from http://ff123.net/sa...   Oct 26 2011, 18:40
- - psycho   I forgot to mention: OS: WinXP SP3 32-bit Can...   Oct 26 2011, 19:54
|- - Alex B   QUOTE (psycho @ Oct 26 2011, 21:54) Rarew...   Oct 26 2011, 20:51
- - robert   QUOTE (psycho @ Oct 26 2011, 20:54) Quest...   Oct 26 2011, 21:21
- - psycho   Alex B, I used the "VC6/Intel Compiler 9.1...   Oct 26 2011, 21:28
|- - Alex B   QUOTE (psycho @ Oct 26 2011, 23:28) Alex ...   Oct 26 2011, 21:54
- - psycho   john33, I managed to compile lame.exe with VC6, ho...   Oct 26 2011, 22:10
- - krafty   No one is going to explain the lowpass thing? Rob...   Oct 29 2011, 18:11
- - ShotCaller   Considering -V 0 now uses no lowpass filter, would...   Oct 30 2011, 18:32
- - chichazor   ŋThere is a regression in sound quality with -V2? ...   Oct 31 2011, 01:25
- - DARcode   Is there a reson why the old "main" 2010...   Oct 31 2011, 12:41
|- - john33   QUOTE (DARcode @ Oct 31 2011, 12:41) Is t...   Oct 31 2011, 12:49
- - DARcode   Thank you John, I was actually looking the the LAM...   Oct 31 2011, 13:15
- - john33   http://homepage.ntlworld.com/jfe1205/LAME/lame3.98...   Oct 31 2011, 13:20
- - john33   New compiles at Rarewares reflecting id3 tagging c...   Nov 1 2011, 19:37
- - GeSomeone   Thanks John, this seems to be 3.99.1 beta (or even...   Nov 1 2011, 21:16
|- - john33   QUOTE (GeSomeone @ Nov 1 2011, 21:16) Tha...   Nov 1 2011, 23:23
|- - GeSomeone   QUOTE (john33 @ Nov 2 2011, 00:23) QUOTE ...   Nov 2 2011, 13:23
|- - john33   Ah, OK, I thought it was perhaps something I had g...   Nov 2 2011, 13:55
- - sld   Has anybody tried to compile with the Open64 compi...   Nov 2 2011, 02:53
|- - lvqcl   QUOTE (sld @ Nov 2 2011, 05:53) Has anybo...   Nov 2 2011, 16:55
- - john33   So as to be sure that my compiles work on both Int...   Nov 2 2011, 15:13
|- - no404error   QUOTE (john33 @ Nov 2 2011, 17:13) So as ...   Nov 2 2011, 17:53
|- - robert   QUOTE (john33 @ Nov 2 2011, 15:13) So as ...   Nov 3 2011, 01:27
- - Alex B   Using the same test setup as before, LAME 3.99 32...   Nov 2 2011, 19:07
- - viktor   john, any chance for a 64 bit lamedropxpd build?   Nov 2 2011, 19:24
|- - john33   QUOTE (viktor @ Nov 2 2011, 19:24) john, ...   Nov 2 2011, 23:32
|- - viktor   QUOTE (john33 @ Nov 2 2011, 23:32) QUOTE ...   Nov 4 2011, 17:17
|- - john33   QUOTE (viktor @ Nov 4 2011, 17:17) QUOTE ...   Nov 4 2011, 17:56
|- - viktor   QUOTE (john33 @ Nov 4 2011, 17:56) Don...   Nov 4 2011, 17:57
|- - john33   QUOTE (viktor @ Nov 4 2011, 17:57) QUOTE ...   Nov 6 2011, 12:53
|- - viktor   QUOTE (john33 @ Nov 6 2011, 12:53) OK, th...   Nov 6 2011, 13:23
|- - john33   QUOTE (viktor @ Nov 6 2011, 13:23) QUOTE ...   Nov 6 2011, 15:58
|- - Broadway   QUOTE (john33 @ Nov 6 2011, 12:53) OK, th...   Nov 6 2011, 19:20
|- - john33   QUOTE (Broadway @ Nov 6 2011, 19:20) QUOT...   Nov 6 2011, 19:28
- - robert   @Alex Just trying to figure out, what is so specia...   Nov 2 2011, 20:11
|- - Alex B   QUOTE (robert @ Nov 2 2011, 22:11) @Alex ...   Nov 2 2011, 22:52
|- - robert   QUOTE (Alex B @ Nov 2 2011, 23:52) A bit ...   Nov 2 2011, 23:41
- - Alex B   For comparison here is LAME 3.97. I have no idea a...   Nov 3 2011, 00:38
- - Fishman0919   I did a quick test of VC 11 w/nasm 2.10rc8 and Min...   Nov 4 2011, 03:56
- - krafty   Still not a word on the lowpass case for -V0 ???   Nov 5 2011, 21:42
- - ZinCh   LAME 3.99.1 released lame-3.99.1.tar.gz QUOTE Fi...   Nov 5 2011, 22:51
- - lvqcl   BTW, 3.99.1 was released.   Nov 6 2011, 12:57
|- - john33   QUOTE (lvqcl @ Nov 6 2011, 12:57) BTW, 3....   Nov 6 2011, 15:57
- - john33   Having just checked, it appears to fine here. Anyo...   Nov 6 2011, 19:40
- - robert   Hm, yes. Dumpzusammenfassung -------------------...   Nov 6 2011, 22:32
4 Pages V   1 2 3 > »
RSS Lo-Fi Version Time is now: 31st August 2015 - 12:05
