What's the point of higher sampling rates in audio?, Such as 96 and 192kHz.
stranhoROX
post Oct 16 2011, 18:03
Could someone explain to me why there are some recordings with sample rates as high as 192kHz? If most of us hear up to 20kHz, wouldn't 44.1kHz or even 48kHz be enough? Or is there other practical aspects besides boosting maximum frequency in higher sampling rates I am not aware of?
[JAZ]
post Oct 18 2011, 22:09
And are you 100% sure that the plugin is samplerate aware???
I've been part of this past year fixing most of the plugins of my program* so that they don't perform differently at different sample rates. There's no plausible reason why a compressor would act that much different at different sampling rates. The slope should increase accordingly.
(Of course, by the nature of a compressor, a higher samplerate allows to control better the envelope, but we're talking about a couple of samples better, not something that could clearly be heard).
* http://sourceforge.net/projects/psycle . I'm doing the last tests and adjustments for a new official release. (Should have already released it this weekend).
Arnold B. Kruege...
post Nov 1 2011, 21:44
QUOTE ([JAZ] @ Oct 18 2011, 17:09) *
If nonlinear processing is done in the digital domain, certain high harmonics can reflect back down into the audible range. Any signal that is generated in the digital domain above the Nyquist frequency aliases around the Nyquist frequency. For example, an 8 KHz tone in a 44.1 KHz sampled sytem is distorted by a fourth order digitally-implemented nonlinearity and would be expected to produce a fourth harmonic at 32 KHz. Since 32 KHz is 10 Khz higher than the 44.1 KHz Nyquist frequency of 22 KHz, the 4th harmonic is aliased down to 12 KHz where it is far more audible than it would be in a digital system with a much higher sample rate or an analog system. In a 96 KHz system, the same nonlinearity would produce a foruth harmonic at 32 KHz where it would not be audible.
Aliasing can also impact certain dynamic range compression or expansion algorithms that are based on nonlinarities implemented in the digital domain.
Most kinds of processing that are used in music synthesis and mixing are linear, so aliasing is not a common problem.
This post has been edited by Arnold B. Krueger: Nov 1 2011, 21:58
2Bdecided
post Nov 2 2011, 12:32
ReplayGain developer
QUOTE (Arnold B. Krueger @ Nov 1 2011, 21:44) *
A simple non-linear transfer function (i.e. literally mapping sample values to new sample values using a look-up table which, if plotted input vs output on a graph, would show a curve) - that can produce harmonics above the noise into the MHz range. You don't prevent audible aliasing just be using a "slightly" higher sample rate.
It helps a bit, but "just" 96kHz isn't really a solution.
benski
post Nov 2 2011, 15:40
Winamp Developer
QUOTE (2Bdecided @ Nov 2 2011, 07:32) *
This isn't completely true, David. If you have an arbitrary non-linear function, yes you will have sky-high THD generation. However, if you have a function with a known polynomial order (such as a Taylor series approximation of a transcendental function), then you will also have a predictable limit on the number of harmonics produced. This is because because a polynomial function is the equivalent of amplitude modulation - x^2 is the signal x modulating the amplitude of signal x - and AM has predictable sidebands (M-N and M+N, in the x^2 case, that would be 0 and 2x)
- stranhoROX   What's the point of higher sampling rates in audio?   Oct 16 2011, 18:03
- - C.R.Helmrich   Good question! My answer: People record with 9...   Oct 16 2011, 18:18
|- - punkrockdude   QUOTE (C.R.Helmrich @ Oct 16 2011, 19:18)...   Oct 18 2011, 21:13
- - Brand   Yeah, this has been discussed a lot on HA. But in...   Oct 16 2011, 18:29
|- - saratoga   QUOTE (Brand @ Oct 16 2011, 13:29) Howeve...   Oct 16 2011, 21:32
- - benski   There are some advantages to recording, mixing and...   Oct 16 2011, 20:38
- - Canar   Trivial case where higher-sampling rates can becom...   Oct 16 2011, 21:50
|- - Notat   +1 to saratoga Canar's scenario is applicable...   Oct 16 2011, 22:48
|- - krabapple   QUOTE (Notat @ Oct 16 2011, 17:48) There ...   Oct 17 2011, 03:57
- - Juha   Still there are plenty of audiointerfaces which wo...   Oct 17 2011, 04:14
- - 2Bdecided   @benski, ...but if you're simply relying on t...   Oct 17 2011, 10:07
|- - benski   QUOTE (2Bdecided @ Oct 17 2011, 05:07) @b...   Oct 17 2011, 11:47
|- - Northpack   QUOTE (benski @ Oct 17 2011, 10:47) And i...   Oct 17 2011, 16:34
||- - 2Bdecided   QUOTE (Northpack @ Oct 17 2011, 16:34) QU...   Oct 18 2011, 11:26
||- - Dirk95100   QUOTE (2Bdecided @ Oct 18 2011, 12:26) An...   Oct 18 2011, 12:33
|||- - 2Bdecided   QUOTE (Dirk95100 @ Oct 18 2011, 12:33) QU...   Oct 18 2011, 14:46
|||- - Dirk95100   QUOTE (2Bdecided @ Oct 18 2011, 15:46) QU...   Oct 19 2011, 05:35
||||- - saratoga   QUOTE (Dirk95100 @ Oct 19 2011, 00:35) ht...   Oct 19 2011, 05:51
|||||- - Dirk95100   QUOTE (saratoga @ Oct 19 2011, 06:51) QUO...   Oct 19 2011, 08:42
|||||- - SebastianG   QUOTE (Dirk95100 @ Oct 19 2011, 09:42) An...   Oct 19 2011, 09:38
||||- - 2Bdecided   QUOTE (Dirk95100 @ Oct 19 2011, 05:35) ht...   Oct 19 2011, 11:01
||||- - Dirk95100   QUOTE (2Bdecided @ Oct 19 2011, 12:01) QU...   Oct 19 2011, 12:50
||||- - SebastianG   QUOTE (Dirk95100 @ Oct 19 2011, 13:50) Wh...   Oct 19 2011, 13:52
||||- - pdq   QUOTE (Dirk95100 @ Oct 19 2011, 07:50) Wh...   Oct 19 2011, 14:00
|||- - Woodinville   QUOTE (2Bdecided @ Oct 18 2011, 06:46) 1)...   Oct 19 2011, 07:45
||- - krabapple   QUOTE (2Bdecided @ Oct 18 2011, 06:26) Th...   Oct 18 2011, 23:10
||- - 2Bdecided   QUOTE (krabapple @ Oct 18 2011, 23:10) QU...   Oct 19 2011, 10:50
|- - dhromed   QUOTE (benski @ Oct 17 2011, 12:47) And i...   Oct 17 2011, 17:05
|- - knutinh   QUOTE (benski @ Oct 17 2011, 12:47) I...   Oct 17 2011, 18:34
|- - Dirk95100   QUOTE (knutinh @ Oct 17 2011, 19:34) QUOT...   Oct 18 2011, 05:06
- - Wombat   QUOTE (dhromed @ Oct 17 2011, 18:05) QUOT...   Oct 17 2011, 18:45
- - HTS   Do microphones have to be good enough to take adva...   Oct 18 2011, 03:45
|- - saratoga   QUOTE (HTS @ Oct 17 2011, 22:45) Otherwis...   Oct 18 2011, 03:47
- - FreaqyFrequency   There are, in fact, at least two omni capsules out...   Oct 18 2011, 04:12
- - hellokeith   Seems like a worthwhile experiment would be to run...   Oct 18 2011, 07:14
- - unekdoud   QUOTE (stranhoROX @ Oct 17 2011, 01:03) C...   Oct 18 2011, 08:01
- - Cavaille   Guys, you all disappoint me. The point of higher s...   Oct 18 2011, 13:34
|- - 2Bdecided   QUOTE (Cavaille @ Oct 18 2011, 13:34) Guy...   Oct 18 2011, 14:55
|- - saratoga   QUOTE (Cavaille @ Oct 18 2011, 08:34) Guy...   Oct 18 2011, 17:41
|- - C.R.Helmrich   QUOTE (Cavaille @ Oct 18 2011, 14:34) It ...   Oct 18 2011, 22:42
||- - hellokeith   QUOTE (C.R.Helmrich @ Oct 18 2011, 16:42)...   Oct 19 2011, 05:30
||- - C.R.Helmrich   QUOTE (hellokeith @ Oct 19 2011, 06:30) Q...   Oct 19 2011, 15:50
|- - krabapple   QUOTE (Cavaille @ Oct 18 2011, 08:34) Guy...   Oct 18 2011, 23:26
|- - Slipstreem   QUOTE (Cavaille @ Oct 18 2011, 12:34) Thi...   Nov 8 2011, 02:01
- - Wombat   I love the steps forward high resolution movies co...   Oct 18 2011, 19:48
- - [JAZ]   And are you 100% sure that the plugin is samplerat...   Oct 18 2011, 22:09
|- - punkrockdude   QUOTE ([JAZ] @ Oct 18 2011, 23:09...   Nov 1 2011, 16:55
|- - Arnold B. Krueger   QUOTE ([JAZ] @ Oct 18 2011, 17:09...   Nov 1 2011, 21:44
|- - 2Bdecided   QUOTE (Arnold B. Krueger @ Nov 1 2011, 21...   Nov 2 2011, 12:32
||- - benski   QUOTE (2Bdecided @ Nov 2 2011, 07:32) A s...   Nov 2 2011, 15:40
|- - HTS   QUOTE (Arnold B. Krueger @ Nov 1 2011, 15...   Mar 20 2012, 03:35
|- - Woodinville   QUOTE (HTS @ Mar 19 2012, 19:35) Aren...   Apr 7 2012, 05:41
|- - knutinh   QUOTE (Woodinville @ Apr 7 2012, 06:41) H...   Apr 9 2012, 12:20
- - Juha   I bet most of these 16/44.1 fanatics rips/ripped t...   Oct 19 2011, 04:33
|- - krabapple   QUOTE (Juha @ Oct 18 2011, 23:33) I bet m...   Nov 15 2011, 17:29
|- - mjb2006   QUOTE (krabapple @ Nov 15 2011, 10:29) [2...   Nov 15 2011, 22:12
|- - krabapple   QUOTE (mjb2006 @ Nov 15 2011, 17:12) QUOT...   Nov 15 2011, 22:45
- - greynol   It has little to do with editing. People record a...   Oct 19 2011, 16:34
|- - Arnold B. Krueger   QUOTE (greynol @ Oct 19 2011, 11:34) It h...   Nov 1 2011, 15:08
- - greynol   That's great, Arny, though I don't know th...   Nov 1 2011, 16:48
|- - Arnold B. Krueger   QUOTE (greynol @ Nov 1 2011, 11:48) That...   Nov 1 2011, 21:27
|- - greynol   QUOTE (Arnold B. Krueger @ Nov 1 2011, 13...   Nov 1 2011, 22:16
- - 2Bdecided   Yes, I agree. Sorry, that's what I was implyin...   Nov 2 2011, 16:18
- - astroidmist   I don't know if this has been posted or addres...   Nov 7 2011, 07:00
- - Roseval   Nyquist in reverse One should sample at the doubl...   Nov 8 2011, 00:01
- - Wombat   QUOTE (Roseval @ Nov 8 2011, 01:01) One s...   Nov 8 2011, 02:14
- - pappaapa   Question: Shouldn't the rest of the worlds ac...   Nov 8 2011, 15:38
|- - 2Bdecided   QUOTE (pappaapa @ Nov 8 2011, 15:38) To m...   Nov 8 2011, 18:00
||- - pappaapa   QUOTE (2Bdecided @ Nov 8 2011, 18:00) Any...   Nov 9 2011, 00:10
||- - Soap   QUOTE (pappaapa @ Nov 8 2011, 19:10) But ...   Nov 9 2011, 00:48
||- - 2Bdecided   QUOTE (pappaapa @ Nov 9 2011, 00:10) But ...   Nov 16 2011, 13:38
|- - krabapple   QUOTE (pappaapa @ Nov 8 2011, 10:38) Ques...   Nov 8 2011, 18:04
- - Wombat   QUOTE (pappaapa @ Nov 8 2011, 16:38) Ques...   Nov 8 2011, 15:55
- - Wombat   QUOTE (2Bdecided @ Nov 8 2011, 19:00) Far...   Nov 8 2011, 19:31
- - pappaapa   First: Thanks for your replies! And just to t...   Nov 8 2011, 21:20
|- - drewfx   QUOTE (pappaapa @ Nov 8 2011, 15:20) Firs...   Nov 8 2011, 22:42
||- - pappaapa   QUOTE (drewfx @ Nov 8 2011, 22:42) My und...   Nov 8 2011, 23:50
||- - drewfx   QUOTE (pappaapa @ Nov 8 2011, 17:50) QUOT...   Nov 9 2011, 03:58
|- - Soap   QUOTE (pappaapa @ Nov 8 2011, 16:20) So u...   Nov 8 2011, 23:24
- - Roseval   Having digitized some vinyl I know for sure I won’...   Nov 15 2011, 22:49
RSS Lo-Fi Version Time is now: 5th May 2015 - 01:21
