Windows Vorbis Comment editor w/ custom field support?
kyra
post Sep 18 2011, 17:16
Hello everyone,
I have literally spent months searching for a Windows programme, with or without a simple-to-use GUI, which supports editing Vorbis Comments in FLAC files, and supports adding any custom fields.
I'm very sorry if I have missed anything obvious but it wouldn't be the first time. dry.gif
For basic tagging, Tag&Rename is serving me very good, but it lacks the option of adding custom fields. The programme that I am looking for should not only be able to add custom fields, but more than one instance of each field (for example, several genres) as is encouraged in the Vorbis Comment standard.
Thanks a million for any help!
This post has been edited by db1989: Sep 18 2011, 18:40
Reason for edit: removing ! icon; this isn’t a priority topic
tpijag
post Sep 18 2011, 17:39
Two programs often mentioned here are http://www.mp3tag.de/en/ and http://www.xdlab.ru/en/
kyra
post Sep 18 2011, 17:57
They are both very good, but none of them do any sort of custom tag fields, which I find quite remarkable. sad.gif
ojdo
post Sep 18 2011, 18:12
Have you tried foobar2000? It supports custom fields and multiple instances per field.
http://freemusi.cc/
tpijag
post Sep 18 2011, 18:30
QUOTE (kyra @ Sep 18 2011, 11:57) *
I can not speak to mp3tag and specifically Flac files, but I would be quite surprised if you can not add custom Vorbis comments.
Load tracks, right click, extended fields, add field. Foobar also should do as what you want.
This post has been edited by tpijag: Sep 18 2011, 18:31
kyra
post Sep 18 2011, 18:38
QUOTE (tpijag @ Sep 18 2011, 19:30) *
I will be completely honest and admit that I have had no first-hand experience with Mp3tag, since it for no apparent reason refuses to work on my computer. However, in tag scanner, there is no 'add field' option under Extended information.
QUOTE (ojdo @ Sep 18 2011, 19:12) *
As a matter of fact, I have not! Thank you very much for the tip! I shall try this.
However, I am still interested in a stand-alone programme that can do this more swiftly!
Is there an 'add field' option in Mp3tag?
db1989
post Sep 18 2011, 18:40
What about…
QUOTE (tpijag @ Sep 18 2011, 18:30) *
tpijag
post Sep 18 2011, 18:41
Yes it has an add field options as noted above. Possibly I was vague as I was referring to fact that my use of mp3tag has been with mp3 files and not Flac. Functionality should be the same. They also have an extensive forum for assistance.
Edit:
There is no reason to believe a standalone program will handle your needs better or more swiftly than foobar2000.
This post has been edited by tpijag: Sep 18 2011, 18:52
kyra
post Sep 18 2011, 19:29
Thank you very very much for your assistance! I will reply in this thread if there are any problems. smile.gif
This post has been edited by db1989: Sep 18 2011, 19:34
Reason for edit: removing pointless quote of above post
RSS Lo-Fi Version Time is now: 28th July 2015 - 09:40
