TransPCM—use Float16/24 to reduce bit-depth, also promotes compression, 2013-05-30: beta 0.1.3a / formerly HalfPrecision / ref.: IEEE 754-2008
Nick.C
post Sep 12 2011, 22:03
lossyWAV Developer
When I first became aware of the Float16 type I found it interesting in terms of maybe having potential as a possible lossy storage type.
Attached is a processed version of the sample in this thread which has been decoded back to PCM. The processing is as follows (at this stage as there is no player that I am aware of):
Input file Sample [PCM] > FLOAT16 > [PCM] > Output File.
The conversion from integer to Float16 reduces the number of significant bits of the 24-bit sample to (a maximum of) 11. There is therefore an amount of added noise due to truncation. The added noise has been noise shaped using SG's adaptive noise shaping method as used in lossyWAV.
Original Sample
Lossy Float16 Processed Sample [edit] removed due to TransPCM executable / foobar2000 Float16 playback availability, 29th May 2012. [/edit]
If the 24-bit coded sample is encoded with FLAC (wFormatTag left as 0x0001 as FLAC does not handle Floating Point samples and wBitsPerSample is left as 24) there is a saving of in excess of 20% in filesize.
I don't see any practical advantage using this storage type for native 16-bit PCM.
Changelog:
TransPCM beta 0.1.3a 30/05/2013
  • Bug fix in Float24 handling (thanks Bryant!).
  • Bug fix in WAVE_FORMAT_EXTENSIBLE chunk handling (thanks again Bryant!).
TransPCM beta 0.1.2 02/06/2012
  • Modification to adaptive noise shaping for 44.1/48kHz input;
  • Amendment to tracer fingerprinting.
This post has been edited by Nick.C: May 30 2013, 07:57
Attached File(s)
Nick.C
post Jun 14 2012, 17:47
lossyWAV Developer
The use of --stdinname %d is to tell the program what filename to associate with the data taken from STDIN.
Error 50 (0x32) denotes that the string "tpout.wav" cannot be found in %d (i.e. all output files are expected to end "tpout.wav" - although this *should* have been documented....
The "/d /c" before "C:\.....\TransPCM" are parameters for cmd.exe which is called by foobar2000 to carry out the conversion.
I hope that this helps.
- Nick.C   TransPCM—use Float16/24 to reduce bit-depth, also promotes compression   Sep 12 2011, 22:03
- - AndyH-ha   This differs from simply reducing the bit depth?   Sep 12 2011, 22:11
- - Nick.C   Yes - in that values up to c. +/- 2^31 can still b...   Sep 12 2011, 22:19
- - saratoga   Isn't this pretty much what ADPCM does? Excep...   Sep 12 2011, 22:32
|- - C.R.Helmrich   You mean a-Law/µ-Law? Makes me wonder how many bi...   Sep 12 2011, 23:05
- - bryant   QUOTE (Nick.C @ Sep 12 2011, 14:03) Attac...   Sep 13 2011, 06:13
- - Nick.C   The plan was to simply set wFormatTag= 0x0003 and ...   Sep 15 2011, 21:09
|- - benski   QUOTE (Nick.C @ Sep 15 2011, 16:09) The p...   Sep 16 2011, 14:03
- - knutinh   float16 could be very efficient on GPU hardware if...   Sep 16 2011, 13:49
- - Nick.C   I understand that currently players are rather unl...   Sep 16 2011, 19:26
- - Nick.C   Below is Delphi / IA32 & x87 code used to enco...   Sep 22 2011, 13:05
- - Nick.C   HalfPrecision beta 0.0.2cd attached. [bugfix] [sup...   Oct 20 2011, 12:53
|- - Gumboot   QUOTE (Nick.C @ Oct 20 2011, 11:53) NB: t...   Dec 22 2011, 23:19
- - lvqcl   foobar2000 1.1.9 beta1: "Implemented experime...   Oct 22 2011, 10:54
- - Nick.C   RE: TransPCM—use Float16/24 to reduce bit-depth, also promotes compression   Oct 22 2011, 14:24
- - Nick.C   HalfPrecision beta 0.0.2e attached [superseded]. F...   Oct 24 2011, 18:23
- - pdq   I once had an idea for how to encode audio data. T...   Oct 24 2011, 19:29
- - Nick.C   That would be one way of doing it. However sample ...   Oct 24 2011, 21:02
- - Nick.C   HalfPrecision beta 0.0.2f attached superseded . ...   Nov 1 2011, 13:53
- - Nick.C   HalfPrecision beta 0.0.2g attached. Superseded. ...   Nov 10 2011, 13:41
- - Didjeridoo   Nick.C Thank you for your innovation. It remains t...   Nov 11 2011, 11:36
- - Nick.C   @Didjeridoo: Thanks - I am also looking forward to...   Nov 11 2011, 23:05
- - Nick.C   HalfPrecision beta 0.0.2h attached. Superseded ...   Nov 14 2011, 21:22
- - Didjeridoo   Nick.C I watch all the moves and develops Is not...   Nov 15 2011, 10:32
|- - lvqcl   QUOTE (Didjeridoo @ Nov 15 2011, 13:32) P...   Nov 15 2011, 15:53
- - Ljubo44   Do you have any sample of command line for foobar.   Nov 15 2011, 19:13
- - Nick.C   HalfPrecision beta 0.0.2i attached. Superseded. F...   Nov 15 2011, 20:05
- - Ljubo44   on 16/44,1 size is same after compress halfp.wav 1...   Nov 15 2011, 21:24
|- - Nick.C   QUOTE (Ljubo44 @ Nov 15 2011, 20:24) .......   Nov 15 2011, 22:05
- - Ljubo44   You are right, I used foobar 1.1.9 to convert to f...   Nov 15 2011, 22:37
- - Nick.C   HalfPrecision beta 0.0.2j attached. Superseded. ...   Nov 15 2011, 23:02
- - Nick.C   HalfPrecision beta 0.1.0a attached. Superseded. ...   Nov 17 2011, 14:20
- - Didjeridoo   I hope the developers do not ignore innovation   Nov 18 2011, 19:44
- - Nick.C   foobar2000 1.1.10 beta 1 adds Float24 support - re...   Nov 18 2011, 21:24
- - pompon   QUOTE (Nick.C @ Sep 12 2011, 16:03) When ...   Dec 5 2011, 06:37
- - FreaqyFrequency   @pompon: This is different from those coding sche...   Dec 5 2011, 08:44
- - Nick.C   Right then people - HalfPrecision needs a new name...   Dec 22 2011, 20:34
- - Nick.C   .... a surprise, yes, however as the standard has ...   Dec 23 2011, 08:20
|- - Gumboot   Well, by "huge surprise" I mean "de...   Dec 23 2011, 08:43
|- - Nick.C   It would surprise me if, when using any type of fl...   Dec 23 2011, 09:01
|- - Gumboot   Well it's not really in its infancy. I includ...   Dec 23 2011, 22:02
- - Nick.C   I accept that the Float16 proposal must have been ...   Dec 27 2011, 21:34
- - FreaqyFrequency   I fear that I may need a little more clarification...   Jan 9 2012, 05:48
- - Nick.C   Hi there, Using HalfPrecision to convert from 24-...   Jan 9 2012, 20:05
- - FreaqyFrequency   Thanks for the reply, Nick. Looking at the Replay...   Jan 10 2012, 03:36
- - Nick.C   TransPCM beta v0.1.1 attached. Superseded Chang...   May 29 2012, 21:51
- - Nick.C   TransPCM beta 0.1.2 attached. Superseded. Chang...   Jun 2 2012, 13:57
- - Ljubo44   CODE/d /c C:\bin\TransPCM_beta_0.1.2...   Jun 14 2012, 01:29
|- - lvqcl   QUOTE (Ljubo44 @ Jun 14 2012, 04:29) What...   Jun 14 2012, 15:47
- - db1989   Why do you have switches before the executable? An...   Jun 14 2012, 09:02
- - Nick.C   The use of --stdinname %d is to tell the program w...   Jun 14 2012, 17:47
- - Nick.C   Rockbox now has added Float16 compatibility* - tha...   Nov 24 2012, 23:15
- - saratoga   No problem. Hope its useful to people.   Nov 25 2012, 00:28
- - Nick.C   TransPCM beta 0.1.3a attached to post #1 in this t...   May 30 2013, 07:58
RSS Lo-Fi Version Time is now: 5th September 2015 - 03:32
