LAME 3.99 is out, 2012-02-28: version 3.99.5 has been released
lvqcl
post Oct 15 2011, 18:07
October 15 2011: 3.99 beta 1 becomes 3.99
Download: http://www.rarewares.org/mp3-lame-bundle.php
Changelog: http://lame.cvs.sourceforge.net/viewvc/lam...ml/history.html
This post has been edited by greynol: Nov 9 2011, 21:10
lvqcl
post Oct 18 2011, 21:52
Apparently Reaper is a program that uses lame_enc.dll
The code from BladeMP3EncDLL:
typedef    unsigned long    HBE_STREAM;
typedef    HBE_STREAM    *PHBE_STREAM;
PHBE_STREAM phbeStream;
lame_global_flags* gfp = NULL;
// Init the global flags structure
gfp = lame_init();
*phbeStream = (HBE_STREAM)gfp;
lame_global_flags* gfp = (lame_global_flags*)hbeStream;
This code works only when sizeof (unsigned long) == sizeof(pointer).
(Or when the upper half of a pointer is 0. Maybe setting largeaddressaware=0 to Reaper executable should help)
QUOTE (punkrockdude @ Mar 8 2010, 02:20) *
This is in the change log of Reaper 3.35:
x64: now requires libmp3lame.dll or lame_enc64.dll (old x64 lame_enc.dll was broken)
IMHO 64-bit libmp3lame.dll is better than lame_encXX.
This post has been edited by lvqcl: Oct 18 2011, 22:09
punkrockdude
post Oct 18 2011, 22:23
lvqcl, thank you very much for the detailed reponse. DO you know where I can find the other dll using latest 3.99. I have only found lame_enc64.dll. Regards.
- lvqcl   LAME 3.99 is out   Oct 15 2011, 18:07
- - IgorC   Congratulations to developers of LAME with their n...   Oct 16 2011, 08:36
- - halb27   Thanks a lot for the new version. Tuning on VBR s...   Oct 16 2011, 13:34
- - ShotCaller   So is the best plan to wait for a few more .1 revi...   Oct 16 2011, 18:49
- - halb27   For learning about 3.99's average bitrate for ...   Oct 16 2011, 18:54
- - lvqcl   My test set: CODE 3.98.4 3.99 -V6: 126 ...   Oct 16 2011, 19:35
- - lameboy   A big Thank You to the LAME devs for the important...   Oct 16 2011, 20:48
- - halb27   I did a short listening test comparing 3.99 agains...   Oct 16 2011, 21:52
|- - IgorC   Interesting report. QUOTE (halb27 @ Oct 16 2...   Oct 16 2011, 22:46
|- - /mnt   QUOTE (halb27 @ Oct 16 2011, 21:52) As a ...   Oct 30 2011, 23:41
|- - halb27   QUOTE (/mnt @ Oct 31 2011, 00:41) I have ...   Oct 31 2011, 20:04
- - halb27   Sorry for having said "There must have gone s...   Oct 16 2011, 23:39
- - IgorC   It's ok , halb27. My sarcasm sometimes drives...   Oct 17 2011, 00:10
- - Wombat   I didnīt really test anything because i donīt use ...   Oct 17 2011, 03:58
- - halb27   I just retested trumpet, and this morning it was n...   Oct 17 2011, 08:07
- - TuNk77   I don't know if this is the right place to ask...   Oct 17 2011, 18:23
|- - john33   Quite simply, it's the fact that one is genera...   Oct 17 2011, 19:10
|- - TuNk77   Thank you for replying john33 and thanks for clari...   Oct 17 2011, 19:21
- - inrobert   Hello. I have a problem with new version. After up...   Oct 17 2011, 23:06
- - robert   Confirmed, fixed sources are available from SF.net...   Oct 18 2011, 01:06
|- - john33   QUOTE (robert @ Oct 18 2011, 01:06) Confi...   Oct 18 2011, 10:40
|- - temp1   QUOTE (john33 @ Oct 18 2011, 03:40) QUOTE...   Oct 18 2011, 11:36
|- - no404error   QUOTE (john33 @ Oct 18 2011, 12:40) QUOTE...   Oct 18 2011, 12:41
|- - inrobert   QUOTE (john33 @ Oct 18 2011, 11:40) QUOTE...   Oct 18 2011, 19:28
- - ShotCaller   What is everyone's thoughts on -V 0 now using ...   Oct 18 2011, 04:09
|- - Northpack   QUOTE (ShotCaller @ Oct 18 2011, 03:09) W...   Oct 18 2011, 10:59
- - halb27   Thanks for the info. I don't like having no or...   Oct 18 2011, 06:29
|- - markanini   QUOTE (halb27 @ Oct 18 2011, 07:29) Thank...   Oct 18 2011, 14:14
|- - halb27   QUOTE (markanini @ Oct 18 2011, 14:14) QU...   Oct 18 2011, 17:00
- - robert   Tuning CBR/ABR is something I have planned to do i...   Oct 18 2011, 11:19
- - robert   That's actually not a bug for the x64 compile,...   Oct 18 2011, 13:20
|- - no404error   QUOTE (robert @ Oct 18 2011, 15:20) That...   Oct 18 2011, 15:22
- - Agent69   QUOTE (john33 @ Oct 15 2011, 13:15) QUOTE...   Oct 18 2011, 20:01
- - punkrockdude   John33: do you know why the x64 version does not w...   Oct 18 2011, 21:22
|- - john33   QUOTE (punkrockdude @ Oct 18 2011, 21:22)...   Oct 18 2011, 21:30
- - Steve Forte Rio   Question for the LAME developer: may I ask you, wh...   Oct 18 2011, 21:41
|- - kwanbis   QUOTE (Steve Forte Rio @ Oct 18 2011, 20...   Oct 22 2011, 01:31
|- - IgorC   ++ My guess is that it's something to do with ...   Oct 22 2011, 09:00
- - lvqcl   Apparently Reaper is a program that uses lame_enc....   Oct 18 2011, 21:52
|- - punkrockdude   lvqcl, thank you very much for the detailed repons...   Oct 18 2011, 22:23
- - ShotCaller   QUOTE (Steve Forte Rio @ Oct 18 2011, 22...   Oct 19 2011, 16:59
- - lameboy   For Mac-users there's a plugin available for X...   Oct 20 2011, 15:19
- - krafty   I too noticed that there is no lowpass using -V0. ...   Oct 23 2011, 20:56
- - Gregory S. Chudov   I'm using lame_enc.dll in CUETools, and have s...   Oct 24 2011, 20:53
- - lvqcl   Why do you want to use lame_enc.dll, but not libmp...   Oct 24 2011, 21:07
- - Gregory S. Chudov   That would be the alternative, yes. But it still w...   Oct 24 2011, 21:13
|- - [JAZ]   QUOTE (Gregory S. Chudov @ Oct 24 2011, 22...   Oct 25 2011, 19:01
- - Frankie   3.99 works fine but on my machine (Intel Dual Core...   Oct 25 2011, 21:43
- - Destroid   I was about to post LAME 3.99 b1.2 test I ran comp...   Oct 26 2011, 11:28
- - Alex B   QUOTE (Alex B @ Oct 3 2011, 20:49) A quad...   Oct 26 2011, 13:19
- - lvqcl   Results of "lame -S -V2 --noreplaygain test.w...   Oct 26 2011, 16:56
|- - Alex B   QUOTE (lvqcl @ Oct 26 2011, 18:56) Result...   Oct 26 2011, 22:08
|- - robert   QUOTE (Alex B @ Oct 26 2011, 23:08) Your ...   Oct 26 2011, 22:53
- - psycho   My results (samples taken from http://ff123.net/sa...   Oct 26 2011, 18:40
- - psycho   I forgot to mention: OS: WinXP SP3 32-bit Can...   Oct 26 2011, 19:54
|- - Alex B   QUOTE (psycho @ Oct 26 2011, 21:54) Rarew...   Oct 26 2011, 20:51
- - robert   QUOTE (psycho @ Oct 26 2011, 20:54) Quest...   Oct 26 2011, 21:21
- - psycho   Alex B, I used the "VC6/Intel Compiler 9.1...   Oct 26 2011, 21:28
|- - Alex B   QUOTE (psycho @ Oct 26 2011, 23:28) Alex ...   Oct 26 2011, 21:54
- - psycho   john33, I managed to compile lame.exe with VC6, ho...   Oct 26 2011, 22:10
- - krafty   No one is going to explain the lowpass thing? Rob...   Oct 29 2011, 18:11
- - ShotCaller   Considering -V 0 now uses no lowpass filter, would...   Oct 30 2011, 18:32
- - chichazor   ŋThere is a regression in sound quality with -V2? ...   Oct 31 2011, 01:25
- - DARcode   Is there a reson why the old "main" 2010...   Oct 31 2011, 12:41
|- - john33   QUOTE (DARcode @ Oct 31 2011, 12:41) Is t...   Oct 31 2011, 12:49
- - DARcode   Thank you John, I was actually looking the the LAM...   Oct 31 2011, 13:15
- - john33   http://homepage.ntlworld.com/jfe1205/LAME/lame3.98...   Oct 31 2011, 13:20
- - john33   New compiles at Rarewares reflecting id3 tagging c...   Nov 1 2011, 19:37
- - GeSomeone   Thanks John, this seems to be 3.99.1 beta (or even...   Nov 1 2011, 21:16
|- - john33   QUOTE (GeSomeone @ Nov 1 2011, 21:16) Tha...   Nov 1 2011, 23:23
|- - GeSomeone   QUOTE (john33 @ Nov 2 2011, 00:23) QUOTE ...   Nov 2 2011, 13:23
|- - john33   Ah, OK, I thought it was perhaps something I had g...   Nov 2 2011, 13:55
- - sld   Has anybody tried to compile with the Open64 compi...   Nov 2 2011, 02:53
|- - lvqcl   QUOTE (sld @ Nov 2 2011, 05:53) Has anybo...   Nov 2 2011, 16:55
- - john33   So as to be sure that my compiles work on both Int...   Nov 2 2011, 15:13
|- - no404error   QUOTE (john33 @ Nov 2 2011, 17:13) So as ...   Nov 2 2011, 17:53
|- - robert   QUOTE (john33 @ Nov 2 2011, 15:13) So as ...   Nov 3 2011, 01:27
- - Alex B   Using the same test setup as before, LAME 3.99 32...   Nov 2 2011, 19:07
- - viktor   john, any chance for a 64 bit lamedropxpd build?   Nov 2 2011, 19:24
|- - john33   QUOTE (viktor @ Nov 2 2011, 19:24) john, ...   Nov 2 2011, 23:32
|- - viktor   QUOTE (john33 @ Nov 2 2011, 23:32) QUOTE ...   Nov 4 2011, 17:17
|- - john33   QUOTE (viktor @ Nov 4 2011, 17:17) QUOTE ...   Nov 4 2011, 17:56
|- - viktor   QUOTE (john33 @ Nov 4 2011, 17:56) Don...   Nov 4 2011, 17:57
|- - john33   QUOTE (viktor @ Nov 4 2011, 17:57) QUOTE ...   Nov 6 2011, 12:53
|- - viktor   QUOTE (john33 @ Nov 6 2011, 12:53) OK, th...   Nov 6 2011, 13:23
|- - john33   QUOTE (viktor @ Nov 6 2011, 13:23) QUOTE ...   Nov 6 2011, 15:58
|- - Broadway   QUOTE (john33 @ Nov 6 2011, 12:53) OK, th...   Nov 6 2011, 19:20
|- - john33   QUOTE (Broadway @ Nov 6 2011, 19:20) QUOT...   Nov 6 2011, 19:28
- - robert   @Alex Just trying to figure out, what is so specia...   Nov 2 2011, 20:11
|- - Alex B   QUOTE (robert @ Nov 2 2011, 22:11) @Alex ...   Nov 2 2011, 22:52
|- - robert   QUOTE (Alex B @ Nov 2 2011, 23:52) A bit ...   Nov 2 2011, 23:41
- - Alex B   For comparison here is LAME 3.97. I have no idea a...   Nov 3 2011, 00:38
- - Fishman0919   I did a quick test of VC 11 w/nasm 2.10rc8 and Min...   Nov 4 2011, 03:56
- - krafty   Still not a word on the lowpass case for -V0 ???   Nov 5 2011, 21:42
- - ZinCh   LAME 3.99.1 released lame-3.99.1.tar.gz QUOTE Fi...   Nov 5 2011, 22:51
- - lvqcl   BTW, 3.99.1 was released.   Nov 6 2011, 12:57
|- - john33   QUOTE (lvqcl @ Nov 6 2011, 12:57) BTW, 3....   Nov 6 2011, 15:57
- - john33   Having just checked, it appears to fine here. Anyo...   Nov 6 2011, 19:40
- - robert   Hm, yes. Dumpzusammenfassung -------------------...   Nov 6 2011, 22:32
4 Pages V   1 2 3 > »
RSS Lo-Fi Version Time is now: 3rd August 2015 - 05:10
